Old 04-16-2007, 11:17 AM   #2971
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
I'm sure someone will chime in with the number - but if not, I'm sure it would easily be found on the kyosho website. I'm at work or I'd take a look... I shouldn't even be on here.... lol
XMSRacing is offline   Reply With Quote
Old 04-16-2007, 11:26 AM   #2972
KARO's Avatar
Just wondering about that legal width question...I sometimes travel to big race where cars are teched.
I think the ball end number is KYO1296...and I probably have some lying around at home from my last buggy (777SP2). Will try them out tonight if I can find some. May need to use the Kyosho balls with them...one models balls may be larger than the others . The inside ball on the steering assembly has that bump steer offset too. I've broken one of those Losi ball ends myself.
KARO is offline   Reply With Quote
Old 04-16-2007, 11:37 AM   #2973
The problem with using metric rod ends is that the diameter of the hole for the screw that goes into the arm is different.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 04-16-2007, 11:43 AM   #2974
It's not a super big deal fellas. Someone told me today Losi has a superduty rod end but I have to do some checking yet to find out for sure. It just seems like a part that shouldn't break and when you're racing you don't need to have that in your mind all the time. Confidence in your car= better finishes.
Hey boys we're on page 100!
cwalters is offline   Reply With Quote
Old 04-16-2007, 12:19 PM   #2975
trebor's Avatar
Originally Posted by KARO
Is width still ROAR legal with the +2 hubs?
I would like to know also even though Im not doing alot of those kinda races. Just to know is good.
*CELEBRATION* PG100
trebor is offline   Reply With Quote
Old 04-16-2007, 12:22 PM   #2976
XMSRacing's Avatar
Yes and no... every car needs a weak point. Do you want that to be $8 arms... $$$ shock towers... or 75 cent rod ends.
Old 04-16-2007, 12:35 PM   #2977
I don't want anything to break, ever. You can't win if you don't finish. $.75 or $8 doesn't matter. (exception-a full speed crash into a wall) If you factor in fuel, entrance fees, gasoline to get to a track, and maybe a hotel it gets damned expensive for every minute spent on the track.
Bruce Edwards
Thanks to:
Old 04-16-2007, 12:55 PM   #2978
good point XMS but I would rather the stress be placed on an aluminum tower or that arm that is 7mm thick plastic all the way around versus a 1.5-2mm thickness. I think there are better alternatives out there or I think Losi may have already addressed the issue. I'm just trying to come up with a solution is all.
Where is Aaron when we have questions like this. I pmed a Losi sponsored guy I know personally and still haven't heard anything back yet. Hopefully there is a solution and it has a LOSA in front of the number
Man, I'm on page 100 again. Sweet...
Old 04-16-2007, 01:07 PM   #2979
I know I broke two of these very early in the season but I haven't broken one since. I think a little bit of it had to do with it being too cold.
*Topher* is offline   Reply With Quote
Old 04-16-2007, 01:39 PM   #2980
freefallmarine's Avatar
Yes the 2mm hubs are Roar legal.Roar rules are 330mm width of the buggy. And the Kyosho part for the rod ends are IFW150 it sucks because it comes with the Kyosho tie rod ,dont use it. just sell it to a 777 driver and make some money back.
freefallmarine is offline   Reply With Quote
Old 04-16-2007, 02:34 PM   #2981
GTB_USER_Erik's Avatar
Originally Posted by cornerspeed
Yes, it numbed the car and made it more comfortable to drive. You still have to drive the car smooth, I don't care with what ever set-up is run. Drive calm and you'll get it fast.
Cornerspeed,,,,
I thank you for the set-up. Do you know if the RTR comes with the 3 deg. rear toe-in 2 deg. anti-squat block or that a kit part?????
GTB_USER_Erik is offline   Reply With Quote
Old 04-16-2007, 02:37 PM   #2982
I am currently having a few problems with my 8 I hope someone can help me out, If I start the car and run it on the starter box it runs fine but soon as its on the ground if i accelerate then brake hard the engine will stall, I thought it may be the clutch still partly engaged but I am running aloy and carbon shoes with the silver and gold springs which I thought would have been hard enough.
If you have any suggestions please let me know.
Thanks Brendan
mtmmotorcycles is offline   Reply With Quote
Old 04-16-2007, 03:23 PM   #2983
22Racer's Avatar
Trader Rating: 67 (100%+)
I replaced a broken steering rod end with a Jammin one, seems to fit nice.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 04-16-2007, 03:29 PM   #2984
32racer32's Avatar
Might want to check your piston. Sounds like you may have got dirt or trash on the piston and dammaged it a bit.
32racer32 is offline   Reply With Quote
Old 04-16-2007, 03:30 PM   #2985
Originally Posted by GTB_USER_Erik
Cornerspeed,,,,
Yep the rtr comes with the 3T 2A block.
losi8ight is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
