Old 03-23-2008, 10:11 PM   #1186
Truck_Buster's Avatar
Trader Rating: 63 (98%+)
[QUOTE=rossii;4288623]hi there.
i have been hearing that jp3 pipe is good for truggy application. does any one here know exactly the name of this pipe or the code name to iit?
cheerss
http://www.amainhobbies.com/product_...oducts_id/6992
Losi 8ight 2.0
Truck_Buster is offline   Reply With Quote
Old 03-23-2008, 10:27 PM   #1187
Trader Rating: 16 (100%+)
thanks bro
[QUOTE=Truck_Buster;4288687]
Originally Posted by rossii View Post
hi there.
cheerss
rossii is offline   Reply With Quote
Old 03-24-2008, 01:07 AM   #1188
trvlngman357's Avatar
Send a message via Yahoo to trvlngman357
Default well so far so good
I must admit Im willing to give the buggy a try again now after wheeling the truggy around for a few weeks now. have just one mod left from previous post and thats the trapped steering links, once i get that part in i should be ready for some big racing days. Thanks for all the helpful info ppl I have read all post on this thread and there was some great info in there.
LET THERE BE LIGHT!
trvlngman357 is offline   Reply With Quote
Old 03-24-2008, 02:36 AM   #1189
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
357 -
What part of Texas are you in? I'm in Dallas.
Trapped steering links. Do you mean captured ends for your steering rods?
We have the sets at the shop.
TNT in Plano.
TEX
tex1 is offline   Reply With Quote
Old 03-24-2008, 06:02 AM   #1190
air8's Avatar
May I suggest after doing this that the next weak link is the Front inner hinge pin cover (LOSA4431). There are aluminum covers, of course, and they would be the next step after capturing the rod ends. Just adds to the "Bullet Proof"
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-24-2008, 06:48 AM   #1191
Default correct
i was speaking of the steering linkages I reside in Victoria Tx, I have ordered the king headz hingepin holders front inners and outters. But then i noticed that the captured ones by losi are changeable so the king headz might get put up for an auction unless i happen to get another 8ight buggy. LOL...
LET THERE BE LIGHT!
Old 03-24-2008, 11:05 AM   #1192
I recently went to a standard 3 shoe clutch set-up in my 8T. I am using a mugen flywheel, shoes, springs & Bell but the clutch bell still doesnt totally reach the spur gear. It hits half of the teeth on the bell. Am i doing something wrong? I can get it to reach with gobs of shims but i really dont like all the shims. Any help would be much appreciated. Oh ya and i have the king heads extended motor mount.
Webs215 is offline   Reply With Quote
Old 03-24-2008, 11:36 AM   #1193
air8's Avatar
Did you turn the top blocks around so the arrow points towards the back of the truck. This should move the engine forward the 2mm required to use a 3shoe clutch.
--"U Ain't Fast!!"
Chris Pearce
Old 03-24-2008, 11:53 AM   #1194
Im pretty sure that i did.. I will have to double check tonight. Thanks
Old 03-24-2008, 11:54 AM   #1195
Default i thought of doing this also
but i was told by a guy who races losi that you have to put all those shims in there in order to get the right mesh when using brand other than losi for clutch bell and shoes. lmk what happens with yours for now im still using the losi stuff.
LET THERE BE LIGHT!
Old 03-24-2008, 12:22 PM   #1196
Im gonna mess with mine tonight ill post the results.
Old 03-24-2008, 03:21 PM   #1197
I have the buggy, not the truggy, but it still applies. I run a Mugen flywheel, shoes and springs but use the Losi clutch bell and the teeth line up great.
J.C. Johnson
whoajoe is offline   Reply With Quote
Old 03-31-2008, 03:03 PM   #1198
nitro neil's Avatar
Trader Rating: 73 (100%+)
Default wheels for the 8t
I was wondering if any one could help me out. i just got a 8t and this is already built. is there anything i have to do to it before i finish it off such as rebuilding anything? I also was wondering about the lpr rims i should use standard offset or the 1/2 inch offset. It looks like the wheels that come with the truck have a 1/2 inch offset, but i thinkk that these are standard for losi. Either way i wanna keep it legal thanks
nitro neil is offline   Reply With Quote
Old 03-31-2008, 06:52 PM   #1199
tex1's Avatar
Thumbs up
You need to ensure you have the radio set up right. That is the biggy for the Losi.
Make sure your shocks are full and your diffs are tight and have fluid in them. I have seen the rear diff back away from the housings input gear. The aluminum inserts help this a lot. I would highly recommend these if you have the time and means.
On the shocks, I use an Xray 4mm reammer to open the upper bushings so they rotate freely on the shock mounts. If you grease them up and then put some glue on the bushing then install the shock over it, your bushing will wear instead of the alum shock tops. It is very effective. CA Glue will only bond the alum to the plastic temporarly.
Read my post about installing batteries in the battery holders.
There is a lot of good information on here. Good luck.
TEX
Old 03-31-2008, 07:46 PM   #1200
nitro neil's Avatar
thanks tex, i have went through the diffs and i did put in the aluminum bearing spacers i also did the one for the center diff. i also changed the upper servo saver arm. I will go through the shocks when i get everything installed in the truck. thanks
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
