Old 09-14-2007, 12:51 AM   #646
air8's Avatar
OOps from me to. Dam you're fast. If you have the RTR the Mach engins will be fantastic. Mine is 12 gallons old and hasn't been pinched or resleeved. All original. But I think it is losing it's power now a days. But my Mach came in my buggy RTR.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-14-2007, 12:53 AM   #647
freefallmarine's Avatar
Air, if your loosing compression in the mach, just start removing head shim's. itll bring the compression back.
freefallmarine is offline   Reply With Quote
Old 09-14-2007, 01:11 AM   #648
air8's Avatar
Ok. Never thought of that either. Won't that run a bit different? I see detonation, but I could be wrong.
--"U Ain't Fast!!"
Chris Pearce
Old 09-14-2007, 01:18 AM   #649
It's not good for it but hey', its got 10 gallons.... Run it till she blow's.....
Old 09-14-2007, 01:27 AM   #650
air8's Avatar
I wish I understood the chassis/suspension adjustments better.
Bumpsteer
Camber links
Well, that's it really. I need to research what to expect from the adjustments.
--"U Ain't Fast!!"
Chris Pearce
Old 09-14-2007, 05:38 AM   #651
tex1's Avatar
Send a message via Yahoo to tex1
Post Chassis setup....
Bumpsteer - in the Losi is on the inner steering link ball placement. If you want the car aggressive when the weight is transferred to the front (ie - under braking) you run the ball in the high position. If you want it a little mellower then you run the ball in the low position. It all has to do with your outside front when you are loaded going into a corner. Set it on your table and check it out. It is a very cool little adjustment.
Camber links - control what is known as roll center. Your tires move up and down with the articulation of the suspension arm. Where that tire rolls over because of the upper link being shorter is your relative roll center. The more you shorten your upper link the lower your roll center is. The tire will gain negative camber quicker as the suspension arm is moved upward. As you side load a given tire, a lower roll center (shorter camber link) will take away (side bite) traction during compression and a longer camber link will increase traction.
Keep in mind this is what makes a car steer, rotate, grab and even traction roll. If you have too long of a link and the tire stays straight up and down you are going to get the side wall effect of the tire you are running. That can be good or bad and is totally dependant on the tires and wheels you run.
Hope this helps,
TEX
<------ We are not done yet!
tex1 is offline   Reply With Quote
Old 09-14-2007, 12:07 PM   #652
air8's Avatar
Thanx Tex, that was pretty good.
--"U Ain't Fast!!"
Chris Pearce
Old 09-15-2007, 04:20 PM   #653
Tex, Good Luck at RC Pro!!!
Old 09-15-2007, 09:40 PM   #654
tex1's Avatar
Red face Long day......
Carl,
It looks like I'm bottom of the B. I have 5 whole tanks of driving on the track right now. We were told that there would be a practice session today from 8 - 9 for the guys that did not get to practice yesterday. I put my car on the track at 8 and they closed the track down right after that.
I got faster every round so its all good.
Car is handeling great.
Losi and Xrays are ruling the roost right now.
Thanks,
TEX
Old 09-16-2007, 02:11 AM   #655
RETRO RC's Avatar
Originally Posted by babloo View Post
Thanks. In the maunal the setup sheet says bump steer either up or down. What do they mean?
Hi babloo
what they are refering to is the inner ball on the steering arms it has a flange on 1 side of the ball only, that depending on wheather the flange is up or down can effect the bump steer caracteristics by shortening the steering throw at the top or bottom of suspenstion travel ( it makes the steering piont out at the top or bottom of the suspention travel)
tex's post has the examples of how this effects the handling-steering on the Losi's
hope this helps
Adrian
RETRO RC is offline   Reply With Quote
Old 09-16-2007, 03:37 AM   #656
Originally Posted by air8 View Post
Hey babloo, reading is the best way learn about these vehicles. And don't be afraid to ask. No such thing as a dumb question. Have you raced your truck yet?
Hi. just ran 2 - 3 tanks. The os is fast. Even thou we have not tuned it yet. We have been battling in starting the os thou. The os that i have has to use a starter box. Now since the os is brand new the piston gets tight, which the guys at my hobbie shop said is excellent because of compression. The starter box will not turn turn the motor becuse of this. To overcome this we have to heat the motor with a heat gun or hairdryer and then she will fire up. Must say the 8ight T takes all types of terrains and handles beautifully. Keep you posted once the engine is fully run inn.
Losi 8ight T Race Roller
O.S. .21 VZ-B V Spec T
Spektrum DX3.0
Dynamite 053 Midrange
babloo is offline   Reply With Quote
Old 09-16-2007, 03:39 AM   #657
Hope this helps,
TEX
Thanks Tex
Spektrum DX3.0
Old 09-23-2007, 01:43 PM   #658
ShotGunn's Avatar
Our friends at crc are fans of the Losi 8ight an 8ightT,they have a fix for the steering rod ends popping off problem..teamcrcdotcom
ShotGunn is offline   Reply With Quote
Old 09-23-2007, 09:55 PM   #659
air8's Avatar
Not to burst your bubble, but this was talked about a while back. I personally saw Steve Slayden do this to a truggy he was racing in OKC back in June. It works great. The CRC link has what looks like Traxxas pivot balls which the Revo uses all over the place. A few months ago someone on the Losi 8ight thread posted what they used and it was the 6.8mm inner steering rack pivot balls with a 5-40 screw and 5-40 washer. So simple it's crazy. But when doing this mod the next weakest link is the front inner hinge pin cover. I eventually went to an aluminum front inner cover cause the plastic ones only lasted about 4-5 laps. I have done this to the 8 and 8-T and they are bullet proof ever since. I actually drove my T for 15min. total until I switched it over to the captured rod ends.
--"U Ain't Fast!!"
Chris Pearce
Old 10-03-2007, 11:52 AM   #660
air8's Avatar
OK. I read something new today. Saw someone on here talking about "vibration problems" on the 8T. Has anybody heard of this before? As far as I know every nitro powered vehicle has vibration problems. But also this "vibration problem" is apparently causing the batteries to fail?!?! I have NO idea when the T started getting blamed for vibration killing batteries.
--"U Ain't Fast!!"
Chris Pearce
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
