Old 03-07-2007, 07:46 AM   #2326
Are you guys using the brass bushings inside the rubber grommets on your servos?
PAPA is offline   Reply With Quote
Old 03-07-2007, 08:37 AM   #2327
R40Victim's Avatar
I didn't, I wanted to minimize the transfer of vibration from the car to the servo.
R40Victim is offline   Reply With Quote
Old 03-07-2007, 09:02 AM   #2328
RBMike's Avatar
No gromet inserts here either. 6+ gallons, no servo issues.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-07-2007, 11:54 AM   #2329
Aaron Waldron's Avatar
Clean the shock shaft (inside the shaft where the screw goes!) and the screw really well with motor spray/contact cleaner. Use loctite and let it dry.
The original o-rings aren't too bad, but they can be a bit leaky. Losi is working on new o-rings. Until then, you can get different ones from Ultimate Products or TKO Competition Development and you only need to run one of them, and one stock o-ring. They have a little more stiction than the stock ones, but nothing you're likely to notice with a six pound buggy, haha. Once you run them once or twice, it's all good.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-07-2007, 03:48 PM   #2330
Originally Posted by JP4
I just unpacked my stuff from the Pro Series...I turned my car on and my Throttle servo seems to work fine...What the Heck !!! Over heated? I have to figure this out ....
JP
yeah this is what happened to me too, changed servo brand and havent had any problems since
rc007 is offline   Reply With Quote
Old 03-07-2007, 05:21 PM   #2331
sport10's Avatar
Servo brand has nothing to do with it. I think it is vibration that is causing the failures. So I suggest using either the rubber grommets or the o-ring idea. Maybe do both.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 03-07-2007, 07:44 PM   #2332
maxx90's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to maxx90
Default 8IGHT
HEY GUYS I HAVE READ THIS WHOLE THREAD AND I HAVE A COUPLE QUESTIONS. WITHOUT HAVING TO GO BACK TO LOOK THIS UP. I PLAN ON USING THE 8IGHT CLUTCH I HAVE CERAMIC BEARINGS AND PLAN ON GETTING KING HEADS SHOES. WHAT SHOES AND SPRINGS ARE THE BEST SETUP? THE OTHER QUESTION IS I BOUGHT A NOVAROSSI 3 PORT #N21B I HAVE A JP1 A JP2 A OFNA 086 A OS 2050 A NOVAROSSI 53 AND A NOVAROSSI 86 WHICH 1 DO YOU RECOMMEND? ALSO WHAT PLUG? I LIVE IN ARK AND IT GETS REALLY HOT AND HUMID IN THE SUMMER.THIS SETUP WILL BE RAN ON TRACKS WITH STAIGHTS NO LONGER THAN 120 FEET AND MEDIUM TRACTION. THIS 8IGHT IS BY FAR THE SWEETEST BUGGY I HAVE EVER OWNED YOU DON'T HAVE TO DRIVE IT HARD TO GO FAST. THNX M.W.
maxx90 is offline   Reply With Quote
Old 03-07-2007, 07:48 PM   #2333
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Glad I checked my throttle servo again. I had the EPA to high. At full throttle it was right at the maximum opening. If you pulled on the linkage it wouldn't move anymore. Backed it off a few percent and now I've got just a hair shy of a mm buffer in there.
XMSRacing is offline   Reply With Quote
Old 03-07-2007, 07:49 PM   #2334
Talking Hey guys
Hey guys I have a question I am new to buggy and I have the 8ight and I was wondering what tires do I run for what kind of track condions. I am going to be running proline tires always so out of there brand of 1/8 scale buggy tires what tires do I want to run on what kind of track condions. Thank you guys again. And this forum is awesome all you guys help me for sure.
losi8ight is offline   Reply With Quote
Old 03-07-2007, 07:49 PM   #2335
SupermaxxRich's Avatar
for the 3port engine I would use the Nova 083 pipe. King Headz 7075 shoes with 2 gold and 2 greeen springs. If you want more bottom end snap go all gold springs
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 03-07-2007, 07:56 PM   #2336
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
maxx90- i run the clutch setup supermaxxrich mentioned and it is very smooth and will most likely be the best choice. as for a plug... I am in louisiana and pretty much run a os8 or mc9. for the 3 port motor i would say go with the 53 at 1st with the track being as small as you mentioned, and if it is too snappy on bottom go to the 86.
losi8ight-i just tried out the combo truthe ran at the nitro challange and it worked very well! i would say just get a couple setf of bowties and crime fighters in m2 and you will have a good tire for just about everywhere.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-07-2007, 10:29 PM   #2337
hey guys,
noob question. i put on the crank shaft screw and now the clutch bell does not rotate freely??? what am i doing wrong.
steveatcal is offline   Reply With Quote
Old 03-07-2007, 10:37 PM   #2338
Originally Posted by steveatcal
hey guys,
are you using the washer they supply that has the extra step on it?
Old 03-07-2007, 10:38 PM   #2339
yea im using that washer and the shim before it
Old 03-07-2007, 10:56 PM   #2340
what shim?
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
