Old 11-13-2007, 12:53 PM   #781
air8's Avatar
DUDE, there is a for sale thread on this site.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-13-2007, 03:11 PM   #782
mcsquish's Avatar
Lat weekend was the first time out for me and my truggy. That this is sweeeeeet!! It sounds like I'll be getting stock in a bearing company though since I was told that the clutch bearings go out.
My only thing I am wondering is there better aftermarket brake disks? I had some serious brake fade in my main.
mcsquish is offline   Reply With Quote
Old 11-13-2007, 03:26 PM   #783
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
Originally Posted by air8 View Post
I suggest to check the diff case for wear. I ran my buggy for 7 gallons before I put the aluminum bearing inserts in. I had not lost a bearing prior to that, but the diff case did let aluminum inserts move too much for my liking. So I put new diff halves in just to be on the safe side. Now I'm at 13 gallons on the buggy with no issues at all with any of the diffs. Do you have the aluminum inserts? I put them in the truggy before it ever ran, so I don't know how long the plastic inserts would have lasted.
yep i got the alluminum inserts, put there in there before i even drove the thing.
i might get a new set of casings just to be on the safe side, but yeh they havnt done that much work.
just put the alluminum inserts in the buggy aswell after they went ill have to see how its cacings are holding up.
12a_rx2 is offline   Reply With Quote
Old 11-13-2007, 03:31 PM   #784
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Scott, You use the brakes?!
Part # LOSA3542 Losi HD brake disc set
That should do the trick
SCUBA STEVE is offline   Reply With Quote
Old 11-13-2007, 07:27 PM   #785
air8's Avatar
Good to hear you're having a good time. Just be sure to set the clutch shimming close and the gear mesh and you'll get close to a gallon with a set of bearings with regular maintenance. it's a lot of work to get them to last close to a gallon. I've had one set of buggy bearings last a gallon. But never longer.
--"U Ain't Fast!!"
Chris Pearce
Old 11-13-2007, 08:48 PM   #786
A.C
A.C's Avatar
Send a message via MSN to A.C
ok out of the box Losi 8T the pro kit, what are the stuff that need to change?
pls advice.
A.C is offline   Reply With Quote
Old 11-14-2007, 05:34 AM   #787
air8's Avatar
Nothing NEEDS to change. It's tough as it is. But like all 8th scale vehicles there are things you can do to make the truck bulletproof.
Captured rod ends for the steering links
Front inner aluminum hinge pin cover
Aluminum rear diff case bearing inserts
Aluminum servo saver top
Aluminum steering servo horn
Follow all suggestions for setting up the servos
Put a piece of foam or lexan in the bottom of the battery box
For ease of maintenance a quick change engine mount works great. I think all 8th scales should come with this.
--"U Ain't Fast!!"
Chris Pearce
Old 11-15-2007, 06:15 PM   #788
mcsquish's Avatar
Thanks Steve, why didn't you tell me this last week?? I had to use brakes, you were lapping me too fast and I didn't want to hit you.....
Thanks air8, I'll keep an eye on it.
Old 11-22-2007, 09:54 AM   #789
air8's Avatar
I'm hoping to run the truggy this weekend. It's been a long time since we had a race around here. I'm itching to run nitro.
--"U Ain't Fast!!"
Chris Pearce
Old 11-23-2007, 11:02 PM   #790
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
I am wanting to purchase a 8T RTR but the throttle servo problem is freaking me out abit. I plan on using the Standard steering servo for the throttle, run a KHZ Stiffner http://www.amainhobbies.com/product_...ducts_id/11534 and GMK washers http://www.amainhobbies.com/product_...ducts_id/12291 and put a ink pen spring instead of the standard spring and then of course follow the epa adjustments. How long will it be till I have to get a new servo and then another one after that?
Drift_Buggy is offline   Reply With Quote
Old 11-24-2007, 12:53 AM   #791
Trader Rating: 22 (100%+)
My 8T seems to have a lot of play in the steering linkages somewhere, might this be a common problem with these trucks or do I simply have worn out parts that need to be replaced? I bought it used...haven't driven it yet but hope to soon. This is one of the things that caught my eye though...and would like to get it figured out before I do any serious driving. Also the gear mesh is bugging me, I can't seem to get it tight enough (I think). The clutch bell teeth look a lot different than any other clutch bells I have though. Maybe it's because they are worn out?
revo_race is offline   Reply With Quote
Old 11-24-2007, 08:18 AM   #792
air8's Avatar
There is a bit of slop in the Losi's when they are new. My 13 gallon buggy is very loose and the 3 gallon truggy has quite a bit of play. If you feel the slop is causing issues after running it, then replace the plastic for peace of mind. It's kind of hard to determine what you feel is sloppy, so I say just run it. It's offroad.
--"U Ain't Fast!!"
Chris Pearce
Old 11-27-2007, 03:57 PM   #793
dol
dol's Avatar
im still using my stock servos no issues
as long as you set you epas and rotate the carb slider as far from the center diff as you poss oh and space the servo up a bit so it doesent hit the chassis it should be all good not that hard just to wack a new servo in any ways
my rtr is the best thing i ever brought
Run it,Race it,Skid it,Drift it,Jump it... RC baby
dol is offline   Reply With Quote
Old 11-27-2007, 05:22 PM   #794
air8's Avatar
It's good to hear good fortune on here. Most of the time it's about repair/broken parts and how to fix it. I'm glad you have everything set good and that it's to your liking. I really enjoy my T. So how much run time do you have DOL?
--"U Ain't Fast!!"
Chris Pearce
Old 11-27-2007, 05:42 PM   #795
jgtruggy's Avatar
If your having problems with your servos check out ACE servos. I have a DS1015 for my steering. I bought this digital servo with over 200oz.of torque after the cheap JR servo went out after an hour. This servo now has about 10 hard hours on it with no worries. I love my 8T RTR and am transforming it into a racerLOL.
jgtruggy is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
