Old 09-03-2007, 12:04 PM   #601
mcsquish's Avatar
Cool, thanks for the info. The friend I got it off of went nuts on the after market goodies, and the suggested upgrades are covered. Thanks
mcsquish is offline   Reply With Quote
Old 09-03-2007, 12:20 PM   #602
air8's Avatar
Also inspect your servo saver adjusting nut to make sure it does not back off. Use lock tite if it is backing off.
This truck rocks! I used PL holeshots mounted to Losi rims without modifying the tire carcass. This setup hooked up excellent this weekend. I used an O.S. 21VG (stock) with a JP-1 pipe. Tons of power and tons of traction. Paired together with the 8T, so sweet. LOL. I'm stoked that this truck does so well. The buggy is super dialed also but there are so many fast drivers it's hard to keep up. I'm very happy to do so well since I've only been racing since February. Woo-hoo!
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-03-2007, 01:12 PM   #603
freefallmarine's Avatar
Air8, Seem's you like the truggy... Now we just need to find a race that will take 2 sportsman hacker's..hehehe.....Glad your havin a blast..
freefallmarine is offline   Reply With Quote
Old 09-08-2007, 01:20 AM   #604
air8's Avatar
I've only driven one other truggy and that was a CRT. So it wasn't exactly set up for me, but the 8T feels like a dream. It seems to know what I want it to do. Awesome feeling. I can't wait for the "Hackers R Us" race. LOL. Seriously this truck is easy to drive fast. I can see how developing driving skill would be hard with this truck. I don't mean to put it down but you don't have to maintain an exact line or rhythm like 10th scale or even 8th scale buggy. Its fun, that's all I can say.
--"U Ain't Fast!!"
Chris Pearce
Old 09-09-2007, 02:22 PM   #605
XrayRacer's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to XrayRacer
I ran my new 8T for the first time yesterday, LOVED IT!!!! I was wondering those if anyone elso was having troubles with the rear shock ends? I managed to break 2 of them, which were on the right rear wheel both times. Someone who races a Mugen says it was the way I was landing. The jumps were not very large at all. So if anyone one has any tips for me, I'm listening.
- Clark
XrayRacer is offline   Reply With Quote
Old 09-09-2007, 03:09 PM   #606
air8's Avatar
I use the droop screws in the rear to keep the shocks from fully extending. I set the screws so they just touch the chassis and then adjust each weekend as needed. When the shock ends pull apart I just reset the droop screws and they do fine for several months till the chassis becomes recessed from the screws. I suggest trying this and see how it works out.
--"U Ain't Fast!!"
Chris Pearce
Old 09-09-2007, 03:22 PM   #607
XrayRacer's Avatar
Makes sinse. Thanks Air8. Oh! my 8T did have grease in the diffs. I changed them to the 7-10-5. Which was a lot better. Do you or anbody else have any other set up tips for it?
Old 09-09-2007, 03:32 PM   #608
air8's Avatar
One other thing I tried and stuck with is moving the rear camber link to the 1 position on the shock tower. Stock setting is 4. I did a few add ons to make it stronger. I had a crash course with the buggy so I knew the possible weak points. Alum servo saver top, alum center bearing adapter, captured ends for the steering link, alum front inner hinge pin cover, alum rear bearing inserts. I also added teh extended King Headz engine mount but that was more for convenience. Oh I put a screw in the unused hole for the lower shock screws. In the buggy they would back out fast.
--"U Ain't Fast!!"
Chris Pearce
Old 09-09-2007, 03:36 PM   #609
air8's Avatar
Oh yeah, make sure to use loctite on the center driveshafts where they attach to the pinions and then wrap with shrink wrap. On the front be sure to trim away any extra shrink wrap that might rub on the steering servo horn. That reminds me again, I use an aluminum steering servo horn. The plastic one broke on the buggy twice. Racers edge sells them two to a package and that helps if you're using the same servo spine count between the two vehicles.
--"U Ain't Fast!!"
Chris Pearce
Old 09-12-2007, 12:24 AM   #610
air8's Avatar
Man, I have been jonesing to drive this thing for a while. Our last race was a week and a half ago. My T is runs very strong with the O.S. 21 VG. It has the right amount of traction and power for the tracks around here. I need to do some pipe testing with it though. I only have the JP-1 pipe for it and seems to lack slightly on the top end. Might be a good thing though. I can't overshoot the corners as easily. LOL. JK. Gettin' antsy for the weekend.
--"U Ain't Fast!!"
Chris Pearce
Old 09-12-2007, 09:55 AM   #611
if you are having problems with the pins coming out of the center cvd's, you need the gmk supply cvd condoms. i ran 3 races with the set screw loose just to see if it would destroy anything on the front cvd and it did not hurt anything, i relubed and am still using all of it including the condom. reusing a condom just sounds wrong, lol!
T Green is offline   Reply With Quote
Old 09-12-2007, 11:10 AM   #612
Default Diff cups
Has anyone had the gears slip in the diffs yet? My front and center diffs are both locked up because the pins rotated in the diff cups. Just wondering if was happening to anyone else.
wntabrr is offline   Reply With Quote
Old 09-12-2007, 11:21 AM   #613
XrayRacer's Avatar
Here goes a dumb question. I was starting to experiment with the different clutch springs and the differences between the composite shoes versus the aluminum shoes. Well, when I went to place my order I noticed that there where different degree of springs, 25 deg and 30 deg. Since I am relatively new to the 1/8th scale racing, I am assuming that the 25 is the soft and the 30 is the harder spring. Am I correct on that? Also what would the pro's and con's be for running the different springs. Our track is lightly watered between each race, so you start out with traction but by the time the 6 minutes are up the track is almost dry again. Right now I am running the 4 shoe aluminum with I think silver springs all the way around.
Old 09-12-2007, 11:32 AM   #614
SHIZZILANILLA's Avatar
The grooves where the pins slide in get alot of stress ,they will wobble out causing the gears to slip.
SHIZZILANILLA is offline   Reply With Quote
Old 09-12-2007, 11:57 AM   #615
I forget the degrees and such, but in order from soft to hard: Black/Green/Gold/Silver. Silver has the highest engagement. I probably wouldn't run silvers unless I had a really high bite track or a peaky motor.
Losi 8ight-T 1.0 OS Speed JR 9000S/T
Losi 8ight 1.0 C6BB7T 2045 086 Hitec 5997TG/JR 9000S
Losi 22 Tekin RSpro 8.5/JR9000S
All controlled by 3PK/FASST
magbarn is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
