Old 04-27-2008, 01:59 PM   #1291
air8's Avatar
I also have the 3/3 plate now that I think about it. I also have the rear camber link in 1-A. The local pro said this would help, but I'm not sure what one would expect from this. Less camber gain??? is my thought
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-28-2008, 10:16 AM   #1292
Originally Posted by air8 View Post
Try adding a slight amount of toe out to the front. This will kind of increase the turn in a bit, but you will push slightly coming out of the corner when you're on the throttle.
Or try going to 3 rear toe in. This will help tighten the truck up slightly and add stability.
Those are some of my suggestions. If anyone disagrees speak up please, don't let me lead someone in the wrong direction.
Thanks Air and Integra,
For now I am going to do the following:
1. Back to stock front springs (currently have the stiffest installed to tighten up rear) to fix rough handling through the woops
2. Switch to Proline Bow Ties
3. Switch rear sway bar to thinnest (2.3mm) to improve rear traction
4. Switch center diff fluid down from 10K to 7K to improve rear traction
5. Play with front toe in to tune
If this doesn't work out perfect I will start playing with droop.
Does this sound like a solid plan?
Lastly what adjustable rear hinge pin kit do I need to buy to go to the 3/3 rear end you guys are talking about?
cherokee180c is offline   Reply With Quote
Old 04-28-2008, 10:57 AM   #1293
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
I had the same problem you were having when i 1st got the car. the only changes i have made to my set up was wheelbase and 2.3 swaybar. i am now running 2 shims in front one behind the rear hub. My car is very planted and easy to drive.
also, make only one change at a time.
micrors4guy is offline   Reply With Quote
Old 04-28-2008, 12:42 PM   #1294
So you are running stock XTT's, stock front springs and only increased the wheelbase ever so slightly with the shims on the rear outer hinge pins and changed the sway bar and it tightened the car up that much?
Old 04-28-2008, 02:36 PM   #1295
yep. the car is much tighter now. But you have to take into consideration driving style. I run much like driving a electric car. I dont jab the throtal. I come in brake a little before the turn role threw the turn square off and role back on the throtal. I can get the car to break lose if I need to, but i find undercontrol to be faster. If all of that does not help also move the rear link to the "B" hole on the rear hub.
Old 04-28-2008, 07:15 PM   #1296
I am actually very smooth on the throttle as well, but just found on my track the front is really hooked up, but the back likes to come around with the stock set up. The track has been dry and a bit dusty. Just too much steering. I went to the 2.3mm rear sway bar tonight with the stock black front springs, and picked up the adjustable rear hinge pin kit per Integra/Air at my LHS. I now have the 3/3 setup. Man 3 degrees of toe in looks like a hell of a lot compared to stock visually. I will hold off making any other changes until I put get the bow ties later this week and put it on the track to test it out. Thanks for the help.
Old 04-28-2008, 08:28 PM   #1297
i believe the 0 inserts on the toe peices give you 3 degrees of toe in, and when you add another degree you are at 4. the instructions at 0's in front and reear will give you 3 toe 2 anti squat i believe
Old 04-28-2008, 08:42 PM   #1298
I believe 0 matches the stock setting of 2 degrees tow in, which is what it says in my instructions. It also says that 1 degree in the outer orientation gives a total of 3 degrees of tow in. Can somebody else confirm that the instructions are correct and the most toe in you can get is 3 degrees?
The anti-squat looks fine with 1 degree in the upper position for 3 degrees total.
Old 04-28-2008, 08:50 PM   #1299
Match it up with the stock toe peice. Im pretty shure they did the buggy stock settings for the kick peices not truggy stock settings.you can get a max of 4 degrees to
Old 04-29-2008, 02:17 AM   #1300
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
I'll check this when I get to the track this afternoon.
TEX
tex1 is offline   Reply With Quote
Old 04-29-2008, 04:18 AM   #1301
badassrevo's Avatar
I keep breaking rear outer hinge pins. What do I do?
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 04-29-2008, 05:06 AM   #1302
Switch to the M2C 5/32" ones. They are very good and you should not bend or break them, but you will need to drill out the A-arms and knuckles with the included drill bit. All the reviews for the Lunsford titanium ones are poor.
Ok, I roughly measured the toe-in with a camber guage before I left for work this morning and darn if it doesn't look more like 4 degrees instead of 3 per micrors4guy. I assume that there must be a 1 degree toe in difference built into the lower A-arms of the truggy vs. buggy? Nothing like worthless instructions from Losi.
So to make this easy, what insert in what position is everyone running to end up with 3x3? I assume that the 1 deg. insert in the upper position is fine in the front for 3 total degrees of anti-squat? What insert in what position for toe in? Integra and Air, please confirm so that I can make sure I am running the same setup you guys recommended.
Old 04-29-2008, 05:55 AM   #1303
air8's Avatar
I can't answer that right now. My vehicles are home and I'm at work. Don't worry though, micrors4guy and tex1 are great people to listen to. I have been learning from them for the last year. They know what they're talking about and they will provide an answer very similar to what I could find for you.
--"U Ain't Fast!!"
Chris Pearce
Old 04-29-2008, 06:32 AM   #1304
badassrevo's Avatar
Thanks, I just ordered them from AMain.
Doug Lightcap
Old 04-29-2008, 08:02 AM   #1305
the differance is that the buggy stock toe plate is 3 toe 2 anti, where the truggy is 3 anti 2 toe. The adjustable plates with 0 inserts set it to 3 anti (I believe) and 3 toe ( know this for shure)
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
