Old 02-05-2007, 09:38 AM   #1681
Trader Rating: 14 (100%+)
Originally Posted by cwalters
Looking for a good setup for indoors like Columbus because I'm not going to get any practice, just show up and race. I've got a pretty good idea, just trying to pool some other good setup ideas.
Thanks in advance.
young sheep, call bill at dirtburners, he'll give you the dialed columbus setup, after looking at his car, I know he moved the top of the rear shocks in one hole, disconnected the rear swaybar and had silver springs all around. He was running m3 inside jobs for tires.
o.s. power is offline   Reply With Quote
Old 02-05-2007, 10:26 AM   #1682
i've been looking at getting the 8 and flew from richmond to columbus to catch a show at the funnybone in easton and check out these things in person since you guys have indoor races but couldn't make it to the track thanks to good old nwa getting us there at 6pm instead of the 9:30 am that it was suppose to be. guess for now i'll just have to keep reading the post and wait til spring
silentb is offline   Reply With Quote
Old 02-05-2007, 10:57 AM   #1683
cornerspeed's Avatar
[QUOTE=cwalters]On some cars I've seen the shaft from front to center diffs wearing, is that the one that needs replaced often?[QUOTE]
This is in my belief is true. If you very frequently clean and grease the front center CV coupling it will last a bit longer.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-05-2007, 12:15 PM   #1684
Crim3Wav3's Avatar
I remember from my Mountain Biking days that White Lightning was the shizzle for chains and derailers n'shit.....would this be the best lube to use for the CVD's as most other stuff will just attract dust/dirt/crud/otherlosiowners/sand????
anybody else have a "dry" lube they use with success?
Crim3Wav3 is offline   Reply With Quote
Old 02-05-2007, 12:48 PM   #1685
R40Victim's Avatar
We tried graphite dry lube, but it just gets slung off at the high RPMs that the typical RC car drivetrain opporates at. If you've got some laying around, try it and tell us how it worked for you.
R40Victim is offline   Reply With Quote
Old 02-05-2007, 12:54 PM   #1686
I'll use the same Bel Ray that I use on my 450F linkage it's very good stuff. The tub lasts forever. I'm seeing lots of wear in the dowel that goes through the bone end. Can't tell if it is the dowel itself or the end or both. Just wondering, everything else seems good though. Thanks.
Hey O.S. BRAAAAAAH. Just thought Scuba Steve or someone from there could throw me another setup to try. I got a pretty good idea with it. I know some guys are going to 5,5,2 or 5,5,3 instead of the usual 5,7,2. It's hard saying with oils right now, the weather is different everyday. -7 here today...
cwalters is offline   Reply With Quote
Old 02-05-2007, 02:58 PM   #1687
I am wondering if I am puting my 8ight together right:
I have finished building the front suspension and have attached it to the chassis. I noticed that if I turn the driveshaft and hold the left wheel nut, the driveshaft keeps turning and the right wheel nut continues to turn (the left must slip).
If I try to hold both wheel nuts, I can't turn the driveshaft.
Is this how it should work? If so, doesn't it mean that at least one wheel can be slipping on either side of the car at any given time?
Paulybehaved is offline   Reply With Quote
Old 02-05-2007, 03:14 PM   #1688
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Cwalters, I have a set up that I like and it is very much like Bill's that O.S. power is talking about (Bill and I are good friends and race together)...... I gave the set up to Topher and Hecticracer.... I hope they let me know how it worked for them.... I am no set-up genius by no means but I can definately hold my own ..... but before I make everyone think this is the "Hot" indoor set-up I would like to see how those guys did with it.... Don't get me wrong I will give it to you I just don't want to steer any one in the wrong direction... plus alot of people have different driving styles...... but I will post that set-up shortly.
Topher
and
Hecticracer > How did the set-up work for you guys ????
SCUBA STEVE is offline   Reply With Quote
Old 02-05-2007, 03:17 PM   #1689
Yes, it is fine.... It's just the differential doing it's job
Old 02-05-2007, 03:23 PM   #1690
I'll let you know after this Saturday.
*Topher* is offline   Reply With Quote
Old 02-05-2007, 04:25 PM   #1691
Ok guys, nothing major but here you go
*Box stock set-up with the following:
*Rr. shocks: 56 pistons with 30 wt.
position inside & hole 1 in tower
Silver springs
* No sway bar
*Droop (shock length) 97.5 mm Fr. & 104.5 mm Rr. (center of screw to centerof screw)
*Front toe O*
*Mugen Diff fluid F 5k / C 6k / R 3k
*Ride hieght 27mm Fr. and Rr.
PL M3 inside jobs with medium ofna molded foam are the best especially on a dry track.... if the track is a little damp and the PL's are to stuck you can try some panther switch clay with the same foam.
Hope this helps you guys, It worked well for me and a few others that ran it... Let us know if you like it .... or if ya don't
Old 02-05-2007, 04:59 PM   #1692
Scuba Steve, is the rest of the setup the same as either box stock or the Drake Neo setup? Ie, the front shock pistons/oil/positions/swaybar?
Stealth_RT is offline   Reply With Quote
Old 02-05-2007, 05:38 PM   #1693
Oops.... sorry ... I fixed it
Yes, stock set up with those changes.
Old 02-05-2007, 05:44 PM   #1694
S Bowen's Avatar
Trader Rating: 57 (100%+)
Hey all, I'm new to the Eight camp. Have to say that the build is nice, great car Losi has here. Wondering about the cvds that are wearing on everyone here causing the "push". On some cars I've seen the shaft from front to center diffs wearing, is that the one that needs replaced often?
Thanks in advance.
Chad me and Al have a good set-up that I will send you if you want.
FACTORY TRACKS RACING, NANKIN HOBBIES, LUNSFORD, JCONCEPTS, KOLOR KONCEPTS
S Bowen is offline   Reply With Quote
Old 02-05-2007, 05:50 PM   #1695
Smile
Hey S Bowen,
I'm having trouble with setups on my car. I've tried many and am having some trouble keeping the car tame. My x-ray handles great right now and I'd like my 8ight to do the same. Anyway, I have been looking for user setups on this message board. Would you mind sending yours to zeteckat101@yahoo.com Thank you !!
zeteckat is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
