Old 01-25-2007, 01:30 PM   #1561
freefallmarine's Avatar
Originally Posted by Buggy Master
well i read that you need to break them in. when i installed mines, i didn't like the feel. it felt noticably tighter. that was 1 tko inside and stock o-ring outside. my next race is this weekend and i don't have time to run the buggy to break them in so i went back to the stock o-rings. i did install a thin traxxas teflon washer to squeeze the stock o-rings a little more and they feel just right. i'll find out if they leak this weekend. this is just my personal experience. tko has great products.
Thank's Buggy, Im going to lighten 5wt and give it a go. Thanks again.
freefallmarine is offline   Reply With Quote
Old 01-25-2007, 05:38 PM   #1562
tex1's Avatar
Send a message via Yahoo to tex1
Talking
Hey Carl,
Brian Jefferson joined the Losi team. He is building his tonight. Have you taken your out yet? Are still iced in?
I'll be at the shop tomorrow. Give us a call.
TEX
BTW - I used a Traxxas 5mm Id shim in my shocks and they do not leak any more.
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 01-25-2007, 05:41 PM   #1563
I am guessing the onpower push mid and out of corner is common for most. Which I think maybe including myself are using the basic setup with some changes.
Has anyone tried lighter swaybar in front with basic setup? Maybe stiffer rear swaybar?
kyracer is offline   Reply With Quote
Old 01-25-2007, 06:51 PM   #1564
Originally Posted by tex1
Hey Carl,
TEX
Congrat's to my Buddy Brian on crossing over to the 8ight side of life... And thank You guys(Rc-Tech guy's and gal's) for letting me know all the build tricks and tech answers..... C.
Old 01-25-2007, 11:27 PM   #1565
GTB_USER_Erik's Avatar
, Ok but let us know if it works
GTB_USER_Erik is offline   Reply With Quote
Old 01-26-2007, 01:24 AM   #1566
Joehwee's Avatar
Joehwee is offline   Reply With Quote
Old 01-26-2007, 04:48 AM   #1567
for those using the traxxas teflon shims, are you gluing it to the spacer or just putting it inside and letting it "freefloat" on the orings.
thanks.
xxxtracer is offline   Reply With Quote
Old 01-26-2007, 06:33 AM   #1568
tex1's Avatar
Lightbulb
My shim is metal. I used this one because it can not rub the shafts and it is thinner than the teflon shims. When you get it in the compression of the rings seem just right.
I put them in the bottom of the hole and just let them free float.
Ideal would be have a 4.5mm ID and an OD that is barely under the ID of the shock body. I would make it plastic at .1 - .15 & .2mm thick. ???? Hummm...
<-- needs to work on this!
I'll keep you guys updated.
TEX
www.indyrcworld.net
(972) 271-4844
Old 01-26-2007, 09:11 AM   #1569
Trader Rating: 37 (100%+)
thanks.
this is the one i use.
http://www2.towerhobbies.com/cgi-bin...&I=LXJJ88&P=ML
i didnt' glue it, just free float. just passing on a tip i read on the grid.
Buggy Master is offline   Reply With Quote
Old 01-26-2007, 10:55 AM   #1570
RBMike's Avatar
I'm running the bigest rear sway & the medium front on a rough track, biggest front on a smooth track.
RBMike is offline   Reply With Quote
Old 01-26-2007, 01:44 PM   #1571
Will a standard metal servo steering horn work for this car?
FYI, Tko Competition has shock o-ring's back in stock.
Old 01-26-2007, 02:58 PM   #1572
SupermaxxRich's Avatar
YES
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 01-26-2007, 07:03 PM   #1573
cornerspeed's Avatar
Anybody have a back-to-back comparison of the aluminum and plastic chassis braces? I gonna try tomorrow at ARC. Just looking for others feedback.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-26-2007, 09:41 PM   #1574
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Originally Posted by SupermaxxRich
YES
Nice, i just ordered that exact motor for my 8ight. But I'm backing it with a jp-3.
Bigedmond is offline   Reply With Quote
Old 01-26-2007, 09:44 PM   #1575
You'll love the V Spec! I have the EB Mod Version but the stocker is an animal as well!!! JP-3 will give slightly more top end and a little less bottom end than my 2050 pipe.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
