Old 02-18-2007, 10:49 PM   #1981
SupermaxxRich's Avatar
Originally Posted by JWRockman
I have a couple of questions about building the shocks.
1. How tight should the pistion fit inside the shock body. The piston seems to be tight against the inside wall of the shock body. Should I smooth down the piston more to make it looser?
2. When threading on the bottom shock caps where the rubber seals are will hand tight be enough? I tried to use pliers while covering the cap before putting the pliers on and it scratched the cap. Is there another way? I did put on some blue locktite on the threads.
Thanks.
Rockman
hand tighten is all that needed bud. Haven't had one back off yet in 3 gallons of fuel
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 02-18-2007, 11:03 PM   #1982
R40Victim's Avatar
Hey guys I am looking for a new motor for my 8ight and my limit is $200.00 dollars and I was wondering if this is a good motor and if anybody can tell me if it is worth buying. Now I know it is a Italian made motor so I know it will be good.
I too have this motor, runs very well on a JP-2 pipe. It's supprisingly powerful for a 3-port, and very efficient. I managed a 14 minute run with it!(I wouldn't have believed it myself had I not timed it). It's been a great motor, very few flameouts(plugs going bad, fuel line pinched, never the motor's fault), I'd highly recommend it.
R40Victim is offline   Reply With Quote
Old 02-19-2007, 04:47 AM   #1983
Hand tight is probably fine, but watch out if you try to do a quick ride-height adjustment by turning the preload collars on the shocks... you might unscrew the shock cap when you think you're turning the collars (happened to me once).
And instead of grabbing the caps with a pair of pliers, just run a small screwdriver or allen driver through the shock mount eyelet on the top of the cap to turn it. Losi put a hex shape at the bottom of the shock body, so you can grab there with a wrench while doing this.
SpeedPassion, SpeedPower, ProLine Racing
Losi 8ight, Losi SCTE, AE SC10, AE RC10T4, Kyosho IGT
Walt is offline   Reply With Quote
Old 02-19-2007, 04:53 AM   #1984
losi8ight
i ran that engine last summer, i loved it. lots of torque. i ran an 053 on it and o99 plugs. if you are running on a big track it will run out of leg on the straight a little but as long as its not a 170' straight you will be fine. i am going to order another one for this summer.
1 thing thats i was told by jim hott. from fusion, take the "brass boost port plug" out of the block and jb weld it in so that you dont have it come out on you. thats how i lost my bf, lost the brass plug and sucked in dirt.
xxxtracer is offline   Reply With Quote
Old 02-19-2007, 06:21 AM   #1985
JWRockman's Avatar
Default How tight should the piston be against the inner shock body wall?
My pistons seem to be very tight against the inside wall of the shock body. Is this normal? Should I sand them some? I suppose it will be smoother over time.
JWRockman is offline   Reply With Quote
Old 02-19-2007, 08:47 AM   #1986
R40Victim's Avatar
The kit comes with two shock tools, one for the top as well so you don't have to scratch the shock cap. Its the other tool with the slot in it. Stick the shock mount in the slot and turn...no plyers needed.
Old 02-19-2007, 09:20 AM   #1987
trebor's Avatar
Default SILICONE?
HELLO ALL, I HAVE A RTR AND I NOTICED I HAVE GREASE IN THE DIFF, SHOULD I PUT SILICONE? AND IF SO WHICH WEIGHT IN WHICH ONES?
trebor is offline   Reply With Quote
Old 02-19-2007, 09:21 AM   #1988
+1. With my cap tightened down with the plastic tools there is no way the cap is coming undone when adjusting ride height!
Old 02-19-2007, 09:22 AM   #1989
pistons shouldn't be tight at all in the shock body. Make sure there is no plastic hanging off the piston from the parts tree it was on.
Old 02-19-2007, 09:42 AM   #1990
weliin's Avatar
The .21 BF is a great motor and mine really woke up when I changed from a dynamite to JP-2 pipe.
weliin is offline   Reply With Quote
Old 02-19-2007, 10:00 AM   #1991
R40Victim's Avatar
Try the kit's diff lubes first, it's a good starting point. Also, make sure you stick to one brand of diff oil, so the comparitve viscocity is linear...translation, 1000 wt oil may be different from brand to brand(or so I'm told). Just get 5K for the front, 7k for the middle, and 2k for the rear. That'll be a good starting point.
Old 02-19-2007, 10:09 AM   #1992
Yes, I've been running Mugen oils and they seem to be slightly thicker than the Losi oil. Having said that we should be seeing Losi diff oils anytime now
Old 02-19-2007, 11:46 AM   #1993
weliin's Avatar
Well the cars been out since Oct and still no diff fluids. I'll believe it when I see it.
Let's get it right.. Release the car AND it's supporting products OR at least tell us which other manufactures oils are the closest match. It's really a shot in the dark on which oils to use to get out of the box matching performance which we tuned the setups around in the first place.
Old 02-19-2007, 12:23 PM   #1994
Billy's Avatar
Default Droop
J. Wright: Post # 1963 and #1965 (nice picture) on how to measure Droop. You will need a digital caliper to measure it. You are correct. 95mm in the front 106mm in the rear. Hope this helps.
Billy is offline   Reply With Quote
Old 02-19-2007, 12:33 PM   #1995
Send a message via AIM to L2-ProRacer
Mugen, Kyosho and GS are all exact C.P.S. differential and shock oil. I would reccomend running one of these so you know your oils are exact.
I ran 5-6-2 this weekend and it felt great! The car was very positive and pulled of corners very well. I'm going to try 5-5-2 this weekend.
L2-ProRacer is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
