Old 03-04-2007, 07:28 PM   #2266
GTB_USER_Erik's Avatar
By 3 laps
Now who could argue with that logic
GTB_USER_Erik is offline   Reply With Quote
Old 03-04-2007, 07:46 PM   #2267
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Well, I put one oring in below the battery box 'cause I dont have a 1/2 inch screw. The servos are still quite a bit off the chassis from the shim, spacer and rubber gromet I have had in. The tray does not flex at all at full throttle or brakes, but it seems like the spring is just to strong. I cut the ballcup and cut a link off of the spring, but now its just altering how much angle the servo horn has to push the carb closed. When closed though, the spring could be compressed about 3mm more (full brake) BUT the servo is buzzing quite a bit. Most likely the spring is just to hard. Ill just try to find a different spring. Thanks for the help so far. Till next weekend (or if the parts come before then)...
rezenclowd3 is offline   Reply With Quote
Old 03-04-2007, 07:49 PM   #2268
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
the servo is going to buzz when you are on the brakes, just make shure you aren't getting coil bind and you should be fine as long as everything else is setup correctly.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-04-2007, 08:48 PM   #2269
^^^ Well I wasn't getting coil bind when the two servos died... I hope its just a fluke.
Old 03-05-2007, 12:10 AM   #2270
Trader Rating: 18 (100%+)
Send a message via AIM to scr_achy Send a message via Yahoo to scr_achy
can someone post a pic of how they have these o-rings installed on the servo and battery box.
Thanks!
I just ordered a maxamps.com 1290 mah lipo receiver pack. It should fit i think lol..
got my servos, just waiting for my darn motor to arrive lol.
Founder- RcBros.com
It's all about the fun!
Toys: MF2,E X1-CR, 8ight, LCC, MRC, Axial, T209, Baja 5B
scr_achy is offline   Reply With Quote
Old 03-05-2007, 01:11 AM   #2271
Aaron Waldron's Avatar
I don't have a picture, but it's really as easy as it sounds. Put the screw through the chassis, put the o-rings on the screw, and thread it into the battery box.
rezenclowd - Are you using a digital servo for throttle?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-05-2007, 04:33 AM   #2272
robsxxxs
i have had better luck with shoe goo than with ca. i dremeled the tank and the clip slightly. ca would pop loose after 3 or 4 races for me even when i dremeled it.
T Green is offline   Reply With Quote
Old 03-05-2007, 08:33 AM   #2273
Aaron: No I am not using a digital servo on either end. I am using the 94358s on both ends. I am sending them in Wed to get fixed, so ill post the report here once they are back.
Old 03-05-2007, 09:21 AM   #2274
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Does anyone use the active braking systems on their controllers for their 8ights to create an "ABS" effect?
I'm wondering if using that function would create servo issues with the constant cycling while on the brakes.
XMSRacing is offline   Reply With Quote
Old 03-05-2007, 09:25 AM   #2275
i use my finger as a abs brake. i never just slam on the brakes. i pump them, I find i have more control over the way the car acts that way.
Rob Jensen
Old 03-05-2007, 09:35 AM   #2276
Davidka's Avatar
Trader Rating: 75 (100%+)
You only want to use ABS functions on your transmitter with electronic speed controls. I hear it hurts servos.
I have been thinking of modifying my radio by putting a piece of fuel tubing behind the brake trigger to make the spring much stiffer for brakes. I think it woudl give the brakes more "feel".
Old 03-05-2007, 09:57 AM   #2277
Kcdzim's Avatar
Send a message via AIM to Kcdzim
Although I'm fairly new to all this and could easily be wrong, I'm thinking an anti lock brake might not be beneficial while trying to correct mid air attitude in a jump where you need a quick response on the brake to nose down.
Losi 8ight 2.0 Associated SC10 Associated RC10T Xray T3 2011
Corally RDXΦPhi Vintage Transam
Professor Z Graphics
Kcdzim is offline   Reply With Quote
Old 03-05-2007, 10:11 AM   #2278
XMSRacing's Avatar
It would stop the wheels mid air just as fast.
I was more worried about long term effects on the servo.
Old 03-05-2007, 10:54 AM   #2279
jkirkwood's Avatar
Originally Posted by cwalters
So what are some of the steps that are first being taken to get rid of the traction rolling?
If you are using tires with a square lug on the outside roll you can cut them at 45 deg angles to help them not bite as hard. You can also limited the rear droop, try a lower rear camber link position, lower the ride height. If none of that works and it's rolling really bad all over the track then stiffen the car up.
If it's just one or two corners I would weigh the need to fix the traction roll in one corner vs changing my setup much that will effect the car for the entire rest of the track if I was happy with it. In the corner that the traction roll occurs I would find another line or adjust the approach.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 03-05-2007, 11:03 AM   #2280
RBMike's Avatar
For you guys talking about the radio's ABS, It does run the RX batteries down faster due to the pulsing.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
