Old 01-21-2007, 04:18 PM   #1501
RBMike's Avatar
I put another 1/2 a gallon thru mine today & I am amazed at how tough this thing is. We have a front stright with a small jump before the sweeper at the end. I was hacked just before the car took off from the jump. The car hit full speed into a fence post. Nothing broke.
RBMike is offline   Reply With Quote
Old 01-21-2007, 04:28 PM   #1502
Eric Swanson's Avatar
I hit and bent the hell out of a steel sawhorse at full speed yesterday, and there isn't even a scratch on the car from it.
Team Associated | Reedy Power | AKA | Schelle | LiveRC | LiveTime
Eric Swanson is offline   Reply With Quote
Old 01-21-2007, 08:02 PM   #1503
tex1's Avatar
Send a message via Yahoo to tex1
Red face
Carl,
Call me tomorrow at T&T. I'll measure my shim in my shock since they are due for a rebuild anyways. The shim tightens up the fit of the oring. Seals them up nice and tight.
When are you going to drive that thing?
If you do get some TKO orings grab a few extra sets while you are at it.
PLEASE.....
Later,
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 01-21-2007, 08:55 PM   #1504
vr6
Trader Rating: 22 (100%+)
need help please!!!!! when i put the front diff cases together, the gears have a really bad mesh, makes a clicking sound, or even really bound up, can someone please help explain what i'm doing wrong
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 01-21-2007, 08:56 PM   #1505
dirtracer1's Avatar
Originally Posted by scotty5555
This may be a repost but i just saw that there was a split center diff mount.
http://tkocompetitiondev.com/shop/pr...roducts_id=298
looks very nice.....it should make access to the center diff a snap.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 01-21-2007, 09:31 PM   #1506
cornerspeed's Avatar
I noticed this also. It meshes better if you push the pinoin gear from the inside towards the driveshaft and the drive shaft coupling towards the gear. Little end play of the pinoin shaft. Then the pinoin gear will not be too tight on the ring gear.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-21-2007, 09:55 PM   #1507
R40Victim's Avatar
I just installed one of these:
Testing to begin on Saturday. I've been using the motor mount for the last two weeks, makes clutch maintainance very quick and easy. This should make swapping center diff fluid alot easier.
R40Victim is offline   Reply With Quote
Old 01-22-2007, 01:12 AM   #1508
Install pinion into case half first and push it in as far as it will go, then on the other side install your cvd flush against the bearing and lock the set screw down. This will ensure free play between pinion and ring gear. Next time you have it apart you more than likely wont have to do this. Yeah just like cornerspeed said above... Guess I should have read further....
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 01-22-2007, 01:29 AM   #1509
That looks nice! Are the halfs pinned for alignment when you clamp it together? That may have to go on my upgrade list.
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
Old 01-22-2007, 07:34 AM   #1510
Trader Rating: 28 (100%+)
Have a link to the mfg site?
Edit: nevermind, found it.... $$ cha-ching
FlyByWire is offline   Reply With Quote
Old 01-22-2007, 07:39 AM   #1511
My diffs done that as well. It almost felt like a burr was on one of the gears. I read way in the past of this forum where it takes some breaking in period. I left it alone and ran it. It feels and sounds much better. People I have spoke with said it will take almost a gallon of fuel to free the buggy up.
kyracer is offline   Reply With Quote
Old 01-22-2007, 07:44 AM   #1512
vr6
thanks for everyones' input, i tried everything. but still have some bad clicking, it seems that if the screws are a little loose, it quiets up, but then there is a gap for small debris to get it
Old 01-22-2007, 07:45 AM   #1513
RBMike's Avatar
How much does it weigh? (compaird to the stock parts)
Old 01-22-2007, 08:10 AM   #1514
weezer23's Avatar
When you guys are measuring ride height, are you dropping it from a few inches up then measuring or setting down and letting weight of the car go down then measure?
weezer23 is offline   Reply With Quote
Old 01-22-2007, 08:15 AM   #1515
Pick the buggy up off the ground and drop it a foot or two off the table to measure ride height. You want the shocks to rebound like it would on the track. This will give you the true ride height.
I like the springs between the brake pads like the Jammin has. Good idea.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
