Old 01-31-2007, 05:17 PM   #1621
Peter Martin's Avatar
Slow...probably a little oil yes. Your procedure is fine. Clean and re lube. I prefer grease...stays in longer. You can smear a very thin film on the bearing and heat it with a heat gun or put the bearing on the end of a soldering iron. The grease will thin and migrate into the bearing. That said the oil method has served you well. When they start to feel rough after cleaning and oiling it is a good time to replace them. Thanks for your business!
Peter Martin is offline   Reply With Quote
Old 01-31-2007, 08:10 PM   #1622
Peter, thank you for the response. Is there a specific grease you recommend? Will Dow 33 work?
Your site was the first place I hit up when I bought my 8ight for bearings, Himoto wings, o-rings. All top notch stuff.
slow is offline   Reply With Quote
Old 02-01-2007, 01:50 AM   #1623
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
here some nice losi pics my cars the one that looks like a parrot
Losi 8ight building and setup-me-jarrod-going-.jpg   Losi 8ight building and setup-me-passing-3-guys.jpg
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 02-01-2007, 10:13 AM   #1624
Slow...a light synthetic grease...Mobil 1 or our Sonic grease. The Dow 33 grease is used for guns etc. I believe....try it.
Old 02-01-2007, 10:41 AM   #1625
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
dow 33 is what is used on most paintball guns as it causes the orings to swell a tad bit to get a better seal....
with that being said i think i may have to put mine out the paintball bag and give it a try on the losi shock orings!
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 02-01-2007, 11:13 AM   #1626
I'm not exactly sure but I think dow 55 is the oring swealant and dow 33 is not. The reason I say is because I tried both with one TKO oring and a Losi oring. With the dow 55 the shock had much more stiction. I just use dow 33 for the shock orings and my shocks are pretty smooth without any leaks.
I have 2 gallons of fuel on the same set of TKO/Losi orings and no leaks. I work on various paintball guns so I know about leaks( up to 4500 psi )
Old 02-01-2007, 11:24 AM   #1627
both cause swelling, but dow 55 causes more swelling, and is more of a oily greese.
Rob Jensen
Old 02-01-2007, 12:10 PM   #1628
Did some quick research. Dow 33 was developed as a low temperature bearing grease and was also found to work well for paintball guns in low temperatures. Dow 55 was developed as a oring grease and does swell orings. What we want is Dow 44 which is a high temperature bearing grease.
Old 02-01-2007, 02:15 PM   #1629
RBMike's Avatar
Your shocks are getting that hot?
RBMike is offline   Reply With Quote
Old 02-01-2007, 02:24 PM   #1630
Dow 44 for the clutch bearings. Sorry lost context there.
I'll shut up know.
Old 02-01-2007, 02:53 PM   #1631
dirtracer1's Avatar
I'll shut up know.
there seems to be two conversations going on here.
regarding the shocks......from what i'm reading, some are using a dow branded grease on the shock o-rings. whatever happened to using ae's green slime grease......or is the point to swell the o-rings with the dow grease.
i assume that the ae green slime grease doesn't swell an o-ring....correct?
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 02-01-2007, 04:56 PM   #1632
I have always used the AE green slim on Orings and never had any odd issues. Orings do swell over time that is normal reaction with them. Well I thought it was.
kyracer is offline   Reply With Quote
Old 02-01-2007, 05:39 PM   #1633
tex1's Avatar
Send a message via Yahoo to tex1
Wink
micrors4guy - you are correct about Dow grease. The 33 will only swell slightly and the 55 will swell more. Use to use it in all of the prototype guns we were testing. Good stuff. If the 33 will do the job on the stock orings then that is what you should use. If you need more sealing then 55 will help.
TEX
Halo Dude.
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 02-01-2007, 05:42 PM   #1634
tex1's Avatar
Talking
In the clutch I personally will not run grease. It gets hot, slings out and then all hell breaks loose. Clean them out. Make sure you get the rear one on the Losi real good. It hold a ton of grease!
1 Small drop of Mobil one and you are good to go.
TEX
www.indyrcworld.net
(972) 271-4844
Old 02-01-2007, 06:09 PM   #1635
tex- i know i was correct lol. i have been playing/ messing with paintball and paintball markers for over 10 years, not to mention i work in a paintball shop as the tech.
Rob Jensen
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
