Old 01-24-2008, 11:51 AM   #1111
air8's Avatar
Some people do use the aluminum, but it seems to be more of a tuning preference. The Losi 1/8th vehicles are very tough. The parts breakage is minimul. I've only seen one broken arm, nasty crash into the edge of a plywood board. I've seen a couple of bent shock shafts.
Everyone I race with seems to be using the plastics still. I've seen one or two guys put some aluminum on, and they report that they didn't notice a difference. Here on Tech some have said they like the way they perform with the aluminum. It's up to you, but the aluminum upgrades aren't necessary. The buggy and truggy are super strong. I'm glad I run these vehicles. I'm one of the many who are hard on their vehicles.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-24-2008, 07:26 PM   #1112
Chumangii , the only things I would suggest are the cnc servo saver top piece and center diff insert. The truck is very durable out of the box.
Rossii,I forgot to tell you that I aslo don run sway bars on my truck with that shock setup I posted.
indaway is offline   Reply With Quote
Old 01-24-2008, 11:02 PM   #1113
RETRO RC's Avatar
Originally Posted by chumanji View Post
Just wondering. Do any of you upgrade any of the 8T's plastic parts into alminium? Is it worth it? If you did, what part did you upgrade and is there is any performance differences? I was thinking of changing the spindles and the brace (upper, front and rear).
Hey chumanji.
don't bother with the ali braces or top plate you don't need them,
but there are a few things you should look into as prevantative wrenching
#1. rear aliminium bearing inserts part# losa4430
#2. ali servo saver top #losa4441
#3. centre diff front bearing insert #losa4442
#4. An ali servo horn for the steering as the plastic insert strips easily
#5. King Heads 7075 or dynamite long life clutch shoes
hope this helps
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 01-25-2008, 11:45 AM   #1114
Thanks for all the feedback. Looks like I gotta change my shopping list a bit.
chumanji is offline   Reply With Quote
Old 02-01-2008, 06:15 PM   #1115
mcheck's Avatar
just finished up the last few details and cant wait to run my new 8T! what fuel are yall running?
mcheck is offline   Reply With Quote
Old 02-05-2008, 08:55 AM   #1116
Default bearing inserts?
I'm not sure of the significance of adding the aluminum bearing inserts. I've got at least a couple gallons through my 8T and still got the originals. Any input on these?
I have went through some serious clutch shoes though. I need to try the long life ones.
Matthew
Crasher is offline   Reply With Quote
Old 02-05-2008, 09:08 AM   #1117
nitroveins's Avatar
Default losi lipo receiver battery
What kind of connector is on the charge/balance lead on this battery? has anyone changed it? and where did you mount the voltage regulator? some pics would be great. thanks
nitroveins is offline   Reply With Quote
Old 02-05-2008, 10:52 AM   #1118
Dookiman's Avatar
Just ordered an 8ight T roller! I need to get some servo's worthy of this truggy...
Does anyone have any experience with Futaba brushless servo's??
FUTBLS351 Futaba Servo-Digital BLS351 Hi-Speed Brushless, 210 oz, .13 sec. 149.95 In Stock
FUTBLS451 Futaba Servo-Digital BLS451 Hi-Speed Brushless, 147 oz, .10 sec. 99.95 In Stock
The 351 for steering, and the 451 for throttle/brake duty???
Thanks for any input!!!!
You gotta love it...
Losi/Werks Racing/AKA/Fastlane Graphix
Dookiman is offline   Reply With Quote
Old 02-05-2008, 12:46 PM   #1119
air8's Avatar
Good Job. And welcome to truggy racing. LOL. I use Byrons just because it's available. I'm happy with it. Our LHS's are going to start carrying the Gen 2 Byrons only. so we'll see how that goes. I'm not too worried though. Most of the fuels out today are great. Shouldn't have any problems caused by fuel.
Matthew
I used the plastic inserts on my Losi buggy for 10 gallons. I wasn't worried about it on my T but I put them in anyways. I have seen a one of the inserts rotate in the diff housing. But I don't know if it was put in correct to begin with. With regular maintenance and cleaning you should catch this before it becomes an issue. The only problem on my buggy was the plastic had loosened up a little and the bearing was moving around slightly. That's why I put the aluminum inserts in.
I believe these are called JST connectors. Many online stores carry them. I usually switch them over to a regular JR/AIR reciever plug. But there is a possibility of plugging something in wrong. To set yourself up safely, make up an adapter for your charger and one that can plug in to the RX or on/off switch if you use one. If I find some time tonight I can post up pics of my regulator setup. On the truggy tray I moved my on/off switch to the outside of the tray. This opened up some room to put in the regulator and all the wiring. But on the buggy I got everything to fit. Go figure. LOL.
No reason those shouldn't work. Although I think the 451 is plastic geared???? Not for sure on that one. Using metal gears is just a little more insurance. It does not detract from the servo's performance or durability. And sometimes the plastic is perferred. That way the gears go out before the electronics....hopefully. LOL.
--"U Ain't Fast!!"
Chris Pearce
Old 02-05-2008, 12:54 PM   #1120
gearheadz80's Avatar
gearheadz80 is offline   Reply With Quote
Old 02-05-2008, 03:48 PM   #1121
Integra's Avatar
Originally Posted by gearheadz80 View Post
little late on that 1...that was out late last week.
Old 02-05-2008, 03:55 PM   #1122
mcheck's Avatar
what are the main differences between that chassis and the race roller? is it necessary to change it?
Old 02-05-2008, 05:08 PM   #1123
LOW ET's Avatar
Trader Rating: 95 (100%+)
that one will flex more.
LOW ET is offline   Reply With Quote
Old 02-05-2008, 09:44 PM   #1124
Trader Rating: 16 (100%+)
i thought that flexible chassis is for the 8buggy not for truggy ?
perhaps they have it for both buggy and truggy?
by the way any news bout new 8buggy chassis kit? heard its gona be a
new release by losi...
rossii is offline   Reply With Quote
Old 02-05-2008, 10:27 PM   #1125
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I use the BL451s for both steering and throttle duties in my buggy. I really like them, but I changed because they were digital, and it made setting up the failsafe with the 3PKS much less of a hassle, and that let me use HRS mode. The servos were faster than my Airtronics 358s, but the Airtronics servos were also 1-2 years old (or older as I bought 2 of the 4 I had used) For throttle in a truggy, the BL451 is great, but I would recommend more torque for steering, perhaps a JR 9100T Even the JR9100S should be enough torque. The BL351 should also be an excellent servo. There really is not much to say about a good servo except for the already stated: its good.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
