Old 10-03-2006, 09:50 PM   #211
At tonights race in the expert buggy class every buggy but one was a losi.
I raced mine tonight, i think losi did an alsome job i love it so far.
And parts are so cheap!
scotty5555 is offline   Reply With Quote
Old 10-03-2006, 09:58 PM   #212
Oh ya,
as for the clutch, i think it the alu. shoes hit at the wrong time for our track. Im running the Losi collet with a Xray flywheel, Mugen carbon clutch shoes and the stock Losi chutch bell.
I think it works alsome
Old 10-04-2006, 05:30 AM   #213
Originally Posted by rdeppen
"copied from Tech Talk"
Front:
2 degrees of toe-out
27mm ride height
-1 camber
stock castor
2.3 sway bar
54 pistons, 40wt oil
4.4lbs springs (same as what the kit recommends)
I set my droop by measuring the shocks when they are on the buggy. 3.680 from center to center.
long steering ackerman
bump steer washer down
#2 camber link
#2 - inside shock location
5000 diff fluid
Trinity 1400 mah battery
7000 center diff fluid
Rear:
3 degree of toe-in
3 degrees of anti squat
29mm ride height
-2 camber
hubs back
2.3 sway bar
55 pistons, 35wt oil.
3.1lbs (same as what the kit recommends)
I set my droop by measuring the shocks when they are on the buggy. 4.175 from center to center.
4-A camber link
#2- inside shock location
2000 diff fluid
Clutch:
2 alum with 1.0 / 30 degree springs
2 plastic with 1.0 / 25 degree springs
13/ 48 gearing
Always been a Mugen guy but reading this post i'm kinda swayed to jump ship... how's the car holding up? been on the deciding factor since Mugen just release the MBX5R. I'm looking to get a new buggy by Chistmas so looking on which one to own now.
By the way, i notice the setup sheet dif config are usually R-2k C-7K F-5K that's pretty much what i ran my MBX5 but i had my center dif pump up to 10K all the while and no one else seems to do that here. Can any 8ight owner cmments on how it holds up on 10k center dif oil? especiall on rough tracks and jumps.
stonely0 is offline   Reply With Quote
Old 10-04-2006, 08:53 AM   #214
speedy2's Avatar
I wonder about the little clutch bearings into the diff supports
should need some more maintainance with those front driveshafts
wobbling in them....
speedy2 is offline   Reply With Quote
Old 10-04-2006, 11:17 AM   #215
rdeppen's Avatar
Stonely so far the car is holding up real good. I have about 1 and 1/2 hours on it and the only thing that is wore out so far is the stock clutch. Word is Losi has new material for theboth the carbon and aluminum shoes coming real soon. Not soon enough for some of us though as out stock clutches are smoked.
Can't say on the 10k diff fluid myself as I'm just starting to make fluid changes from the above posted setup to see what effect they have. When I ran Mugen I used 7k fr 10k cen and 3k rear. Worked great for me but others didn't like it. I don't think that will work in the Losi since most of us are having trouble with the assend being loose. I just did a diff rebuild and went to 5k fr 5k cen 3k rr. I'll see how that works this weekend. Oh and I'm still trying to get my Jammin clutch to work as well LOL
rdeppen is offline   Reply With Quote
Old 10-04-2006, 11:42 AM   #216
Aaron Waldron's Avatar
Pretty sweet, huh?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-04-2006, 11:44 AM   #217
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
looks like you cut the "step" off of the step pins.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 10-04-2006, 11:47 AM   #218
S Bowen's Avatar
Trader Rating: 57 (100%+)
Aaron that looks sweettttttttt
FACTORY TRACKS RACING, NANKIN HOBBIES, LUNSFORD, JCONCEPTS, KOLOR KONCEPTS
S Bowen is offline   Reply With Quote
Old 10-04-2006, 12:03 PM   #219
micro - Nah, just ran the tires to death and then cleaned 'em up with Simple Green for a Kodak moment.
Bowen - The stuff is incredible. Tough as nails, and the stickers help hold the body together so it lasts longer. No worry about fuel messing up your decals, and no waiting WEEKS for a painter to give you a custom scheme.
Custom artwork, affordable and durable graphics, quick turn-around times, and awesome customer service.
http://www.panthermotorsportsdesign.com/rcindex.html
www.liverc.com
Old 10-04-2006, 12:19 PM   #220
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Aaron, That is bad ass!.... I think I'm done painting bodies!
SCUBA STEVE is offline   Reply With Quote
Old 10-04-2006, 01:06 PM   #221
I'm done sending them away to wait to get painted! A quick "psh psh" with a rattle can, wait for the paint to dry, and the stickers take about 15 minutes to apply. Then it's done! Totally factory looking, clean, and professional.
www.liverc.com
Old 10-04-2006, 01:27 PM   #222
R40Victim's Avatar
Are the decals on the inside or outside of the body? I've been using vinyl graphics, done in reverse, and applied to the inside before painting. They've proven alot more durable than the typical exterior decals.
R40Victim is offline   Reply With Quote
Old 10-04-2006, 04:29 PM   #223
localbuzz's Avatar
Send a message via MSN to localbuzz
Default My 8ight
I bought my 8ight Monday and I just finished it. This is the first RC car kit I have built. I have to say that the instructions were very good and the car went together very easily. I am going to run it with a Sportwerks .21 V2, 14T and JP1 manifold and pipe. Eventually I will upgrade to something better, probably a Trinity. I have not had a chance to run it yet. I am having the starter box issues that so many of you have described in this thread. I am going to work on that issue tonight. Probably chamfer the wheel of the box and also the hole on the chassis. All the tracks here are indoor, hard packed clay. They had the Regional ROAR racings this past weekend here and there were 2 8ights in the Amain. Both seem to handle the track well. The indoor tracks here can become slick after a couple of races. I can't wait to try it out this weekend at the track.
Here are a couple of picks of my 8ight. I am not really into the fancy paint jobs.
Losi 8ight building and setup-losieight_009.jpg   Losi 8ight building and setup-losieight_010.jpg   Losi 8ight building and setup-losieight_006.jpg
localbuzz is offline   Reply With Quote
Old 10-04-2006, 11:40 PM   #224
R40victim - They are external stickers. PMD does vinyl body wraps for full size race cars, so the beating these graphics will recieve from a little toy car shouldn't even phase them! The material is super strong and sticky, without being too thick or heavy.
localbuzz - Try using a file to make your starter box wheel thinner; just push down on the box to spin the wheel and hold the file in place to make the rubber wheel skinnier. Other than that, it's important that your chassis is lined up well on the box, and you shouldn't have much of a problem.
www.liverc.com
Old 10-05-2006, 12:43 AM   #225
JBRacing's Avatar
As I understood the clutch wears very quickly.
I'm considering buying the Forini Turbo clutch. Which flywheel will fit the Losi? The one that fits the MBX or the one for the SP2.
JBRacing is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
