Old 03-24-2007, 10:33 AM   #2596
RBMike's Avatar
I was going to say king heads
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-24-2007, 07:08 PM   #2597
dirtracer1's Avatar
are any of you guys adding weight to the rear of the buggy? if so, how? where do you get them and how do you install them?
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 03-24-2007, 07:26 PM   #2598
kylehirano's Avatar
Trader Rating: 14 (100%+)
Looks like 5 Losi 8ights in the top ten, after round one, at the Silver State nitro challenge, led by Drake.
Looks like another Losi butt-kickin
Oh yeah only one AE in the top ten
A bad day racing is still better than none at all.
TAMIYA TRF Racing Factory
CWRCB-Central Washington R/C Boat Club, RCUnlimiteds
kylehirano is offline   Reply With Quote
Old 03-24-2007, 08:34 PM   #2599
sport10's Avatar
You need the M2C 3T/3A rear plate set to use the weights. They will have 1/2, 3/4, and 1 ounce weight available to attach to the plate.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 03-24-2007, 08:49 PM   #2600
freefallmarine's Avatar
Go Losi!!!
freefallmarine is offline   Reply With Quote
Old 03-24-2007, 08:59 PM   #2601
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
A while ago some people were asking about setup stations for the buggy...so I wrote this review on the TM setup station:Team Magic Setup Station Review
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-24-2007, 09:13 PM   #2602
22Racer's Avatar
Trader Rating: 67 (100%+)
Drake said in one of the latest magazines to make sure the spring cup slot faces outward so it doesn't get knocked off as easy. ( I think, I didn't go reread it)
It also looks like Drake uses the front green spring on th rear in the pic? Anyone try this?
As for the slight bow in the chassis, I put a straight edge on both our eights (ran once) the both had a slight bow to them (upward in the middle, almost 1mm on one) I am a machinist and if you mill the pockets on the top it will bow the opposite way than it is. Maybe it is intentional or it gets some bow in it when they bend up the sides.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 03-24-2007, 09:32 PM   #2603
Trader Rating: 37 (100%+)
Is there a trick to get this to work, just wondering, because I have a lot of standard 3-shoe clutches I can use and only one Losi 8ight clutch at the moment.
i use the mugen mbx5 collect, flywheel and clutch nut with the losi bearings and clutch bell. it lines up fine. you just need to shim it properly. on my v-spec, i need 1 3x5 shim to get the right end play. on my rex 421b, no shimming needed.
Buggy Master is offline   Reply With Quote
Old 03-24-2007, 09:35 PM   #2604
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
Finally ran the 8ight! Took me awhile to get use to it, but i can tell its going to be a sweet toy. Best day of rc'in i've had forever!
2 quick questions.
1. Are you guys using lock tight on your wheel nuts (or hexes, i dunno what you call them lol) I had one come off, and 2 were finger loose when I got home. i know i tightened them good.
2. whats a good brake par and how often should I replace them?
Thanks a bunch!
-William
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 03-24-2007, 11:16 PM   #2605
vr6
Trader Rating: 22 (100%+)
anybody having problems with their steering servo stripping gears? i checked my servo saver. that seems to be fine. i have it turned out like about 3 to 3 1/2 turns. absolutely no binding in the steering itself. i stripped a metal gear servo and a plastic servo from just being cought on a track tube(pvc) any help would be appreciated
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 03-24-2007, 11:48 PM   #2606
2 quick questions.
Thanks a bunch!
-William
i locktite the wheel hexes as it's metal on metal contact. as far as pads i've run thru 1.5 gallons so far and brakes still seem good, no fade.
steveatcal is offline   Reply With Quote
Old 03-25-2007, 02:36 PM   #2607
kylehirano's Avatar
Here is a pic of my 8ight, just wanted to snap a picture while it was still clean
The boy in pic#4 is my son Dylan, hes only 2yrs old and has driven the 8ight out in the street. The boy is nuts about RC. Get a good look, hes gonna be the next world champ.
Losi 8ight building and setup-losi-006.jpg   Losi 8ight building and setup-losi-007.jpg   Losi 8ight building and setup-losi-008.jpg   Losi 8ight building and setup-losi-010.jpg
Old 03-25-2007, 03:30 PM   #2608
Stewart Fan's Avatar
Are those decals or did some one paint that?
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 03-25-2007, 03:43 PM   #2609
kylehirano's Avatar
Those arent decals, It was painted by BODZ, you can buy the bodies on Ebay, they average between $60 to $80.
Old 03-25-2007, 06:14 PM   #2610
cornerspeed's Avatar
Truhe 1st. / Drake 2nd in buggy at Silver State. Congrats. More Losi domination.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
