Old 02-27-2007, 10:45 AM   #2161
Aaron Waldron's Avatar
Losi's setup sheets include droop measurements that are derived from putting the chassis on blocks and then measuring from shock mount to shock mount, using the middle of the screw on both the arm and the shock tower as your reference points.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 02-27-2007, 11:02 AM   #2162
I just got finished with my 8 and now am ready to purchase the engine / pipe...
I was thinking about the Picco P7R....
Can you guys tell me what the difference is between these two engines and which one I should get???
http://www2.towerhobbies.com/cgi-bi...p?&I=LXJRX0&P=0
This one is listed as .21 Picco O-1BP What does the O-1BP mean???
http://www2.towerhobbies.com/cgi-bi...p?&I=LXPUZ3&P=0
Also, what pipe would you guys run????? The local track is medium size and alot of turns...
The second engine you listed there as 0-1BP is the newer version of the first one you listed. Its called the EVO2, im not sure what the differences between the two. For a pipe, i would run a JP-3 with it.
LuckySleven is offline   Reply With Quote
Old 02-27-2007, 03:12 PM   #2163
I'll be at the Porter, TX race at Mike's. I'm only about 30 min away from it.
I'm hearing that they are expecting 200-250 entries. That seems like WAY too much action for me so i think I might just go out there on Friday for practice and see how nuts it's gonna be.
JustinWZP is offline   Reply With Quote
Old 02-27-2007, 05:38 PM   #2164
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
they have already filled up all the spots for the race at mikes. 200 entries.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 02-27-2007, 08:38 PM   #2165
Mcfly's Avatar
just got my losi 8 pro and looking for lipo rx battery, what is there available in around 1500ma with balance charge conectors, ive checked out the htbatteries.com and look good but a little pricey
Mcfly is offline   Reply With Quote
Old 02-27-2007, 09:44 PM   #2166
sport10's Avatar
Originally Posted by losi8ight
I am going to try this first
Front = Go to stiffer shock spring, stiffer sway bar, heavier diff fluid. Change toe out towards zero. Raise the ride height of the front. Decrease Steering. Go to lower traction tire. Increase front droop. These things tone down "Steering" Traction
The one thing that was not brought up was to decrease the droop of the rear shocks. This will lower the amount of weight that gets shifted on the front of the buggy when braking. I would just setup the car with the Adam Drake THE DIRT setup and go from there.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 02-27-2007, 09:47 PM   #2167
Default so does
So does decrease the droop me loosen or tighten the droop set screw.
losi8ight is offline   Reply With Quote
Old 02-27-2007, 09:56 PM   #2168
sport10's Avatar
Decrease means to tighten (clockwise). The droop adjustment screw just is a adjustable bumpstop. You need to make the screw protrude further out the bottom of the arm to decrease the droop (less travel).
Associated B44
Associated B6
Old 02-27-2007, 11:42 PM   #2169
Default Thank you
Thank you Sport10. I will try that first and then go from there.
Old 02-27-2007, 11:45 PM   #2170
vikingen's Avatar
Trader Rating: 27 (100%+)
My 8ight.. hopefully it stops raining here in sydney so I can race this weekend.. will only be my 2nd proper actual meet running it
my ko throttle servo.. no issues so far
(edited.. looks much better now)
vikingen is offline   Reply With Quote
Old 02-28-2007, 12:02 AM   #2171
SupermaxxRich's Avatar
the spring on your throttle looks like its about to bind. I bet its pretty close to binding if not binding when you put the brakes on. I'd cut the ball cup down 3-4mm at least. Maybe even shorten the spring.....
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 02-28-2007, 01:36 AM   #2172
Yes,
You do not have the updated ball cup. CUT the ball cup end to keep binding!!!!
kyracer is offline   Reply With Quote
Old 02-28-2007, 01:59 AM   #2173
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
That would have been another throttle servo story for sure. Good catch SuperMaxx.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 02-28-2007, 02:11 AM   #2174
vikingen's Avatar
just shortened the spring. definately no bind now. thanks
Old 02-28-2007, 05:13 AM   #2175
And maybe I just have bad luck, but my very first run with my 8ight with the personal transponder mounted to the top of the radio tray I took I hit on the side that broke one of the transponder mounting ears off.
I then noticed that Rich had his PT mounted to the bottom of the radio tray using those exact same holes. It's MUCH more protected down there. I highly recommend it (and thank Rich for the idea).
Mounted on top, the PT extends over the side of the radio tray and can pretty easily take a direct hit with nothing but the flimsy body to protect it, but mounted to the bottom it's protected by the chassis mud guards and close proximity to the chassis.
SpeedPassion, SpeedPower, ProLine Racing
Losi 8ight, Losi SCTE, AE SC10, AE RC10T4, Kyosho IGT
Walt is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
