Old 02-12-2007, 06:52 PM   #1846
sepirts's Avatar
losi8ight, the RTR pipe will work fine. Just make sure you retune your motor when you get your new pipe.
sepirts is offline   Reply With Quote
Old 02-12-2007, 06:57 PM   #1847
Default yeah
Thanks seapirts I am just going to use this pipe for now and save up for a new 053 soon. I spent all my money on stuff for the 8ight but a pipe. So I was just making sure the losi pipe would be ok. Thanks again.
losi8ight is offline   Reply With Quote
Old 02-12-2007, 08:26 PM   #1848
Crim3Wav3's Avatar
Hey Trebor,
If you race at RCE in Mass, don't worry, you can use the engine that came with the car. There isn't really a novice class (yet) so you'll still be running with the pack.
and the 400 dollar engines just get better mileage
Crim3Wav3 is offline   Reply With Quote
Old 02-12-2007, 08:27 PM   #1849
Crim3Wav3's Avatar
and don't forget about ETMR www.glowplug.com
its right down the road in East Templeton...HUGE TRACK!!!!!!! ALL 1/8 SCALES!!!! the FAST GUYS RACE HERE!
Old 02-12-2007, 09:01 PM   #1850
trebor's Avatar
yesi do race at rce. wow somebody knows where it is. i did go to the one in templeton but then i went on the website and they said its closed and neveer oening back up. i dont know. i wish it was open because it is a sick track. do you go to rce? inspector?
trebor is offline   Reply With Quote
Old 02-12-2007, 09:34 PM   #1851
Default Hey
Hey guys I have a real quick question for you. I just bought a king headz radio tra stiffiner for my 8ight and I was wondering if you have any suggestings where would be the best place to mount my PT becasue I am not able to mount it where it is supposed to go becasue the radio tray stiffiner has a curve in it where the hole go to place the Pt. Heres a pic
Old 02-12-2007, 09:44 PM   #1852
Trader Rating: 26 (96%+)
I would just take a piece of lexan and mount it under a couple screws and pop the transponder on to that.
party_wagon is offline   Reply With Quote
Old 02-12-2007, 09:52 PM   #1853
Talking Hi everybody
Hi everybody I am a newb to this site a 1/8th scale buggy I used to race MT and I was wondering if I could ask a couple of questions about 1/8th scale buggys. O buy the way I have a losi 8ight now I know what these things are but what exacley do they do. Sorry I am a newb and I do not know much so I figured what will it hurt to ask right.
OK
1st- What is camber and what does it do.
2nd- What is bump steer and what does it do.
3rd- What is Toe and what does it do.
4th- If you have any pics on what these things are and if you could tell me what they do you do not know how much I would appricite it.
JOSH K is offline   Reply With Quote
Old 02-13-2007, 06:32 AM   #1854
Josh,
check out this link, it is on Team Losi web site. It will help you understand your car's suspension.
http://teamlosi.com/articles/article...articleid=1562
Roll Center- Refers to both the camber locations and the mounting point for the suspension arms. By adding or removing shims from under the camber ball stud or raising or lowering it in a shock tower, you will change the rate of camber change. By changing the height of the suspension mounts, the weight transfer and roll rate of the car is altered.
Camber- The angle of the tire in relation to the ground. A tire that is perfectly up and down has 0-degrees of camber. A tire that has the top leaned away from the centerline of the chassis is said to have positive camber. A tire that has the top leaned in towards the centerline of the chassis has negative camber.
Caster- Refers to the angle of the front axle/steering knuckle in relation to the ground.
Toe In/Out- Looking down at your car from overhead, if the front part of your tires is closer than the rear, that is toe in. If the rear part of the tire is closer, that is toe out. By using toe-out on the front of your car, it will initiate a turn more aggressively. Toe in is not used on the front. On the rear of the car, toe in increases rear grip. Toe out is never used on the rear of the car.
Traction Roll- A condition that occurs on extremely high-grip surfaces where a car will flip or roll over when cornering.
Bump-Steer- Refers to the steering geometry changes that occur when the suspension is compressed.
Pack- How firm or soft a shock feels when compressed with a specific shock oil and piston
Droop- The down travel of a suspension arm once it is fully extended.
nip0380 is offline   Reply With Quote
Old 02-13-2007, 07:20 AM   #1855
Default Thanks
thanks nip0380. Now may I ask one more thing can you tell me if I labled these all right and can you tell me the answer to the wording in green. thank you.
Old 02-13-2007, 07:24 AM   #1856
Davidka's Avatar
Trader Rating: 75 (100%+)
The green labeled part of the image is an example of toe-in. Toe in is when the leading edges of the tires (front or rear) are closer together than the trailing edges.
Old 02-13-2007, 07:31 AM   #1857
Default so
So now my question is when would I have to adjust the camber and caster when I am at a race like for what track conditions or just when would I need to change it like what are the signs of adjustment needed to be done.
Old 02-13-2007, 09:05 AM   #1858
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
losi8ight- your diagram for caster is wrong. thoes links you are pointing to are for adjusting the toe in/out for the front wheels. the caster is in the front spindles.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 02-13-2007, 09:08 AM   #1859
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
I used a few of these setups,and really didnt have to change to much camber or Toe. Hope this help.
http://www.rc-car.com/ME2/dirmod.asp...8726B97A2175A5
layedbackguy is offline   Reply With Quote
Old 02-13-2007, 03:37 PM   #1860
vr6
Trader Rating: 22 (100%+)
anybody using the associated starter box? i called a track two hours away from me and the owner said that quit a few of the 8ight drivers are using the ae starter box because the wheel is taller. any feedback would be great
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
