Old 04-17-2007, 08:06 AM   #3001
Trader Rating: 27 (100%+)
Send a message via Yahoo to HECTICRACER
i want to know if you use the mugen hexes do you need to replace the nuts with the mugen ones or the losi ones fit
HECTICRACER is offline   Reply With Quote
Old 04-17-2007, 08:21 AM   #3002
tomdav's Avatar
Trader Rating: 42 (100%+)
Losi fit.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 04-17-2007, 09:09 AM   #3003
The Mugen hubs go on in such a way they almost seem made for the car. If you were having a hard time making maximum width you can just run 1mm on each side. That puts my car at 310mm width. I've never been teched to 310mm width, but you would still notice the 2mm width change even though it doesn't sound like much.
Thanks for the Kyosho numbers guys, that's what we were looking for to try.
Thanks again, Chad
cwalters is offline   Reply With Quote
Old 04-17-2007, 10:50 AM   #3004
pumpkinfish's Avatar
Which way do you install the shock spring cups to prevent them from popping off? I have lost a couple on the front. Right now I have the slot/tab on shock end facing out from body. Is that right?
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 04-17-2007, 11:03 AM   #3005
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
no they should eather face in towards the diff houseing or out towards the wheels.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-17-2007, 05:43 PM   #3006
trebor's Avatar
Hey people, just wanted to know if the Orion V6 clutch will fit the 8ight? Does anyone run one in theirs?
trebor is offline   Reply With Quote
Old 04-17-2007, 05:53 PM   #3007
JWRockman's Avatar
Default bottom shock caps
Point the opening to the bottom shock caps toward the wheels not toward the inside. If you don't they can pop off.
Rockman
JWRockman is offline   Reply With Quote
Old 04-17-2007, 08:44 PM   #3008
A_Stratus's Avatar
I just purchased an 8ight and it should be in next week sometime I am guessing...I just have a couple questions.
1) I have the ofna chrome top starter box and I was wondering if you can use it with this buggy? I know when it first came out there were some problems but is there a mod or a fix to it?
2) This question is about the King Headz clutch shoes...what is the difference of them over the std Losi ones? Just the grade of aluminum used? Can I just swap different shoes out or do I need a different fly wheel for king headz ones over stock losi ones?
Thanks,
Aaron
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 04-17-2007, 09:31 PM   #3009
lavaandy's Avatar
Default buggy
new buggy
lavaandy is offline   Reply With Quote
Old 04-17-2007, 09:58 PM   #3010
R40Victim's Avatar
It'll work, but you may need to cut the rubber wheel a bit to fit in the 8ight's tiny flywheel opening. You may also need to dremel the chassis a bit.
They work with the stock flywheel, and yes, they are just a different grade of metal, and practically identical to the stock shoes.
R40Victim is offline   Reply With Quote
Old 04-17-2007, 10:32 PM   #3011
A_Stratus's Avatar
Thank you very much R40!
I just seen on Losi's website...the narrowing the wheel on the box, sorry!
Thanks again!
Aaron
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
Old 04-18-2007, 01:22 AM   #3012
freefallmarine's Avatar
Hope some of you guys make it to Tulsa's race this weekend! If you need info for the track, p.m. me.
freefallmarine is offline   Reply With Quote
Old 04-18-2007, 01:48 AM   #3013
trebor's Avatar
Ill be there. jk. Good luck, call me
Old 04-18-2007, 03:42 AM   #3014
Cant wait! its suppose to be 80 deg's this weekend!
Old 04-18-2007, 04:09 AM   #3015
Thanks,
Aaron
I use the same starter box and it works fine, but I did have to dremel the chassis to get it to work. The KH 7075 shoes work great!! They are supposed to be made out of the same material as the new Losi blue 7075 shoes, but they seem to last a LOT longer. I have almost 2 gallons on mine now and I should get another gallon out of them...my stock losi shoes were toasted in a gallon (the composite ones and the blue aluminum ones). I did deburr the KH shoes about 1/2 gallon ago..
gtsum is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
