Old 04-29-2008, 01:40 PM   #1306
I didn't mean to imply that anyone could answer better than anybody else, I just want to match up insert # by position (inside, outside, up/down) to eliminate any confusion for all of us. Hopefully everybody in this discussion with the adjustable rear plate can comment to make sure what we think is 3x3 is actually the same.
Micrors4Guy,
If that is the stock setting for the buggy than it would take +1 in the upper location up front to get back to +3 antisquat for the truggy if the reference for the kit instructions is off of the buggy (ie 0 inserts is actually 3 toe, 2 anti per the buggy). I don't doubt you are correct as it appears to me that my +1 outside on the toe in is really 4 and not 3 as the instructions say.
Again, when guys get home can you just verify what insert in what location that you currently use to synchronize the settings? I have half a mind to call Losi, as it is just plain BS to not update the instructions properly, especially for the damn price they are charging me!!!
cherokee180c is offline   Reply With Quote
Old 04-29-2008, 02:44 PM   #1307
Micrors4Guy,
You are correct, the stock truggy is 3 anti / 2 toe in as it says so directly on the stock pieces. It appears to me that a +1 upper in the front gives the same +3 anti as the original piece, but I can not be sure without pulling the parts and measuring with a digital caliper. It is pretty obvious though that if the 1 insert was put on the inside on the rear piece that setting would be very close to the stock piece (+2), which suggests that it is at +4 toe in now (+4-2=2 or +3 buggy stock-1 as the 1 insert is in the outer location). Is everyone confused yet? I assume this means I want to use the 0 insert on the rear piece to equal the +3 stock of the buggy? Boy am I glad I made the simple comment about it looking so radical, or I would have never known it was wrong.
Can anybody else confirm 1 insert in front upper location and 0 inserts in rear? Sorry this discussion has dominated this section today, but I think this will help a lot of other people since the instructions are just WRONG!!!
Old 04-29-2008, 07:30 PM   #1308
air8's Avatar
LOL. I feel dumb now. I got home and realized I don't have the adjustable braces on the rear. I only have the adjustables for the front of the buggy.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-30-2008, 03:52 AM   #1309
LOL
Old 04-30-2008, 07:06 AM   #1310
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
The stock buggy came with 2 anti/3 toe which is what the 0/0 inserts will give you. However, if you are measureing the front anti compared to the front stock pwice it will not work as both setting were adjusted from the rear alone and the front one staid the same with the non adjustable peices.
in the end of this discusion (hopefully lol) +1 front and 0 will give you 3 anti 3 toe with the adjustable peices so if you are also looking to get the stock truggy 3anti/2 toe you are going to have to go +1 front/ -1 rear.
micrors4guy is offline   Reply With Quote
Old 04-30-2008, 01:40 PM   #1311
I am looking to go 3x3 truggy, so that's what I thought +1 Front upper and 0 in the rear.
Old 04-30-2008, 01:49 PM   #1312
correct.
Old 05-01-2008, 09:40 AM   #1313
air8's Avatar
Bump.
Since racing season is starting don't forget to loctite and heatshrink the front and rear center CV shafts that attach to the pinions.
--"U Ain't Fast!!"
Chris Pearce
Old 05-01-2008, 06:43 PM   #1314
all year is racing season for me
Old 05-01-2008, 07:08 PM   #1315
air8's Avatar
You lucky dog. We have to switch between indoors and outdoors depending on the time of year. Winter shuts down the 8th racing and we switch to 1/10 indoors.
--"U Ain't Fast!!"
Chris Pearce
Old 05-01-2008, 07:25 PM   #1316
louisiana dosent exactly get cold. we may have 2-3 weeks of 30 degree weather. however, we still race all year arround.
Old 05-01-2008, 08:33 PM   #1317
air8's Avatar
double post.
--"U Ain't Fast!!"
Chris Pearce
Old 05-01-2008, 08:35 PM   #1318
air8's Avatar
Hasn't the Futaba challenge been held in Louisiana before? I just saw earlier the challenge will be in St. Louis at Dirtburners, the same place that held buggy nationals in 2007. I think I'll go to that one cause it's about 7 hours away.
--"U Ain't Fast!!"
Chris Pearce
Old 05-02-2008, 07:10 AM   #1319
yep. It was held at HX raceway the past 2 years. About a 5 hour drive for me. Im about 20 mins out of New orleans.
Old 05-04-2008, 12:47 AM   #1320
Originally Posted by cherokee180c View Post
Can somebody else confirm that the instructions are correct and the most toe in you can get is 3 degrees?
LOSA1755 - Adjustable Rear Hinge Pin Brace W/Inserts: 8B/8T
Those tables from "LOSA1755_Adjustable_Rear_HPBrace_Installation.pdf " are wrong. The best way to think of it is that the toe-in is between 1.5-3.5 degrees and the antisquat is between 1.5-3.5 degrees. 0 inserts front and rear give you 2.5 degree toe-in and 2.5 degrees antisquat.
Hope this helps.
vlad_vy is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
