Old 01-18-2008, 10:08 AM   #1081
From time to time we have to pat ourselves on the back... this is one of those times. Thanks Adam for even giving us the opportunity!!
www.upgrade-rc.com
Ryan Pursley
Upgrade/ RCiD
ryan@upgrade-rc.com
www.upgrade-rc.com
661-259-8772
ryno1922 is offline   Reply With Quote
Old 01-18-2008, 10:17 AM   #1082
Integra's Avatar
www.upgrade-rc.com
when can we expect these to be in stock ?....Looks KILLER btw.
Old 01-18-2008, 04:53 PM   #1083
luisv's Avatar
That's a sticker kit? WOW... looks awesome!
8ight TE 1.0 | MM2 2200kV | Spektrum
8ight TE 3.0 | MM2 2200kV | Savox | Spektrum
Ten-SCTE 2.0 | HW Pro SCT | Spektrum
luisv is offline   Reply With Quote
Old 01-19-2008, 04:26 AM   #1084
wow looks pretty sweet
team losi guy is offline   Reply With Quote
Old 01-19-2008, 08:48 AM   #1085
Rossii, try #55 pistons all the way around with 40wt oil. I felt the kit setup
was a little unbalanced for me.
indaway is offline   Reply With Quote
Old 01-19-2008, 09:05 AM   #1086
Vigilante212's Avatar
The drake makes me think seinfeld
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 01-19-2008, 05:52 PM   #1087
air8's Avatar
oooh, oooh, ooooh. My local RC hero. Hey Rossi, this guy is awesome. He is the one everyone in my area chases. Many have challenged, but few have succeeded. LOL. Indaway really knows the in's and out's of RC racing overall. I'm lucky to have chosen the Losi platform cause I get to hang out with him on the weekends. LOL. I learn A LOT!!
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-20-2008, 12:04 AM   #1088
Trader Rating: 16 (100%+)
Default yozz
oh i c. good good good. i may want to try tat. i feel the car tend to swift side to side when i corner as well as flip when landed.
how bout spring, do u do any changes to it? stil rear grey and front black?
some people say its bout experience and finger throttling.
rossii is offline   Reply With Quote
Old 01-20-2008, 12:52 AM   #1089
air 8. u r lucky to have the same group of people playin the same car .
i guess perhaps i should learn more on finger throttle than start to change the setup. but i do agree bout the rear oil is bit soft.
car tend to swift all around.
Old 01-20-2008, 10:32 AM   #1090
Rossi, I moved th rear camber link to #1,A. It seemed to help keep the truck from rolling around on the rear end. The truck would keep rotating when I came out of a corner. After I moved the link it seemed to drive a little more square.
Old 01-20-2008, 05:42 PM   #1091
OH you hav adjusted the camber link as well. i got to check hte #1,a is outwards or inwards.not too sure bout this. yeah i dun quite like the look of the truggy swifting the weight around. its appear sluggish.
Old 01-21-2008, 12:19 AM   #1092
Suspended
Default Losi 8 Pro Roller
Does the pro roller come assembled someout out of the box?
snowboarder0322 is offline   Reply With Quote
Old 01-21-2008, 05:05 AM   #1093
The pro race roller comes with a clutch and flywheel and radio box. The radio box you have to put in your self and the rest comes assembeld. Then you just gotta put all of your electrics and motor in it.
The race roller is a really sweet i car I love mine
Old 01-21-2008, 05:10 AM   #1094
GSP
Default Losi 8 T RTR
Is it a good deal for what you get for club racing? I have been doing the math and the way it works out for me is the RTR is what fits my budget. I also do have a few questions
1. First question is for weekend club racing what upgrades would I need to get for the RTR?
2. What is everyone using in there diffs. Weight?
3. Steering servo with the kit ok or shoudl I up grade?
Any other info or upgrades that you may think of please let me know. The RTR I believe is the best way to go for everything you get along with the radio and I can afford a few upgrades for the RTR at the price it is. My budget is under $1000.00 for everything.
Thanks for the info!
Thanks for all your help and info.
GSP is offline   Reply With Quote
Old 01-21-2008, 05:48 AM   #1095
tex1's Avatar
Send a message via Yahoo to tex1
Questions?? You don't need everything at once.
The RTR does need a couple of things changed for running it on the track.
1. Run the stock steering servo on the throttle.
Put a peice of fuel tubing on the pull side of the throttle linkage and tune for no over travel. Search for my other post in the 8ight forums.
You must use the grommets and inserts in the truck's servos.
2. Get you a good steering servo like a JR, Futaba..... They are $120
3. Get an aluminum servo horn for your selected steering servo. $15
4. Get diff and shock oils. (This is just a starting point.)
Diffs are 10K - 10K - 5K or 10K - 20K - 5K from the front to rear.
Shocks are 60 - 40 and get plus or minus 5 wt for each. $45
5. We have been running Black spring on the front and White springs on the rear. I'm not sure of the springs for the RTR so you need to check. $20??
Later you will change other stuff.
6. Get it on a starter box. You will need multiple things to do this.
Engine mount - Stock low mounts will work. The best is the King's Headz extended mount. It is easier to work with and will protect your clutch bells and spur gears. $18 - $56
You will need a back plate for the engine. $14
Get you a good box - Think about the future here. The Losi box is a great one. $120
7. Get a new throttle servo (smooth is key here!) $90
8. Tires and wheels - Run what works and lasts. You will not be the fastest until your learning curve is overcome. Do not buy Hole Shots! They may work but they won't last. Ask your track buddies.
These are just opinions and is how I would go about racing a RTR truck. Take the time to read this and the 8ight's entire forum. There is a lot of good information there that will help you.
Have fun,
TEX
tex1 is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
