Old 04-11-2007, 09:44 AM   #2881
that track is in Vienna Austria and was the location for the 1/10th electric euros last year.
There is a video of Hupo driving a 7 cell xxx4 over the jump but i think an 8th would survive once the chassis is strraightened back out
http://www.rmc-wien.at/downloads.php
chuckyegg is offline   Reply With Quote
Old 04-11-2007, 06:00 PM   #2882
cornerspeed's Avatar
Originally Posted by *Topher*
What springs have you been using with all aluminum? Anyone have any suggestions?
I have been using the Gold/Black. Was told that is too soft that I should run Silver/Gold. Might try it this weekend. But, I'm going to a track that I haven't been before, so I may not.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 04-11-2007, 08:22 PM   #2883
GTB_USER_Erik's Avatar
Default Panther Tires
Well I just got a set of Panther Tires, "Switch 2.0s" I'm about to mount them
up and noticed there is a single rib on one side of the tire. Here is the question, What side does this go on, inside or outside ?????????
GTB_USER_Erik is offline   Reply With Quote
Old 04-12-2007, 01:15 AM   #2884
freefallmarine's Avatar
Thats wierd..
freefallmarine is offline   Reply With Quote
Old 04-12-2007, 01:31 AM   #2885
Switch 2.0 question above.
The rib will go on the outside I do beleave. I checked my set out and they are mounted on the outside. Plus the brand name is mounted on the same side of the rib.
kyracer is offline   Reply With Quote
Old 04-12-2007, 05:01 AM   #2886
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Outside
XMSRacing is offline   Reply With Quote
Old 04-12-2007, 07:18 AM   #2887
That is what I thought, thanks guys
Old 04-12-2007, 09:00 AM   #2888
trebor's Avatar
How do those tires work?
trebor is offline   Reply With Quote
Old 04-12-2007, 09:08 AM   #2889
XMSRacing's Avatar
For indoor - they rock.
Old 04-12-2007, 09:13 AM   #2890
I bought them to use outside on Bluegroove clay. I hope they will do the job
Old 04-12-2007, 09:23 AM   #2891
Holeshots from Proline in M3 could also help as well, but I haven't run any yet to decide if the wear factor is worth it. Might be good for a qualifier and a 30 minute main or something.
Panther switches work awesome inside on clay but when the track dries out we usually switch to inside jobs in M3 compound. Both the Switches and Inside Jobs have pretty good wear characteristics if you are hooked up and easy on the trigger.
cwalters is offline   Reply With Quote
Old 04-12-2007, 10:32 AM   #2892
The switch 2.0 clay compound is for indoor use only.
I have seen some people use a softer compound outside but from what I can tell its a handfull. You know what they say. A loose car is a fast car.
Old 04-12-2007, 11:44 AM   #2893
MannEdge's Avatar
Trader Rating: 19 (100%+)
I am thinking about the 8ight and I am little worried about the throttle servo problem. Has this been corrected with the new models? If not, how do you know if you are going to have servo problems? By the way, if you cannot tell, I am a newbie.
Thanks,
Manny
MannEdge is offline   Reply With Quote
Old 04-12-2007, 12:05 PM   #2894
XMSRacing's Avatar
cheaper servos plus not being setup right... and even possibly being setup right = disaster.
Buy good servos, take your time setting them up, (plent of pics on this thread) have an experienced racer check it out before you run it, and you'll be fine.
I fried a JR 590 that was setup correctly - however, since I put in a pair of JR 9000T's - I haven't had a single problem.
Old 04-12-2007, 12:09 PM   #2895
MannEdge's Avatar
I purchase HS-5955 for both the throttle and the steering.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
