Old 01-29-2007, 11:07 AM   #1606
RBMike's Avatar
OK, I've gone thru 4 gallons now & I'm just starting to get 1 leaky front shock. Other than this (& clutch/ bearings), I have still not broken a single thing. On the servo issue (for guys with the kit), it's the long spring that is the problem. The only thing I did was cut down that spring & set my end points correctly.
RBMike is offline   Reply With Quote
Old 01-29-2007, 11:26 AM   #1607
Steve Walters's Avatar
Is there a new Part number for the New Losi Blue (7075) shoes. Losa9108 is the part number for the Aluminum shoe(s), but the older one.(silver)
Anyone know the new Part number?
Steve
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 01-29-2007, 11:45 AM   #1608
CaseyP's Avatar
Steve same part number....it is a running change so you will get the correct one when you order the old number. They are working great for me I have put 3 race weekends on them so far with nothing more than inspecting them. They seem to make the carbons last longer as well.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 01-29-2007, 01:12 PM   #1609
What is the difference in these shoes? I assume they are made of 7075 aluminum, but what do they do different?
Dale.0 is offline   Reply With Quote
Old 01-29-2007, 01:33 PM   #1610
CaseyP's Avatar
yes they are 7075...they last 3 times as long and to me, feel the same as the first ones. The stock clutch set up offers the most punch. Its all a personal preference.
Old 01-29-2007, 02:26 PM   #1611
I feel my clutch engages at too high of RPM. I would like it to engage a little sooner. I guess i will try softer springs.
Old 01-29-2007, 02:46 PM   #1612
SCUBA STEVE,
I am going up to Fasttrax this weekend if the snow does not come. I was told that Kevin W. and a few other "fast dudes" will be there as well.
You have to check out the WALL at this track, its crazy!
Has anyone used 2 King Headz 7075 shoes and 2 carbon shoes?
kyracer is offline   Reply With Quote
Old 01-29-2007, 10:38 PM   #1613
weezer23's Avatar
Im running the standard setup and was just wondering if anyone else thinks the toe out looks more than 1 out? Maybe Ive just looked at it too much but it looks like more than 1 degree of toe out and my tie rod lengths are exact to the book. I dont have a setup board to verify this so figured Id ask you guys.
weezer23 is offline   Reply With Quote
Old 01-30-2007, 12:56 PM   #1614
BUCKSHOT's Avatar
Default HOW BOUT THE ROSSI AXE .21
ANY INFO,EXPERIANCE WITH IT ?HOW BOUT ON AN 8IGHT
BUCKSHOT is offline   Reply With Quote
Old 01-30-2007, 01:04 PM   #1615
CaseyP's Avatar
weezer....It will look like more because the rear of the car has 3 deg tow in.try to eyeball down from the chassis guards to the front, Keeping the rear out of your sight will play less tricks on your mind.
Old 01-30-2007, 08:46 PM   #1616
Default TKO Clutch Bearings
How long can expect to run my TKO clutch bearings? I've already got 2 gallons though the same set of bearings and they still spin fine.
Also after a day of racing or practicing my bearings and the crankshaft have a brown tarnish on them. I have to use a scotchbrite pad to clean it off the crankshaft. Is this burnt oil?
I spray my bearings out with motor spray and put 2 drops of Much More bearing oil on each bearing. Should I be doing something else?
slow is offline   Reply With Quote
Old 01-31-2007, 12:36 AM   #1617
Talking
I ordered my losi 8ight today will be here friday, cant wait!
rcjake is offline   Reply With Quote
Old 01-31-2007, 01:45 AM   #1618
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
cool man you will be very pleased,although at first it feel very different compared to other more conventonal buggies after 2 tanks you will be hooked on this fantastic machine!!!!!!!!!!!!
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 01-31-2007, 08:14 AM   #1619
Turbine_au's Avatar
Man you dribble some crap sometimes Andrew.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 01-31-2007, 03:46 PM   #1620
freefallmarine's Avatar
Well I've joined the group. My buddy Brian and i both grenaded throttle servo's at a race yesterday. he with a 358 and I with a 359. linkages were not binding nor was there over epa. The servo was new and there are no markings on the bottom of the servo case or on top of the chassis. it ran for a 5 min qualifier and maybe 3 minutes of warm up befor that. Oh well..the nature of the hobby. I do have some great praise for the 8ight though, man this car is fast! Brian and I are both breaking in some Tko o-rings so the suspension was a little tight. I do recommend getting some 2mm wheel spacers though. We noticed the diffrence immediatley with the rear calming down and the front still having great steering. i just felt more stable on the loose track.
Im going to need some more set up time to really get the most out of this buggy, but if i had to do it again, Id get another 8ight. just my 2cents.
freefallmarine is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
