Losi 8ight building and setup
#1771
Nip this was copied from the S-Gird (Lois) Forum
I'm running the brace from KHZ, but it stiffens the radio tray threw the Throttle servo, not the steering servo too. I really like mine. It helps with some flex to prevent potential cracking of the servo case when landing (Or Crashing) BIG jumps...
I BOUGHT ONE OF THESE CARBON FIBER SERVO TRAY STIFFENER FROM CAROLINA
RC. IT LOOKS COOL BUT THE HOLES DO NOT LINE UP. I MADE IT WORK WITH
DRILL. IT HAS A THIRD HOLE FOR PT BUT I DID NOT USE IT BECAUSE THE
WIRE COMES OUT RIGHT NEXT TO THE CENTER DIFF AND IT DOES NOT HAVE A
HOLE FOR THE WIRE TO GO STRAIGHT DOWN FOR CLEAN INSTALL. I TURNED IT
AROUND AND MOUNTED BACK WORDS LOOKS OK SORRY NO PICTURE.
http://www.carolinasrc.com/Webstore/...idcategory=518
#1772
throttle setup
trying to setup the throttle EPA on my radio, ive have it at about 45-50%.
that seems to be grabbing the brakes good enough.
Are you guys also at about the same on your brake epa?
#1774
Yup, some of us are even LOWER!
My theory seems to be working. I switched to 5-5-2 to try and get more on power steering. Our track is tight and technical, so getting through it fast can be tough. Raceday is tomorow, so the REAL test begins then. I got a chance to practice last night... I Love This Car...
#1775
When using a Lipo reciever battery pack, do you have to use a voltage regulator, or will the voltage regulator in the reciever handle the extra voltage?
#1776
Dale...I don't use lipo batteries, so I'm not 100% sure. However I do remember seeing people say they use the Novak regulator for lipo batteries...so I think you might need to get one.
#1777
#1778
Guys i been using lipo for the last 4 months or so now. VXR racing 2000mah pack and there 5amp regulator (You NEED a regulator).
The Novak Reg. is 3amps and i'd say thats under powered in 1/8th ( I thought it was anyways, servo swayed alittle in the corners)
The VXR 5amp is good and that's what i currently use BUT is only compatable with Spektrum + Futaba HRS recievers
Much-More do a 7amp one, available from Amian amoungst other places, I'm trying this out on the weekend. They dont mention any compatability issue's so i guess it'll work with all radio set-ups.
Hope thats of help
Rod
Hope thats of help
Rod
#1779
I'm using this MuchMore 7amp regulator and I love it. I gives constant power to my two Hitec 5955 TG servo.
I had the novak one too, but I like the MuchMore regulator better
#1780
Originally Posted by Merciless
Oh and looking sweet my friend, Told ya GAS was the way to go.
Shoulda got a Mugen though im loving my 5R we should been doin this when you were over here dude. It's alot a fun
Tried callin ya but got the machine, hopefully i'll geta chance to try again tonight.....
L8rz
L8rz
I think Justin wouldnt have changed a thing when he was over here. The BTCC was the place to race when he was here and hopefully he enjoyed it as much as I did.
I believe Justin is racing the Losi over there because thats where the competition is in his part of the world.
I will look for his name in the leaderboards when he starts racing this class again and will not be suprised to see him near or at the top of it.
Good luck Dude and see you at the snowbirds
Sean
#1781
#1782
I have just purchased an 8ight and would like to know what would be a good starter box to use? Anyone using the Team Magic X5 Turbo? Any Suggestions?? Appreciate the help...
#1783
#1785
ofna 10256, works great.
