Old 10-03-2006, 07:10 AM   #196
I was thinking the same thing about the center diff. Has anyone tried going to 5 in the center?
*Topher* is offline   Reply With Quote
Old 10-03-2006, 08:15 AM   #197
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
rdeppen, A 13t clutch bell will give you more punch and may cause more of a problem... My 8 actually pushed on a dry track ..... I was running M2 crimefighters and switched to GRP Jolly soft still with the stock set-up and it was alot better ..... but that was just a quick fix and we are all running on different surfaces.....
SCUBA STEVE is offline   Reply With Quote
Old 10-03-2006, 08:25 AM   #198
rdeppen's Avatar
LOL Yeah Steve I just figured out that my math was backasswards. Gonna try 5000k in the center this weekend
rdeppen is offline   Reply With Quote
Old 10-03-2006, 08:35 AM   #199
...I know the feeling!... I do it all the time!......The thinner diff fluid will probably do the trick.... but even staying with what you have and changing it may also help, That first diff fluid change (I Think) makes a big difference.... you'll notice the fluid will look like a metallic paint from all the gears breaking in! ... but either way I'm sure you'll be in good shape
Old 10-03-2006, 08:51 AM   #200
speedy2's Avatar
5000 in the center will it drive more easy and forgiving especialy in the rough
speedy2 is offline   Reply With Quote
Old 10-03-2006, 10:00 AM   #201
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i put 5 in the center when i built the buggy. and this is what i found.
when the track was we i had traction everywhere. The car would rotate quickley and the rear end staied planted. had a Ton of acceleration and it went threw the rought stuff like butter. however when the track started to dry out the rear end started to swing arround.
im going to try going up on the rear diff fluid and see whae that does. i will let yall know what happens.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 10-03-2006, 10:06 AM   #202
Davidka's Avatar
Trader Rating: 75 (100%+)
What rear link position are you running?
Old 10-03-2006, 10:32 AM   #203
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up Dry slick tracks....
We drive on a dry slick track that has alot of elevation change and blown out sections. The stock setup was OK. However I changed to an old setup to get the car more locked in and consistant. I went with 3-5-3 setup and shortened the wheel base by 1/8th. WOW! The car absolutly flies now and is so easy to drive. The rear stays planted even when I use less tire than what was previously desirable.
With sandy dust on top, the rear is planted with this set up. I'm finding small adjustments can really be felt if you take the time to try them.
I'm running the inner hole on the rear upright. This helps it have good rotation.
Racing tonight. I'll let you guys know once I have had it on the clock.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 10-03-2006, 10:44 AM   #204
im running the same link set up as the drake dirt setup
Rob Jensen
Old 10-03-2006, 11:58 AM   #205
JBRacing's Avatar
What would you say about the micro SR3500 DSM receiver for the 8ight?
I wish to install a telemetry system in the buggy and it does not fit together with the regular DSM receiver in the receiver spot.
JBRacing is offline   Reply With Quote
Old 10-03-2006, 12:19 PM   #206
The micro Spektrum rx will not work with the telemetry system.
gasser is offline   Reply With Quote
Old 10-03-2006, 12:23 PM   #207
Also we found 5,5,3 in the diffs and the heavier front sway bar kept the car from getting up on the front soo much and really locked in the rear end.
Old 10-03-2006, 12:23 PM   #208
jimbal's Avatar
Default My 8
I am still having issues in posting pictures in the text area. See attachments.
jimbal is offline   Reply With Quote
Old 10-03-2006, 02:14 PM   #209
The Evicerator
I see you Scuba Steve... I see you!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-03-2006, 04:23 PM   #210
Evicerator do I know you?
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
