Old 03-11-2007, 06:58 PM   #2386
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
guess i should have looked in the package I'm a dork haha ty
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 03-11-2007, 08:59 PM   #2387
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Hey guys, what shims do you use on your differentials to eliminate backlash? Do you also use any INSIDE the diff? If so, what size shims do I need, or Losi part number? I have been trying to find out, but I dont see it listed in the exploded view/ price list. Thanks!
BTW put 3/4 gallon on the 8 today, and dang so much fun, but it pushes halfway through the turn off power, and a little on power. Then after a BMX track owner let us run on his HUGE track. DANG these things FLY!!! Just glad I didnt break anything landing from 20 or so feet up!
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-12-2007, 07:34 AM   #2388
If you used the stock setup, that would be the reason for the push. Try out the setups posted for Amezcua, Drake, or Truhe. All three of those should aleviate the problem. I found the stock setup to push entirely too much, but once you move the hubs all the way back and change to the 3T/3A rear pivot block (along with some small suspension changes, ride height, and droop), you'll notice the buggy has a lot more off-power steering.
Laterilus is offline   Reply With Quote
Old 03-12-2007, 07:50 AM   #2389
sport10's Avatar
Use maximum droop in the front. It helps eliminate push during offpower steering on a tight track.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 03-12-2007, 08:21 AM   #2390
RBMike's Avatar
On the warn chassis posted above, I have to agree with Aaron. I ran my Mugen chassis until you could shave with the rear edge and never noticed any difference at all in flex when I would finally replace it. I would bet if you take a caliper & measure the chassis thickness at the front of the rear diff case, it's the same as when new.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-12-2007, 08:24 AM   #2391
glassdoctor's Avatar
Stock setup to me doesn't push at all, on power... it's actually has too much on power steering. Off power steering isn't bad.... it pushes a little through the middle on some turns.
But in general my buddies and I think the stock setup needs tweaked for more off power and less on power...
glassdoctor is offline   Reply With Quote
Old 03-12-2007, 08:47 AM   #2392
I set it up as to Drakes Neo Buggy '06 setup sheet. Max droop in the front, a little less in the rear. I only get to drive on the weekends so Ill test more stuff out. I am changing to 5-5-2 (F-C-R) as the track is always rutted and loses quite a bit of traction in just 5-10 minutes as it dries out. Ill first test that, and go from there. I dont think it will be hard to dial out though, I do however want a compromise for high traction to very low traction. More so on the very low traction as I will already be in the "groove".
Old 03-12-2007, 09:32 AM   #2393
GTB_USER_Erik's Avatar
Originally Posted by Steve Walters
Speaking of Portland, I'm going to be there visiting family for a week. What shop's are the ones to check out? Whats the race seen there? I will be there the 13th threw the 20th, and I'm thinking of bringing my 8IGHT with me..
The only indoor track is in Milwaukie, At AmainRaceway & Hometown Hobbies
But this track is very small and too tight IMO for an 1/8 scale.
There is CNC Reaceway up the Highway in Woodland WA. But he has closed his track for a little while, while he does some repair work to it.
Hope your visit is a good one.....
GTB_USER_Erik is offline   Reply With Quote
Old 03-12-2007, 09:35 AM   #2394
Stewart Fan's Avatar
Eric you have a PM.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 03-12-2007, 09:47 AM   #2395
Originally Posted by Stewart Fan
Eric you have a PM.
Stewart You have mail
Old 03-12-2007, 09:49 AM   #2396
Stewart? wernt you a member of REDFROG RC Club?????
Old 03-12-2007, 09:51 AM   #2397
I ran at Red Frog a few times but not a member. I am one of the regulars at C-n-C's and I help Chris with the hobby shop on race days.
Old 03-12-2007, 10:19 AM   #2398
Steve Walters's Avatar
Thanks Erik, Looks like the buggy will stay at home for this visit. Plan "B" now, Salmon and Crabbing off the OR Coast...
Does Amain Raceway & Hometown Hobbies and a good selection of merchandise? Is it worth a trip to check out. No Sale tax and all...
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 03-12-2007, 11:27 AM   #2399
They have a fair selection of stuff. I personaly shop at 'Tammies Hobbies" in Beaverton, Huge selection
Hope this helps
Old 03-12-2007, 01:49 PM   #2400
ape_x's Avatar
Quick question:
I'm rebuilding my 8 buggy diffs and noticed a difference between the
8B and 8T instructions. should i get ahold of the small shims which
are a new addition to the 8T for my 8B diff rebuild?
ape_x is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
