Old 08-30-2007, 04:05 PM   #586
MikeFriery's Avatar
Trader Rating: 19 (100%+)
my truck came with a yellowish color brake pad ive never seen before.. did losi revise them?
MikeFriery is offline   Reply With Quote
Old 08-30-2007, 09:37 PM   #587
Trader Rating: 15 (100%+)
Send a message via AIM to James Y
My 8T's brakes are very weak! I'm using the JR 9000s for throttle/brake and find it very hard to brake. Anyone using different brake pads?
James Y is offline   Reply With Quote
Old 08-31-2007, 02:29 AM   #588
Default 8t
I thought the fuel line on the linkage was to soft so I changed it to some stiffer stuff and that did the trick.
sracer is offline   Reply With Quote
Old 08-31-2007, 02:30 AM   #589
MikeFriery's Avatar
Freefallmarine- You can use a 1/10th scale shock shaft as your rear outer hinge pin. You can modify it to use a capture screw if you really want.. or you can just use a 1/10th scale piston to hold one side in place, and still use the nut on the other side.
Old 08-31-2007, 07:19 AM   #590
As long as your hubs are at least 2 spacers back, the hinge pins will not break/bend with normal use. (not talking about a head on into one of your rear wheels or landing a big jump on one rear wheel.) There is too much leverage when running the hubs all the way forward or one spacer back. The stock hinge pins are fine with this setting.
Themajorhobby is offline   Reply With Quote
Old 08-31-2007, 10:06 AM   #591
Lars Johnson's Avatar
Send a message via AIM to Lars Johnson
I dont think they are a different material, probably just a different shade of the same material. My kit (s/n 1982) came with the white ones, i'm still running them, but i just put the yellow shaded ones on my 8ight, and i didn't really notice any difference.
you might want to look at what sracer said, and if you've run the truggy for a while, the disc's and pads are probably glazed. i've got about 4 gallons thru mine now, and i've taken them out twice and scuffed the disc's with a scotch brite pad to get all the build-up off, and just flipped the brake pads last weekend. I've been running the same JR 4800T throttle servo the whole time, she still stops on a dime.
Team Associated / Reedy / AKA / Futaba / OS Engines / Byrons Fuel / www.steelescycle.com
Lars Johnson is offline   Reply With Quote
Old 08-31-2007, 12:37 PM   #592
SHIZZILANILLA's Avatar
I have run my hubs 2 spacers back and front and they still bent , Also truck handles better with Hubs forward . I just mashed a railroad tie throuh my hubs ,now they dont bend.
SHIZZILANILLA is offline   Reply With Quote
Old 08-31-2007, 01:16 PM   #593
air8's Avatar
??HUH???? What do you mean by "railroad tie"?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-31-2007, 07:21 PM   #594
freefallmarine's Avatar
Choo,Chooooo.....
freefallmarine is offline   Reply With Quote
Old 08-31-2007, 11:51 PM   #595
tex1's Avatar
Send a message via Yahoo to tex1
Red face
Joe and I made some out of drill blanks from the trickest of aircraft surplus supply stores. Joe said they are unbendium. I'll let you guys know if it is Shens or not. I think it is true tricknology at work here!
We have not bent any yet. The Lunsford ones suck!!
TEX
tex1 is offline   Reply With Quote
Old 09-02-2007, 08:06 PM   #596
mcsquish's Avatar
Hi all, I have just picked up a 8T and I am wondering what changes are being made to it. I haven't ran off-road for about 5 or 6 years (local track closed, had to go on-road) so I'm WAY out of the loop for information. I have to apologize for being too lazy to read all of the previous pages before asking............
mcsquish is offline   Reply With Quote
Old 09-02-2007, 10:42 PM   #597
air8's Avatar
No changes needed. Just run it. I think in the 8ight thread someone posted to use a small piece of fuel tubing on the throttle linkage to absorb vibration the throttle servo might endure. Also using a one piece engine mount make maintenance very simple. Engine swaps or pulling for clutch inspection takes less than two minutes to pull the engine. If you got the RTR start planning for decent servos. Enjoy the truck, it's awesome.
--"U Ain't Fast!!"
Chris Pearce
Old 09-02-2007, 10:50 PM   #598
MikeFriery's Avatar
i ran my eight t out of the box yeterday, with the exception of taking a few screws out and making sure they were loc-tited and it ran flawlessly, and the kit setup was really good.
Old 09-03-2007, 01:01 AM   #599
Default Outer Pins
I'm running these. Highly recommended.
http://www.m2cracing.com/product.sc?...&productId=158
dirtdemon is offline   Reply With Quote
Old 09-03-2007, 01:02 AM   #600
RETRO RC's Avatar
nice choice the 8T rocks here a small list of things that need attention
1. check all parts are loctited as some kits have had problems with screws coming loose, especially the front centre universal.
2.make sure that your end points on the throttle servo are set properly and that there is no binding (under braking especially). 3-5mm of fuel tubing on the pull side of the throttle servo horn is a must.
3. the plastic inserts in the factory servo horns have been known to strip on the steering servo so it might pay to get a solid aluminium horn for the steering.
4.the plastic rear bearing inserts wear pretty quickly on the 8T so it might pay to get the ali ones part# LOSA4430 theyre alot cheeper that replacing a crown and pinion gear.
5.clutch shoes either king heads 7075's or the dynamite long lifes would be my pick haven't tried the new losi long lifes yet
I'm sure there are things that other people have or are doing but these a just a few to get you started
have fun burn nitro
Adrian
RETRO RC is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
