Old 03-05-2007, 07:16 PM   #2296
Aaron Waldron's Avatar
I suppose there are different theories, but I believe that digital servos are more likely to fry than analogs when subjected to conditions like incorrect EPA's or added stress.
Dale - Probably not? But it might be one spacer behind, and two in front, versus "all the way back" being that the spacers are all in the front.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-05-2007, 10:02 PM   #2297
Talking servo question
I have the losi 8ight buggy and I had a nother throttle servo go out on me, it is my 5th one. This is what I did so far to see if I could fix the problems, I cut the ball cup, put kingheadz radio tray stiffiner on, alluminum chassis braces, set the epa correct for sure, I had somebody that has been racing for 14 years help so he knew what he was doing, He also run's the 8ight buggy. Ok I have been running cheap servos like z590- z270's just so if they blow I would not be out a lot of money. So my question is do you think those servos I am using are to weak for my throttle and it is just putting to much stress on the servo. So what I am thinking maybe I should put like a high torque servo in there like the airtronics blue or the jr9000t. So my questions is what do you think I should do becasue I am sick of burning up servos, and sick of worring about the throttle servo going out when ever I go out to race. So if you could help me out I would really appriciate it alot. Thank you very much.
losi8ight is offline   Reply With Quote
Old 03-05-2007, 10:10 PM   #2298
Originally Posted by losi8ight
Ok I have been running cheap servos like z590- z270's.
There's your problem. The price of those servos is appealing, but they are not really meant to with-stand the vibration/impact that these buggies endure.
I have been using a JR 8800s for throttle and haven't had it go out yet. I've got about 4 gallons on my 8ight.
rwlkr is offline   Reply With Quote
Old 03-05-2007, 10:15 PM   #2299
I don't think that the servo failures are caused by flex, not one bit. The radio tray stiffener, the chassis braces, none of that is going to help.
Make sure your servo is spaced up of the chassis considerably (the stock spacers are probably not enough).
Use a 1/2 inch screw as the one that will thread into the bottom of the battery box. Put two of the 1/10th scale size shock o-rings on the screw, in between the chassis and battery box. Only thread the screw in as far as the screw will be flush with the boss inside the battery box. This will help cushion the radio tray from vibration.
This is what I've been doing to my cars since my first, and only, throttle servo failure. I've driven gallons since.
www.liverc.com
Old 03-05-2007, 10:50 PM   #2300
R40Victim's Avatar
Yup, the spacers help alot, and I've had my Z590 for several months now, no failures. You don't need an expensive servo to solve the problem.
R40Victim is offline   Reply With Quote
Old 03-05-2007, 10:55 PM   #2301
Well when the LST and Mayhem came out a few years ago, people were blowing those same servos. Horizon Hobby said that they had a bad batch go out and have since fixed them. Makes you wonder if they are just a cheap Servo? Still...
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 03-05-2007, 11:10 PM   #2302
R40 - I think that spacing the servo properly off of the radio tray is the most important part of keeping the servos alive. Glad to hear it's working well for you.
MonkeyWrench - I can't imagine trying to engineer a servo to handle the duty of what we ask them to do in an R/C car, especially an 1/8th scale buggy!
www.liverc.com
Old 03-05-2007, 11:50 PM   #2303
I just found out tonight that it sounds like Losi is planning on changing the outer rear hinge pins that seem to have been a problem.
www.liverc.com
Old 03-06-2007, 12:50 AM   #2304
GTB_USER_Erik's Avatar
To what end are they changing the design?
GTB_USER_Erik is offline   Reply With Quote
Old 03-06-2007, 01:34 AM   #2305
I don't know, I'm not sure if they've decided on a course of action yet. But I understand that they're exploring a change to help improve durability.
www.liverc.com
Old 03-06-2007, 04:55 AM   #2306
Turbine_au's Avatar
Aaron, just to clarify something regarding the 1/10th o-rings in the battery box. Are you referring to step F-08 in the manual? If so, all four screws need to o-ringed or just the two closest to the throttle servo?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 03-06-2007, 06:49 AM   #2307
JP4
Default Throttle Servo "OUT"
My 1st big race...Pro Series @ Badlands....I made the A-Main in Inter. 1/8 buggy ....I was in 3rd half way through 30 minute main....I was running really strong and consistant...when suddenly the Throttle servo stoped working..I'm done with Hi-tec servos...but I have other guys that have had the airtronics and futaba servos go out to....I know the EPA and the ball cap etc...are right... I had to share this with you guys....
And the guys @ Badlands III really put on a great show....The track is awsome ....if you can make the Trip to that track its worth it!
JP
JP4 is offline   Reply With Quote
Old 03-06-2007, 07:42 AM   #2308
Default so
So do you guys mean like put shock o-rings under the radio tray? Does anybody have a picture we can refer to if so that would be great.
Old 03-06-2007, 08:10 AM   #2309
RBMike's Avatar
Thanks again Aaron
Mike
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 03-06-2007, 08:54 AM   #2310
J.Wright's Avatar
I am not sure what has been said about the O-rings on this board however I spoke with the Drake last Saturday and he told me to put 4 O-rings 1 under each screw that attach the throttle servo to the radio tray there by isolating the servo from some of the chassis flex so far I have not had another failure since doing this. Good luck
Jim
J.Wright is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
