Old 03-20-2007, 08:26 PM   #2551
Ronny.A's Avatar
Originally Posted by micrors4guy
ronny a- you arent running for mugen anymore?
Hey man:-)
At the moment, I have some things to do & promote for the shop, and this will also make me able to travel/race more abroad. So for this season I'm not racing for Mugen Seiki. I don't know what I will be running this year, but for now, it's currently the 8ight I'm testing out.
Ronny.A is offline   Reply With Quote
Old 03-20-2007, 08:29 PM   #2552
kylehirano's Avatar
Trader Rating: 14 (100%+)
Originally Posted by freefallmarine
Has anyone mounted a fuel filter in the fuel splash guard? Im just trying to figure a place to put one.
You can cut or drill two small holes in the splash guard and mount a filter with a zip-tie, I tried this and it worked just fine, but be carefull where you drill your holes because space is very tight.
Also I have a idea on the leaky shock situation, when you have your shocks apart, put a thin washer (shim) in first then your first o-ring ,spacer, o-ring, plastic cap and aluminum retaining cup. The shim will compress the o-rings so they hold to the shock shaft tighter, I used some traxxas shims for the revo, and I ran the local track a few times and so far no leaks, I threw away the package the shims came in so I dont have a part # but I got them at the LHS.
A bad day racing is still better than none at all.
TAMIYA TRF Racing Factory
CWRCB-Central Washington R/C Boat Club, RCUnlimiteds
kylehirano is offline   Reply With Quote
Old 03-20-2007, 09:15 PM   #2553
Ronny.A's Avatar
Sullivan CT-1 Screen Fuel Filter
http://www2.towerhobbies.com/cgi-bin...?&I=LXFU76&P=0
Old 03-21-2007, 04:43 AM   #2554
GTB_USER_Erik's Avatar
Originally Posted by Ronny.A
Eric Use a heat-gun or a hair-dryer to pre-heat your engine a little before attemting to start it. Blow heat on the engine-head towards the side that your tune pipe is, not towards the servos as this builds condensation in them when it's cold in the wether Don't use the highest setting on a heat-gun, that's just too hot. This will fire up your new engine in a snap, and help against unesessary stress on your conrod & setup, not to mention your startbox-wheel
I do have a Heat-Gun so I will do as suggested.
thanks Ronny
GTB_USER_Erik is offline   Reply With Quote
Old 03-21-2007, 06:24 AM   #2555
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
GTB -
When getting ready to start your motor remove the glow plug, heat the crank case and oil it lightly. Once heated ( case measures 180+ ) you can prime the engine on the box for a couple of seconds. Screw your glow plug back in. Fire her up.
Take your motor to 200 + on your first tank. Don't be afraid of the needles!
Once at 200, set the idle and low needle. Dont get it on the pipe making max power. Your parts are tight mechanically and the motor is not ready for this yet. Keep running the car! If it dies, do not let it cool back down. Fire her up and on you 3rd tank you can get the motor on the pipe a little.
Once the motor stays stable for 5 minutes and the tune and temp does not change from her loosening up, you can shut it off and let it cool. Always make sure the piston is bottom dead center and not stuck in the top.
Thermal cycle the motor 4 or five times and you are set.
It would be better if you did this in a parking lot with some old wore out tires from yur LHS.
This way you don't stress the drive line too bad while your motor is tight.
The key is to break it in at temp. Any lower and the parts are not expanded fully to thier engineered dimensions.
Hope this helps,
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 03-21-2007, 12:19 PM   #2556
Well I've got three different chassis here, two are new and all three are bowed up on a flat surface. Could be from the machining or posssibly even the anodizing process.
Here's something for you all to check out: A losi EIGHT brushless/lipo!!!
Go on YouTube and search Losi 8ight electric racing clip...
cwalters is offline   Reply With Quote
Old 03-21-2007, 12:32 PM   #2557
RBMike's Avatar
Ha Ha, That's great. I just converted my Pro-spec to brushless electric. Hope to get it to the track in the next couple of weeks to see how it stands up.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-21-2007, 01:44 PM   #2558
The brushless 8 didn't look as if it was properly balanced. It seems the drivers side is heavier.
satoch is offline   Reply With Quote
Old 03-21-2007, 01:47 PM   #2559
R40Victim's Avatar
There are many of us intersted in a conversion like that, so let us know what you spend to put it together
R40Victim is offline   Reply With Quote
Old 03-21-2007, 02:55 PM   #2560
Originally Posted by tex1
GTB -
Hope this helps,
TEX
"Thermal cycle the motor 4 or five times and you are set"
Does this mean Run the engine up to 200 and shut down. Four or times or?? please define
Erik
Old 03-21-2007, 02:58 PM   #2561
I have expreance in Brushless conversions. To do it RIGHT, your looking at five to six hundred dollars, on top of your donor car
Old 03-21-2007, 03:34 PM   #2562
Kcdzim's Avatar
Send a message via AIM to Kcdzim
As far as metal treating processes go, anodizing (even hardcoat anodizing) is primarily superficial. It's a series of electrically charged chemical dips and it's never going to bend or stress a part. It's either the metal relieving internal pressure during milling, an intentional bend, or very poor material and part care. If the chassis was heat treated AFTER machining, that's just about the only other reason I could think of that could cause a warp (if it were flat to begin with). It's a bit less common to heat treat after machining though, primarily because the part will change, so I doubt this is the case.
Losi 8ight 2.0 Associated SC10 Associated RC10T Xray T3 2011
Corally RDXΦPhi Vintage Transam
Professor Z Graphics
Kcdzim is offline   Reply With Quote
Old 03-21-2007, 03:37 PM   #2563
RBMike's Avatar
lets see, Nitro Motor=200 to 350 (say 275 average). Pipe & header=125. plug, clutch w/flywheel & bell=100+. fuel=30.
That's 530 right there so it's about the same as a brushless set-up.
Downs, custom motor mount & have to recharge batteries.
Ups, no fuel, no plugs, no noise, no clutches, less mess, less maintainance(on motor).
-B44 (Novak)
Old 03-21-2007, 03:40 PM   #2564
Kcdzim's Avatar
Erik
There are about a dozen different ways to heat cycle an engine and group of people that will say one is better than the others...
Basically, run the engine until it reaches 200 degrees F, shut it down, get the piston down to the bottom of its stroke (flywheel will rotate easily at that point), let it cool, run till it reaches 200... etc etc. Hes saying repeat the process 5 times.
Often your engine mfg will supply break in instructions. I believe mine said start at 180, then cycle at temp increases of 10 degrees with each subsequent cycle until you're running around 220.
Old 03-21-2007, 04:24 PM   #2565
Yes true...
Proper Brushless Motor = 250 to 300$. HighQuality Brushless ESC = 150 to 250$. A minumin of a 4S Li-Po Battary 300$ ( 1/8 scales are Heavy to propel). And a Charger for the Li-Po, These take a different Charger 100 to 200$.
Total = 800.00 To do it right
Fun factor; Priceless
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
