Old 03-21-2007, 04:43 PM   #2566
22Racer's Avatar
Trader Rating: 67 (100%+)
I've seen guys wrap tinfoil around the head so it stays warm without leaning it out to much. I am going to do this on our new Novarossi's.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 03-21-2007, 06:19 PM   #2567
tex1's Avatar
Send a message via Yahoo to tex1
Wink
Eric -
It should take you a minimum of 3 - 4 tanks (sometimes 6 -7) to get the motor running smooth and stable. This is when you shut it off the first time. After that, run the motor up to temp and make sure it stays stable for a minute or two then turn it off. That is one cycle. Let it completely cool. Run it again another 3 or 4 times and then you should be good to take it to the track for further tuning.
Hope this helps. Novas take a long time to set and loosen up. OS engines take less time. The principles are the same. The metals in the piston and sleeve are different. If they are not the right size (ie: at the engineering temp) the softer material will be worn away.
Have fun,
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 03-21-2007, 06:43 PM   #2568
make sure that when your breaking your engine in with the heat cycle method, you put the piston at the bottom of the stroke of the cylinder as it cools.. so the piston doesnt get stuck at the top
Garrison is offline   Reply With Quote
Old 03-21-2007, 08:44 PM   #2569
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
To those using a lipo receiver pack....
Do you really need a voltage regulator.. or can I get away with not using one for the weekend? The one I got is wack and I don't care for it, I will have to extend the wires and I don't have the time or supplies at hand right now.
Would I be o.k. to run without the regulator for practice this weekend or should I pick up a nimh?
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 03-21-2007, 09:27 PM   #2570
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Pick up a NIMH, that sucker can be well over 8 volts on a fresh charge!
XMSRacing is offline   Reply With Quote
Old 03-21-2007, 09:32 PM   #2571
thanks guess i'll get a nimh while i wait..
Founder- RcBros.com
Old 03-22-2007, 05:52 AM   #2572
GTB_USER_Erik's Avatar
Originally Posted by tex1
Eric -
Have fun,
TEX
Thank you very much for the VERY INFORMITIVE help on this subject. For the last thing I want to do is detonate this Engine, (it was a birthday present from the Mrs......) She wants me to win some races this summer
p.s. I do to. I know though my driving skills need to improve though
GTB_USER_Erik is offline   Reply With Quote
Old 03-22-2007, 08:00 AM   #2573
Mytimac's Avatar
So any opinions on this new Losi starter? Anyone seen the team drivers with it yet?
Mytimac is offline   Reply With Quote
Old 03-22-2007, 09:30 AM   #2574
I haven't seen anyone use the new starter box but the idea is brilliant. Too bad it didn't come out at the same time as the buggy.
satoch is offline   Reply With Quote
Old 03-22-2007, 09:32 AM   #2575
You need a voltage regulator.
Old 03-22-2007, 01:21 PM   #2576
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
im shure a couple have it this weekend at silver state.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-22-2007, 03:03 PM   #2577
freefallmarine's Avatar
Anyone have a body prefrence? Pro-line, J concepts,or stock Losi? Which one hold's up better?
freefallmarine is offline   Reply With Quote
Old 03-22-2007, 06:57 PM   #2578
R40Victim's Avatar
There's one of each on my race team, so we'll see how they do. I like my stock body, fits well, is light, gets plenty of air over the motor, and looks good. Of the other two, one is very thick, a little heavy(but the marginal increase in weight really shouldn't be much of an effect) and is very strong. The last is right in the middle, but I prefer the style of my stock one better. Pics:
http://z6.invisionfree.com/Bug_Bite_...wtopic=15&st=0
and:
http://btrc-central.net/forum/viewtopic.php?t=396
R40Victim is offline   Reply With Quote
Old 03-22-2007, 07:10 PM   #2579
Matt Howard's Avatar
the Jconcepts body is thick (heavy) compared to the kit body. I think I like the lines of the kit body over the Jconcepts, I've got a crowdpleazer being painted as we speak so I can't comment on that one yet.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-22-2007, 07:17 PM   #2580
Thanks, 40,and Matt. Weight won't be an issue. I use shoe-goo in them and the bodies weigh a ton! But i crash alot and i need the goo!!!
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
