Old 10-28-2007, 04:46 PM   #766
dol
dol's Avatar
mite take you up on that my parts arent due till late next week
i think i can get braces & pins but no shock tops
but i dont think im any where near ready too keep up on the track
will have to see
Run it,Race it,Skid it,Drift it,Jump it... RC baby
dol is offline   Reply With Quote
Old 10-29-2007, 01:20 AM   #767
RETRO RC's Avatar
will have to see
RCB in Auckland has stock of hinge pins, braces and shock tops unless something is wrong on Matts web site so Brett should be able to get them for you asap as Matt and Brett are sending parts to each other every day
RETRO RC is offline   Reply With Quote
Old 10-29-2007, 04:45 PM   #768
dol
dol's Avatar
just txt him parts due tomorow
will have to post sum pics
prob a good idea for those with the rtr to replace these parts
the race roller parts seem to be a lot stronger
would only take a good hit in to the pit wall to brake the rtr parts
picks tomorow
Old 11-01-2007, 06:53 PM   #769
Trader Rating: 16 (100%+)
Default rebuilding of shocks and differential
hi to all losi truggy owner. once u goys receive your race roller truggy, do u guys rebuild or check on the shocks oil and the 3 differential? just to see if the diff oil is enough as well as the shock oil?
by the way any idea what is the weight of the front ,center and rear diff oil weight?
rossii is offline   Reply With Quote
Old 11-01-2007, 07:06 PM   #770
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
7-10-5 front to rear, well if my center diff wasnt empty. I also had a few stiped out screws.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE [email protected] (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 11-01-2007, 11:48 PM   #771
tex1's Avatar
Send a message via Yahoo to tex1
Red face
I would always recommend rebuilding the race rollers. I don't trust other people with my race setups. They tend to over look things. My diff had a bad leak in the rear. The middle one was only half full. Shocks were good.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 11-02-2007, 01:05 AM   #772
Default i c. tat was on my thought too
Hope this helps,
TEX
yup. i should say tat we should do a thorough check up on the diff and shocks oil. i guess i wil need to double check all the entire car b4 running.
Old 11-11-2007, 11:19 AM   #773
air8's Avatar
Now that I am used to running this truck it's time to step up the power. I'm gonna try one of the high end engines and see how things go come spring time. I'll be able to have it broke in at almost anytime of the year. There are a few months it wouldn't be comfortable though. But this truck is so easy to drive that I feel like I'm ready for some real power. HE He Heh
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-12-2007, 03:38 PM   #774
dol
dol's Avatar
is it just me or does the rtr have diffrent wheel nuts to the rr?
Old 11-12-2007, 04:59 PM   #775
air8's Avatar
That's correct. The RTR Losi's have blue hexes and wheel nuts. The Kits', and Race rollers have the hard anodized gun metal color. I think I posted this a few pages back. But it's hard to see in the paragraph that lists all the differences.
--"U Ain't Fast!!"
Chris Pearce
Old 11-12-2007, 06:19 PM   #776
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
air8 which version of the 8t did you start with? What engine have you been running? I am in the wichita area and may be getting a truggy again....lol
Jeff
Jeff Werner is offline   Reply With Quote
Old 11-12-2007, 11:59 PM   #777
dol
dol's Avatar
yea i lost one racing on Sunday ended my day
i was just starting to get the hang of it too
(note to self tighten before each race lol)
one of the other guys had a spear but it wouldnt fit ??
must have just been me cuz the new ones i got fit and all.
odd
Old 11-13-2007, 12:16 AM   #778
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
damm bearings went in my rear diff the other day during our state final wrecking the ring gear and pinion :flamin
the car had only done 1 race meet prior and thats it. didnt expect them to go so soon.
had the same thing happen the day before in my buggy aswell but those bearing had almost 12 months on them
12a_rx2 is offline   Reply With Quote
Old 11-13-2007, 05:49 AM   #779
air8's Avatar
Jeff
Nice to meet you. I'm ready to race this truggy again. Hope to race against you soon. I hope we have some good weather so Marc at Amain will have some more races. That track is fun. I started with the Race Roller. I was using an OS VG .21 that I traded a good friend for. But somewhere it ingested dirt or something. At our Nitro Fall classic the engine would not tune or idle. I tore down the engine and saw lots of scratches on the piston and sleeve. IDK. But that day I had left the Mach 427 from my RTR buggy at home. Doh! So I didn't get to race truggy that day. I'm leaning towards the GO Tech engines (just to try) or the Nova Plus 21 5K. The balanced crank 5 port. The OS 21 was a good match for me at the time, but the T is so easy to drive that I'm ready for some big oomph.
odd
I lost one also on my second race. The thread lock goes away pretty fast. I added a spot of thread lock every other weekend just to be safe. Don't let the dried thread lock build up too much. Might get difficult to put the wheel nuts on straight. But good thinking on tightening before your race. Just think about how easy it is to check for tightness. Why DNF cause of that? You learned a lesson. LOL. But so did I. I hate when the simple things take you out.
I suggest to check the diff case for wear. I ran my buggy for 7 gallons before I put the aluminum bearing inserts in. I had not lost a bearing prior to that, but the diff case did let aluminum inserts move too much for my liking. So I put new diff halves in just to be on the safe side. Now I'm at 13 gallons on the buggy with no issues at all with any of the diffs. Do you have the aluminum inserts? I put them in the truggy before it ever ran, so I don't know how long the plastic inserts would have lasted.
--"U Ain't Fast!!"
Chris Pearce
Old 11-13-2007, 12:28 PM   #780
For Sale a Brand new set of Team Losi Eight Shocks.
These are Brand new, built but never run. Along with the Shocks will
come extra springs, o-ring set, 2 new sets of Shock Piston's, one new
set of Rear Shock Body's, New set of Shock caps, Shock Adjuster nuts,
and rear Shock Shafts. All spare parts are new, still in original
packaging. I am asking 60.00 shipped to the lower 48 states. If you
have any questions or would like to see pics email me at
[email protected]
IMTK422 is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
