Old 03-22-2007, 07:19 PM   #2581
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i like the j concepts bodies.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-22-2007, 09:08 PM   #2582
cornerspeed's Avatar
I like the Proline body myself. Looks streamlined to me. I am painting up my second one now.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 03-23-2007, 05:17 AM   #2583
j concepts bodies, and save the goo, you wont need it with the j concept body hd bodies.
T Green is offline   Reply With Quote
Old 03-23-2007, 07:34 AM   #2584
RBMike's Avatar
I just painted a J-concepts body last night, I have to say I like the shape of the stock body better.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-23-2007, 07:39 AM   #2585
i drilled a new hole in the front body mount parallel with the chassis to make it easier to get a clip in, it allows better access with the humps on the illusion body.
Old 03-23-2007, 10:10 AM   #2586
freefallmarine's Avatar
Will the paint stay if i dont use the goo, and crash alot?
freefallmarine is offline   Reply With Quote
Old 03-23-2007, 10:36 AM   #2587
Kcdzim's Avatar
Send a message via AIM to Kcdzim
Yes. Assuming you let the paint cure long enough (over a day), and are using the correct paint. In my experience, I've never had paint crack and peel unless I used the wrong paint. I've definately had spots wear off (top of battery box, top of pipe, side guards), and in those areas shoo goo (or a shoogooed bit of extra lexan) can be used to shield those spots.
With the 8ight, or any buggy, if you crash a lot the weak points are going to be the mounting holes, where flex will stretch or compress and crack the body. If you protect the wearing spots on the body, the paintjob will still look pretty good long after the body looks shredded from flexing (and top side skids).
Losi 8ight 2.0 Associated SC10 Associated RC10T Xray T3 2011
Corally RDXΦPhi Vintage Transam
Professor Z Graphics
Kcdzim is offline   Reply With Quote
Old 03-23-2007, 02:59 PM   #2588
trebor's Avatar
Originally Posted by tex1
Matt,
The 2050 (discontinued so don't sell it) has more bottom. The 2060 is a smooth pipe that was designed to settle peaky motors such as the V-Spec.
Both are great pipes! The 2050 will get you a little better fuel times.
Hint = The 2060 (long curved) comes with a completey different header than the 2050 (short squared). Get both headers! It is a great tuning option.
Hope this helps,
TEX
Tex,
is the OS 2050 really discontinued or on backorder? anyone know?
trebor is offline   Reply With Quote
Old 03-23-2007, 04:42 PM   #2589
Matt Howard's Avatar
Originally Posted by trebor
Tex,
discontinued
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-23-2007, 05:43 PM   #2590
I got my Qoncepts split center diff mount installed today, makes getting to the center diff super easy
RCTech #361
Old 03-23-2007, 07:48 PM   #2591
trebor's Avatar
where did you get it?
Old 03-23-2007, 07:59 PM   #2592
www.qoncepts.com It's kinda pricey IMO but will definitly be a time, and sanity, saver
RCTech #361
Old 03-23-2007, 09:55 PM   #2593
pretty, cool. pricy but cool.
Old 03-24-2007, 10:00 AM   #2594
kylehirano's Avatar
Trader Rating: 14 (100%+)
A few pages back someone said a standard 3-shoe clutch will work on the 8ight, but I tried to put one on, and the standard 3-shoe clutch does not extend out far enough to make good contact with the spur gear?
Is there a trick to get this to work, just wondering, because I have a lot of standard 3-shoe clutches I can use and only one Losi 8ight clutch at the moment.
A bad day racing is still better than none at all.
TAMIYA TRF Racing Factory
CWRCB-Central Washington R/C Boat Club, RCUnlimiteds
kylehirano is offline   Reply With Quote
Old 03-24-2007, 10:10 AM   #2595
tomdav's Avatar
Trader Rating: 42 (100%+)
I have a quick change Kingheadz mount and you can flip the upper mounts to move the engine foward for standard clutch setup.
Loving the 8ight so far. Ran at a big event last weekend and took some big hits in the main. The only issue so far is losing a spring cup in practice and having the spring get dislodged from the cup during the main. I was going full tilt down the straight and someone got a little aggressive coming out of pit lane. My car did its best impression of a blender and kept on truckin.
The only gripe I have is the geometry of the throttle servo to the carb. I use so little throw that I feel Im not getting enough consistancy thruout the range. Need to mess around with the radio some more I guess.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
