Old 02-20-2007, 09:31 AM   #2011
sport10's Avatar
Originally Posted by losi8ight
Ok thanks man. Here is a picture from a diffrent forum on what a guy did for his chassis to fit on the starter box. I might just do this it looks easier and I do not have to screw with the wheel.
Tell me what you think I should do.
Using a file to file down the drive wheel on the starter would be easier IMO. Just press the file against the starter wheel while it is spinning till it is the correct thickness. Easy as pie or should I say cookies.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 02-20-2007, 09:34 AM   #2012
robsxxxs's Avatar
i have a question about clutch bearings. is it just the big bearing that always goes or is it both the big and small bearings? and one last question what are the sizes of the bearings?
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
robsxxxs is offline   Reply With Quote
Old 02-20-2007, 09:41 AM   #2013
sport10's Avatar
Losi sells them cheaply as a set. losipartshouse is a great place to get them.
Associated B44
Associated B6
Old 02-20-2007, 10:09 AM   #2014
the outer is a standard 5mm x 10mm and the inner is 5mm x 13mm. you can get them here for $2.
http://www.bluegrasshobbies.com/bg/c...roducts_id=483
xxxtracer is offline   Reply With Quote
Old 02-20-2007, 10:44 AM   #2015
dirtracer1's Avatar
you can also get avid bearings at..........avid.
http://www.avidrc.com/?action=category&id=1
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 02-20-2007, 11:20 AM   #2016
trebor's Avatar
are ceramic bearings really worth the money?
trebor is offline   Reply With Quote
Old 02-20-2007, 11:46 AM   #2017
weliin's Avatar
If you got the money to blow then go for but you don't need them to win.
weliin is offline   Reply With Quote
Old 02-20-2007, 11:55 AM   #2018
trebor's Avatar
so id be wasting my money in other words. thanks for the honesty.
Old 02-20-2007, 01:11 PM   #2019
I've got 3 gallons so far on one set of ceramic bearings from TKO. At $4.95 for each bearing I think they're worth it. I have not run the stock Losi clutch bearings so I don't really have a comparison.
slow is offline   Reply With Quote
Old 02-20-2007, 04:11 PM   #2020
Talking Well
Well I got this motor today
And man it is very nice I am running it with a sportwerks 053 hard anodized pipe. I did 5 tanks of ideling. I had to do the ideling method because I do not have the front hubs or cvds on so I could not putt it around. On the third and 4th tank I sarted to rev it a little more and then on the fifth tank I reved it even a little more. On all the tanks it stayed around 180-200 degrese so I am good. What I did notice was this black looking stuff that came out of the pipe. I made sure it was not metal shavings, it was more like dirt looking but it was not dirt. Would anybody know what this is. Thanks guys.
losi8ight is offline   Reply With Quote
Old 02-20-2007, 05:01 PM   #2021
180-200 degrees?!!!! You're destroying that motor! That's too cold. 210-230 is where you should be. That poor connecting rod...
satoch is offline   Reply With Quote
Old 02-20-2007, 05:06 PM   #2022
Default During
During break in???? 210-230 man every where I read it is keep it at the 200 mark or a little below. I have done this break in method with 3 other motors and they run strong and last along time. So 180-200 is a good temperature. Plus where I live it was 70 degrese out today and humid so that is why i kept it at 180-200 degrese. I am not killing my motor I know what I am doing, All the guys at my lhs do this same method to there motors and there motors run strong.
Old 02-20-2007, 05:09 PM   #2023
Rob Phillips's Avatar
Breaking in an engine without it being under a load will cause excessive wear (I know, this can be debated). I hope you're just refering to the oil being dark that is coming from you pipe, it should be some what darker, but not black. Too much fiction, especially on aluminum parts, without proper lubrication will cause the parts to wear much quicker which is evident by the darker oil.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 02-20-2007, 05:12 PM   #2024
for some reason after looking at this pic I have the sudden erge to eat some "cookie crisp"
Old 02-20-2007, 06:25 PM   #2025
Default to tape or not to tape, that is the question...
On my monster truck, I tape the tires with duct tape or packing fiber tape. I have never had buggy tires before... Do you tape them also?? These tires have ribs on the inside, does that affect anything?
baker745 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
