Losi 8ight building and setup
#1531
i can help with the o-rings if someone can give me the correct sizes. i can get someone in my purchasing dept. to order them from the vendor that we use for all of our r-rings and fastners, i know that they use probably about 300-500 different sizes of o-rings, and i know that they also use the buna type too. i work for GE so i know that i can get someone in purchasing to locate what everyones needs.
#1532
Originally Posted by freefallmarine
Any one know where i can get TKO 8ight shock o-rings, besides the tko or amain site's? There both out of stock. Would any other hobbyshop carry them? Thank's.
#1533
Thank's rwlkr, for the heads up. Im gonna clean them out.
#1534
Originally Posted by vr6
thanks for everyones' input, i tried everything. but still have some bad clicking, it seems that if the screws are a little loose, it quiets up, but then there is a gap for small debris to get it
#1535
If you put the diff in backwards the tires rotate in the wrong direction!!!
#1537
The two shafts inside the diff that hold the idler gears are ground down in the middle so that they interlock and can therefore lay on the same plane.
One more thing to check is that those two flat spots in the dead center of those two shafts are perfectly interlocked with each other. If they are not, then things would bind up for sure.
#1538
The new 1/8 Losi Pink Tapers are an excellent tire, probably one of the best tires I have ever ran indoors. Just like with the 2wd version that I run on my B4 electric buggy, they give excellent traction and extreme stability, very predictable. Thanks to Adam Drake I was able to run a set in my main at the CRCRC Indoor Gas Champs, and that was the most consistent my car felt all weekend. Though alot of people there who just glanced at them said they are just like Switch 2.0's, their not! I have a side by side pic of the Losi Taper and Switch 2.0, as for height and shape the Losi Tapers are the same profile, but they are wider and the bars in the middle are spaced more and have a small pin in between each bar. A definite MUST in any racers tire bag!!!
#1539
the taper pin and switch are similar because the switch tire is a knock off a taper pin from way back.
#1540
let me rephrase that.....the switch was made to combat the losi taper pin....panther however was the first to make one for 1:8 scale buggy.
no knock on the panther tire....they just were not the first with this style of tire. thats all simple observation.
#1541
Also guys to add to what Ryan said, the losi tire is wider but the ID is also larger than a standard tire so if you want to run the same tire set-up as Adam make sure you mount them on losi rims, they have a larger OD and are wider than a standard rim ..... and I beleive are acctually the only true legal wheel . If you would like a "more rounded" tire surface you can mount them on any other wheel to get that affect and they still work great but on the smaller wheel there seems to be a ton of side bite... I ran them both ways and they are sweet either way!
As Ryan said they do work great and my buggy was also the best on the losi tapers most of the weekend.
#1542
Where can you get those 1/8 tapers?
#1543
#1544
#1545
I'm looking for a little feedback from guys who have switched from the Mugen camp and are now running an EIGHT. Thinking about switching and just wondering what you all think as compared to the Mugen. I've heard some things from people but I'm still confused as with what to do. Any feedback would help my decision.... Thanks.
