Old 05-05-2008, 09:30 AM   #1336
Originally Posted by micrors4guy View Post
tex- the table that vad posted is also wrong. for the rear when you run 0f/0r you are setting it to 2 anti and 3 toe. so to get the stock truggy block setting you need to run 1+ in the front and 1in for the rear to give you 3 anti 2 toe.
It sounds interestingly. May be we have different braces? Or different Set-up Systems?
I'm not using instruction at the time of assembling. Only got exact match with stock braces. After that I've verified toe-in and anti-squat, with 0.5 insert up in the front and 0.5 insert inside in the rear I have 3 degree anti-squat and 2 degree toe-in. I haven't verified all other angles.
vlad_vy is offline   Reply With Quote
Old 05-05-2008, 12:42 PM   #1337
Revo-lution's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rescuemann View Post
I am having issues with the steering. I think that it is in the servo saver/spring. I have noticed a decline in my steering nimbleness on my truggy. I have not noticed any problems in my buggy other that the normal slop. I have tightned the nut to increase tension on the spring. I have a JR 9000S for the steering. should I loosen up the spring again? I have no idea hoe to resolve the issue other than replacing everything.
The S is a little weak for that application IMO, I'd have used the 9000T. The quick .06 response is nice, but lacks torque and is really only useful in an onroad application.
I used a 9000S for my throttle and a 9000T for my steering (double the torque) and it is an amazing setup. http://i32.photobucket.com/albums/d5...y/IMG_1821.jpg Perhaps you can sell one of the 9000s and bump a 9000T into the steering spot.
It won't directly affect your steering woes until you tighten that nut, but once you do it'll be a nice welcome once you feel 370oz on the front wheels. I'm assuming you are running two 9000S servos right now.
~ Go big or go home ~
~ Novarossi powered 8T 1.0 - A.K.A. 4.0~
Revo-lution is offline   Reply With Quote
Old 05-05-2008, 12:53 PM   #1338
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
they made the braces so it is the same as the buggy stock plate that is 3 toe 2 anti with the 0/0 insert. Also, with the stock ones the antisquat and toe were adjusted at the rear now just the toe is from the rear and the anti is at the front.
micrors4guy is offline   Reply With Quote
Old 05-05-2008, 04:49 PM   #1339
air8's Avatar
The reason I run the KH parts is cause the Losi parts weren't designed last year. And it was KH or Fioroiinoiieo parts. LOL. OK, so I can't speak French. LOL.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-05-2008, 09:46 PM   #1340
Originally Posted by tex1 View Post
Vlad,
Did you measure this or receive this from another source? I still have not put my car on the setup station yet. I have just completely rebuilt it so now would be a good time to check.
TEX
All other sources says different things. I don't trust anybody, especially Losi. At first, I got exact match with stock 8IGHT-T Race Roller rear braces (3 degree anti-squat and 2 degree toe-in) with 0.5 insert up in the front and 0.5 insert inside in the rear. After that I've verified toe-in and anti-squat, I have 3 degree anti-squat and 2 degree toe-in. I haven't verified all other angles.
The result of measurement may depends from accuracy of Set-up System (Hudy) and goniometer. Therefore I say - "May be".
Old 05-06-2008, 06:26 AM   #1341
tex1's Avatar
Send a message via Yahoo to tex1
Red face They need to get it straight at Losi......
Good call. I have always been suspect of Losi's data on this. I just have never measured it. All I have is the Hudy station. It is OK if you know what you are looking for.
Right now, I'm running 0's in the front of the rear kit and .5 inside on the outside. I think it is 2 degrees Anti Squat and 2.5 degrees of Toe In. I do have to measure this.
Whatever - It works very well.
TEX
tex1 is offline   Reply With Quote
Old 05-06-2008, 08:22 AM   #1342
I got my info from drake a while back when the issue of the charts being off came out.
Old 05-06-2008, 11:24 AM   #1343
OK. This info from Mike Truhe:
"Those tables have been wrong a couple times. the best way to think of it is the toe in is between 2-4 degrees and the antisquat is between 1-3 degrees. 0 inserts front and rear give you 3 degree toein and 2 degrees antisquat. so to get 3-3 you have to just put the 1 insert up in the front."
They all say different.
Old 05-06-2008, 11:29 AM   #1344
vlad. the information i posted is the same information you just posted. The stock BUGGY comes with a 3 toe 2 anti and that is what they based the settings off of.
Old 05-06-2008, 10:42 PM   #1345
May be for buggy it's working, but for truggy these suggestions and tables don't working. I don't know what the difference, bulkheads are the same.
I do not insist that my tables are true. Nothing serious, everyone can have own opinion.
Old 05-06-2008, 11:05 PM   #1346
Hi, can anyone tell me the o-ring size for the 8T shocks. ID x OD x thickness. Thanks.
Ken4 is offline   Reply With Quote
Old 05-07-2008, 05:48 AM   #1347
the adjustable peices along with the buggy and truggy are the exact same along with the bulkhead they mount to. If you are getting odd readings its because your setup station is off.
Old 05-07-2008, 09:46 AM   #1348
This is accurate as far as I can determine. I am running +1 up in the front and 0 in the rear for 3x3 on the truggy.
cherokee180c is offline   Reply With Quote
Old 05-08-2008, 07:23 AM   #1349
air8's Avatar
So what setups is everyone using?
Mach 427 engine with about 15 gallons on it. LOL. Still strong so far.
JP-3 pipe
ACE 1015 servos
Spektrum RX (grey case)
Protek 2000 Lipo
Protek 6.5v regulator
KH 7075 shoes with 2 black and 2 gold springs
KH qc extended engine mount
Losi aluminum servo saver top piece
Racers Edge steering servo horn
Losi center diff aluminum insert
Losi rear diff case bearing inserts
Stock suspension setup
I've played with the wheelbase adjustments a bit, but back to stock for now. The rear camber link I've messed with a bit depending on traction. I really like how this truck rotates in the corners. Turns in well, and still turns great when on the throttle. It's setup very vell for me and I'm loving it
--"U Ain't Fast!!"
Chris Pearce
Old 05-08-2008, 08:17 AM   #1350
jgtruggy's Avatar
JP-3 pipe
ACE 1015 servos
Protek 2000 Lipo
LOL to the 427. I have about 4 gallons on mine and still strong.
I'm now running a GO .25 6port
KH stiffeners
KH tray stiffeners
Alluminum servo saver
KH extended engine mount
Losi rear HD diff case/ alluminum bearing inserts
JP 3 or 2 pipe
Spektrum radio
Hitec 5955tg steering
ace 1015 throttle
dynamite servo horns
40 weight FS/ 35 weight BS
proline bowties lpr/ rims as well
carbon fiber towers
2 KH 7075 black springs
2 dynamite silver springs
robinson clutch bell 13 tooth
FOR NOW
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
