Old 04-21-2008, 04:37 PM   #1261
Nik
Nik's Avatar
Originally Posted by air8 View Post
On the center rear CV joint coupler. I noticed that if the pinion is allowed to move back and forth there is a notchy feeling when the pinion is pressed rearwards towards the crown gear. But if the pinion is pulled towards the front of the truck it is smooth as butter. So I moved the set screw on the CV coupler back on the pinion shaft so it would hold the pinion away from the crown gear a bit. But I didnt' get the coupler too close to the pinion bearing and cause over heating.
Just FYI
The pinion gear should be as far forward as it can go and should not be able to "walk".
I have been having a problem with the coupler, it keeps wanting to pull off the pinion. The set screw is kept tight and it is lock tighted but in the middle of the race the rear driveshaft will pop out the the bearing will be lost. I really don't know why
Nik is offline   Reply With Quote
Old 04-21-2008, 04:40 PM   #1262
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Inspect the coupler arround the threads. I had one on my buggy that accually cracked and did exactly what you are saying. THe force of the drive train trying to spin caused the hole screw/part that is cracked to lift and move arround.
micrors4guy is offline   Reply With Quote
Old 04-21-2008, 04:41 PM   #1263
Nik
Nik's Avatar
I have had one crack before also, but this one seems fine. I have a spare so I will just replace it to be safe. Its not worth dropping out of the lead to a crappy little part.
Old 04-21-2008, 07:55 PM   #1264
What aftermarket tires are you guys running on the 8T for an outdoor track with low to medium traction? The stock losi's work OK, but I think I need a bit more traction. Do the proline bowties LPR premounts give more traction? I don't want to spend $80 to find out they are worse than stock.
cherokee180c is offline   Reply With Quote
Old 04-21-2008, 08:08 PM   #1265
Integra's Avatar
bow's will Definatly have more forward bite then the XTT's...Crime's will also work...those are 2 Commonly stocked tires in most racer's arsenal.
Old 04-21-2008, 08:17 PM   #1266
Which hook up more? The crimefighters look very very similar to the Losi stock tires. I thought the bow ties look like the knobbies are a little taller and also a bit stiffer from being wider. Some guys are running badlands at my track, but they look like overkill to me and I think when the track gets tacky they tend to traction roll a lot.
Old 04-22-2008, 06:50 AM   #1267
Integra's Avatar
ur 100% right about the badlands....when it gets tacky ur rollin ALL over the place....Crimes and Bow's are Very Very similar ... small differences between the 2.....Also u have to remember the Losi tires have a tOtally differnt profile to em then say a set of LPR's....so that can also play into how the tires will ride.
Old 04-22-2008, 07:07 AM   #1268
badassrevo's Avatar
I run Panther Gators 38 series on Losi wheels.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 04-22-2008, 07:20 AM   #1269
air8's Avatar
Also keep in mind the compound of a tire can play a big role and that depends on the type of dirt you run on. Sandy, soil, clay, loam,.....etc lots of types of dirt.Integra is spot on with his suggestions. Bowties, XTT, Crimefighters are some good choices to keep ready. Panther's tires work just a well also. Sometimes they are the tire to use cause the other three aren't to your liking.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-23-2008, 08:25 AM   #1270
When you run the crime fighters do u want the standard or half offset? and also i just bought the front and rear hinge pin brace with inserts and was just wondering what people put in for the inserts?
rcfreak03 is offline   Reply With Quote
Old 04-23-2008, 10:00 AM   #1271
gearheadz80's Avatar
You have a P.M. rcfreak
gearheadz80 is offline   Reply With Quote
Old 04-23-2008, 11:44 AM   #1272
air8's Avatar
The wheels you want to buy are the 1/2" offset. Doesn't matter which tires you put on. LOL. Just having fun with you.
As for the inserts the "0" will be a stock setting. You can adjust the anti-dive and rear anti-squat/toe from there. it will depend on what you perfer. Every driver is different.
--"U Ain't Fast!!"
Chris Pearce
Old 04-24-2008, 10:11 AM   #1273
mathsinstrument's Avatar
I just bought a Losi 8T from a buddy of mine and I've got a clutch assembly problem.
I am using the Werks Racing Power Clutch will it fit? I've mounted the clutch on the engine and I can't seem to get the stock 13T clutch bell to fit. When I screw down tightly, the clutch bell using the stock instruction, the clutch bell gets jammed. Am I supposed to tighten it tight or use locktite and tighten it just nice so that it does not jam?
mathsinstrument is offline   Reply With Quote
Old 04-24-2008, 10:18 AM   #1274
I have an 8T RR and have a set up question. The 8T actually turns too well (off power and on power) on our track tending to make the back end loose. I am still using stock tires, and am thinking about going to either crime fighters or bow ties next to try them. I fixed this problem for more balanced handling through the turns by switching to the stiffest front springs that come in the RR kit. The car now turns perfect, but I think I am now loosing time through the bumpy sections of the track due to the stiffer front springs bouncing the car too much. What is the best change so that I can go back to the stock front springs, but tighten the car back up a bit? My first thought was to drop down to the lower diameter sway bar in the back first and if that did not work remove the sway bar altogether. Am I on the right track? I also thought about going from 7/10/5 to 7/10/3 on the diff oils? Am I headed the right way and what change first?
Old 04-24-2008, 10:22 AM   #1275
you can try the longer acerman bar
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
