Old 02-03-2007, 06:17 AM   #1651
Originally Posted by cornerspeed
What are you looking for your car to do/feel?
I am having corner entry and mid corner push. I am using Drakes Neo setup on it.
Softer front springs or more rear droop?
*Topher* is offline   Reply With Quote
Old 02-03-2007, 06:35 AM   #1652
gabbyb3's Avatar
Default push
try raising front ride height or lower rear( less droop) i would try a stiffer rear spring. when you are pushing you need more weight transfer to the front... also depends on wheel base, anti squat and rear toe.....you could also use the lower or a shorter front link... or run hole a in the rear hubs.. is this problem off power or on power?
gabbyb3 is offline   Reply With Quote
Old 02-03-2007, 09:11 AM   #1653
Suspended
Send a message via AIM to Nay0k
I would try softer front springs along possibly with moving the rear shocks out on the shock tower. But I don't know what Drake's setup from the Neo race is, is that how they're already positioned?
Nay0k is offline   Reply With Quote
Old 02-03-2007, 09:21 AM   #1654
On power push.
I think I am going to try some of the ideas here.
http://www.teamlosi.com/Articles/Art...ArticleID=1562
Different car but same principles.
Old 02-03-2007, 09:37 AM   #1655
What's the answer?
Dave.H is offline   Reply With Quote
Old 02-03-2007, 09:41 AM   #1656
gabbyb3's Avatar
Default push
if its off power there isnt enough weigt transfer to the front.. use stiffer rear springs or 2 deg anti squat or more front ride height..
Old 02-03-2007, 09:45 AM   #1657
On power push.
Old 02-03-2007, 10:28 AM   #1658
cornerspeed's Avatar
First you said off-power and mid-corner push, now you say its on-power push?????
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-03-2007, 10:37 AM   #1659
That's what I'm saying Cornerspeed
Old 02-03-2007, 10:38 AM   #1660
On power.
Old 02-03-2007, 10:55 AM   #1661
SlobbaTech's Avatar
If you're running 3* anti-squat try going to 2*.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 02-03-2007, 11:22 AM   #1662
If you are refering to me.
My problem is getting the car to turn into the corner without having to completely lift off the throttle in entry and mid-corner. I can't seem to get the car to drive through the corners. If I apply any power it starts a push.
Old 02-03-2007, 11:37 AM   #1663
RBMike's Avatar
Originally Posted by slow
I'm using 7075s with green and gold and I've been having problems with my engine killing late in the race when I hit the brakes. Could it be that my sping combo is not stiff enough to disengage the shoes?
Maybe your clutch shoes need the corners cleaned, you should check them every couple of days (or more often). If the aluminium starts to squish over the edges they can start to hang up on the fly wheel or clutch bell causing your engine to stall when you let off the gas.
RBMike is offline   Reply With Quote
Old 02-03-2007, 12:50 PM   #1664
Trader Rating: 27 (100%+)
Send a message via Yahoo to HECTICRACER
dose anyone know the effect of having your bump steer up instead of down witch is more commonly used i was just askin becuz i notice that i ran it up in my last race a crcrc and the car felt very twitchy
HECTICRACER is offline   Reply With Quote
Old 02-03-2007, 01:12 PM   #1665
Talking TOE-IN & BUMP STEER
Anyone here run around 1 degree to 2 degrees TOE-IN. Is toe-in a bad thing to run with the 3 degrees of rear toe-in.
I'm also wondering whether or not the car will handle better with the bump steer up or down.
THANKS EVERYONE !
zeteckat is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
