Old 02-14-2007, 07:53 PM   #1876
Is the car still killing servos? And does have a brand it killls more than others?
Dave.H is offline   Reply With Quote
Old 02-14-2007, 08:31 PM   #1877
SupermaxxRich's Avatar
the car never killed servo's, the users setting up there cars killed the servo's
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 02-14-2007, 08:43 PM   #1878
Thats what I wanted to hear thanks SupermaxxRich.
Old 02-14-2007, 08:53 PM   #1879
no problem bud.
Old 02-14-2007, 09:27 PM   #1880
MercyRev's Avatar
Trader Rating: 54 (100%+)
I use the first one. It's just to get you close. If you want to be exact, you need to put it on a setup station. But, for quick reference, with the wheels on, use the RPM. Make sure that you are on a flat surface when checking it and actually drop the buggy from about 10-12 inches to let is settle the suspension with some fuel/battery in it.
MercyRev is offline   Reply With Quote
Old 02-14-2007, 10:42 PM   #1881
Default Thanks
Thanks mercyrev again I will go ahead and order that one. So that one that you recomended does have numbers on it so I can tell and turn my camber linkage the way it needs to go.
JOSH K is offline   Reply With Quote
Old 02-15-2007, 06:55 AM   #1882
bloodrush's Avatar
Default which one
which one would you recommened
1/
STS D21T .21 Team Modify Engine 120
2/
OS MAX 21 VZB VSPEC 137
3/
Nosram RS.21 135
and any ideas on pipes for the winning mill?
bloodrush is offline   Reply With Quote
Old 02-15-2007, 08:04 AM   #1883
FastFat's Avatar
Send a message via MSN to FastFat
Is there a difference between the Pro kit chassis and the RTR Chassis?
FastFat is offline   Reply With Quote
Old 02-15-2007, 08:09 AM   #1884
1/
2/
3/
Nosram RS.21 135
OS VSpec with OS 2050 pipe.
Old 02-15-2007, 08:16 AM   #1885
Talking
Yeah there is but not much at all. They are both 4mm thick but the kit chassis is 7075 alluminum and hard anodized and the rtr chassis is 6061 and just alluminum not hard anodized. But they are saying people are buying the rtr chassis and putting all the kit stuff on it becasue the rtr chassis seems to have more tracktion.
Old 02-15-2007, 08:37 AM   #1886
FastFat's Avatar
Thanks Josh!
Old 02-15-2007, 09:36 AM   #1887
Default slight steering bind...
I have just finished putting my kit together and, without the steering servo attached, it seems a bit stiff and a slight bind at center. Has anyone else experienced that?
baker745 is offline   Reply With Quote
Old 02-15-2007, 10:01 AM   #1888
mine will move by blowing on it without the servo attached. Make sure all your bearings are seated in 100% of the way.
Old 02-15-2007, 10:05 AM   #1889
Gordkoff's Avatar
1/
2/
3/
Nosram RS.21 135
OS V-Spec with JP3... Rich nows what it does.. i have both the OS pipe and JP3... OS is collecting dust...
Cheers
Gord
www.bilsteincanada.com
Gordkoff is offline   Reply With Quote
Old 02-15-2007, 10:16 AM   #1890
Default Not using bladders
I ran out of shock bladders so I've been running my shocks with just an oring in the cap, filling the shock and cap with oil, and bleeding properly. I really haven't noticed a difference.
Should there be a difference? Has anyone else done this?
slow is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
