Old 12-01-2007, 04:22 AM   #826
air8's Avatar
You mean fuel tube between the brake pads? I tried the small spring idea before but I never noticed and improvement, so I removed them. I'm not for sure what this mod is for. maybe to keep the brake discs from heating up/or reducing any chance of drag? IDK. But glad to see you're well on your way.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-01-2007, 04:57 AM   #827
Hellsavage's Avatar
Its just to eliminate any drag.
I noticed a big difference when she is on the box. When I turn one wheel by hand she just spins absolutely free from any drag.
Whitout the tubings apy the brakes and let go I turn a wheel and I kept feelling something draging.
2nd advantage is that there can not get any dirt on the bolts so the brake pads stay free to move.
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 12-01-2007, 07:42 PM   #828
Are you guys running the 4 carbons and 4 gold springs on the truggy too? or just the buggy?
B_Wheeler is offline   Reply With Quote
Old 12-01-2007, 11:52 PM   #829
RETRO RC's Avatar
Originally Posted by Hellsavage View Post
I made some pics I have everything up and running.
mzl Hellsavage
hey hell savage you should also rotate the ball on you carb to straighten out the linkage as youv'e got some wicked angle on it man
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 12-01-2007, 11:59 PM   #830
air8's Avatar
Haven't tried this yet. Maybe next summer.
--"U Ain't Fast!!"
Chris Pearce
Old 12-02-2007, 05:33 AM   #831
Hellsavage's Avatar
Just to be sure. I need to turn in counterclokwise?
Thanks fore the reply.
mzl Hellsavage
Old 12-02-2007, 05:37 AM   #832
Hellsavage's Avatar
I have on experiance with the Losi cluch. I always use Werks cluch and they work very wel fore me.
4 carbon and about 8 gallon on a set of shoes.
mzl Hellsavage
Old 12-02-2007, 03:30 PM   #833
has anyone tried the pro line premounted tires on the 8t?
reddishdsb is offline   Reply With Quote
Old 12-02-2007, 04:11 PM   #834
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
i use bow ties on my 8t in XTR compound, not the premounts but that doesnt matter
they grip so much more than the stock 8t tires and last a lot longer aswell
12a_rx2 is offline   Reply With Quote
Old 12-02-2007, 06:31 PM   #835
air8's Avatar
mzl Hellsavage
Yeah, counter clockwise. But just a tad
Lot's of people here have been loving the XTT tires. They last a long time and work so well on many tracks/several types of surfaces. The premounts won't be much different than the un-mounted tires. I assume you're referring to the LPR wheels/tires. The LPR tires will be the only Proline tires for me from now on. I'll be using other brands, but from PL the LPR will be the ones to get for this truggy. If I get to a really rutted track I might use MTR tires.
--"U Ain't Fast!!"
Chris Pearce
Old 12-02-2007, 08:28 PM   #836
RETRO RC's Avatar
mzl Hellsavage
looking at your second pic you need to turn it clockwise NOT counterclockwise
Old 12-02-2007, 09:19 PM   #837
air8's Avatar
MY BAD!!! GO CLOCKWISE A LITTLE. You have it close now. But to be perfect, and no one can blame a problem on your setup, adjust it a little. Thanx Retro RC, I should have went back and actually looked at the picture.
--"U Ain't Fast!!"
Chris Pearce
Old 12-02-2007, 10:57 PM   #838
So me and a friend are looking to get into Truggies, and after reading up on RTR kits we have found the 8t rtr to be the best out there...
With that being said, after purchase, what are some things we should check/change to eliviate the problems that I keep reading about...(i.e. blowing servos, clutch issues, etc.)
Also what are some upgrades that you guys would advise of to make it more competitive on raceday?
We both race 1/10 nitro on road right now, so we know little about off road, but know about nitro, and rc..
thanks in advance,
Brandon
Oww teeth is offline   Reply With Quote
Old 12-02-2007, 11:15 PM   #839
air8's Avatar
Here is a start. I'll be back with more.
Originally Posted by tex1 View Post
Air8,
There are a couple of things you can do to make the vehicle more race bullet proof.
  1. Servos - Only use coreless versions that can be closed by a simple spring or rubber band.
  2. Use fuel tubing on the throttle linkage to compensate for when the chassis flexes and you are at full throttle.
  3. Space the servos up and get the rubber ear boots on.
  4. Take the servo saver and relocktight it after it is set.
  5. Throw the steering servo horn in the trash and get the Losi alum one.
  6. Capture the ends of the steering linkage.
  7. I suggest running the Kings Headz extended motor mount to protect your clutch bell and spur gear.
  8. Put a peice of thick lexan over the foam in your battery box to make a rigid floor.
  9. Surround the batt in foam so it wont move.
  10. Never run solid tabs between the cells on your batteries! They are a failure point. Go with old school braid and shoe goo. The battery will never come apart but it can flex if need be.
  11. Shoe goo the inserts into your shock tops. Ream out the insert so it rotates freely on the shock mount and apply grease between the mount and insert. Now your shock tops will not wear out.
  12. Go with the Losi alum servo saver top. The plasic will now wear on the alum as much and you will not have to service it all the time.
  13. Get a smaller switch than what comes with it. Those big switches go out all the time.
  14. I do not run switches because of this reason.
Hope this helps,
TEX
--"U Ain't Fast!!"
Chris Pearce
Old 12-02-2007, 11:16 PM   #840
air8's Avatar
Roller to RTR differences
[QUOTE=air8;3752118]For people wanting to know the difference between the Roller and the RTR
Originally Posted by ShotGunn View Post
Does anyone know of a complete list of the differences between the RTR an the pro...
SHOTGUNN----
Aside from the obvious engine, pipe and electronics here is a list. I have not seen the RTR in person so this is going off the differences on the 8 buggy.
shock towers, shock caps, shock shafts, shock pistons, shock springs, shock seal retaining caps (lower caps), hinge pins, hex drives and wheel nuts, chassis, diff grease (instead of diff oil), steering hinge pins, sway bars, engine mounts, clutch bell, and clutch shoes.
Also I assume the body come painted on the RTR.
--"U Ain't Fast!!"
Chris Pearce
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
