Old 06-04-2007, 06:12 AM   #451
Had the same thing happen with servo saver nut backing off, I cleaned the treads and applied blue lock tight, but I think I want to find a flanged bearing
for the bottom post.
Steve.
sbales is offline   Reply With Quote
Old 06-04-2007, 09:26 PM   #452
gearheadz80's Avatar
I ran into the exact same problem too the T. This last weerkend
gearheadz80 is offline   Reply With Quote
Old 06-05-2007, 12:01 AM   #453
SHIZZILANILLA's Avatar
how tyte do you run the servo saver . like how many threads show at the bottom?
SHIZZILANILLA is offline   Reply With Quote
Old 06-05-2007, 03:38 AM   #454
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
dont know...havnt tore it apart yet...and for the record... this is one of the reasons I prefer a kit
i would just run it so that it has a little give...
KB
whered my sig go???
Keith Billanti is offline   Reply With Quote
Old 06-05-2007, 05:57 AM   #455
Run the servo saver flush from the bottom of the threads on the buggy and 2-3 threads tighter on the truggy.<---straight from Adam Drakes mouth.
H8W8IN is offline   Reply With Quote
Old 06-05-2007, 06:18 AM   #456
Default servo saver...
i had the same problem...i just tightened it up 2-3threads and put loctite on the treaded area of the servo saver and im good to go, just like new, turns on a dime, haven't lost steering as of yet....
stakin is offline   Reply With Quote
Old 06-05-2007, 01:42 PM   #457
Aaron Waldron's Avatar
It is important to keep an eye on the servo saver, especially to keep it clean. Blue loctite is a great idea to keep the adjustment consistent.
Also, take your servo saver apart and use a file to round the pointed edge of the two servo saver halves. This will help the servo saver break free more easily and work better.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-07-2007, 10:06 AM   #458
mbunker's Avatar
Trader Rating: 29 (100%+)
Send a message via MSN to mbunker Send a message via Yahoo to mbunker
Default slop from worn servo saver arm
I was having an issue with not getting the front wheels to center correctly. After tearing down the steering servo saver assembly, I noticed that the plastic where the servo saver arm top section meets the bottom half with the servo saver spring was worn and had a ton of slop/play. Now I know why Losi came out with the aluminum servo saver arm upgrade and I have one ordered. My 8B hasn't developed this problem which is probably due to the lighter front tires or maybe running the buggys servo saver tighter.
(Kind of makes me wonder if they released this alum arm hopup because they had the foresight on the wear with the plastic arm, then what's the reason behind the center diff front bearing alum. spacer insert.)
mbunker is offline   Reply With Quote
Old 06-08-2007, 06:56 PM   #459
robsxxxs's Avatar
a quick question to you all. my 8ight B's chassis is quite stiff, but my 8ight t is noticably very flexible. are you guys running the aluminum braces front and rear or just in the rear?
robsxxxs is offline   Reply With Quote
Old 06-08-2007, 11:16 PM   #460
The extra leverage really makes a difference!
I don't think the flex is a bad thing at all. Heck, that's why the buggy is that way also. I've heard of some people running one or the other but I know my truck, and at least Truhe's, have the stock braces.
www.liverc.com
Old 06-09-2007, 07:55 PM   #461
lavaandy's Avatar
Default clutch
who is running the kings head clutch shoes? do you like silver and gold springs like the buggy or would it be good to try all silver?
lavaandy is offline   Reply With Quote
Old 06-11-2007, 03:16 AM   #462
El Pedro's Avatar
Hey,
Just ordered a new Eight T. Am planning on putting OS V Spec with OS 3 chamber pipe in. Futaba S9351 and S9451 Servos with my Spektrum HRS gear in.
Are there any mods that need doing right out of the box?
Am hoping to be running this weekend.
El Pedro is offline   Reply With Quote
Old 06-11-2007, 06:58 AM   #463
mbunker's Avatar
Originally Posted by El Pedro View Post
Hey,
This is the exact same setup I run in my 8t except for I run a jp-2 pipe and header. I would suggest getting a 1400 lipo receiver pack and running the 6v regulator since you will be running two digital servos. Also get an aluminum steering servo horn since the plastic losi one will last about 5 minutes with the Futaba servo. And maybe get the Kinghead Aluminum clutch shoes and run all four aluminum it the truggy. There is plenty of info on the losi clutch already here on this forum so I'm not going to go into detail of it here.
Michael Bunker
Old 06-11-2007, 02:24 PM   #464
El Pedro's Avatar
Thanks Michael,
I already use Lipo in all my trucks and will continue to do so with the Losi.
Do you have part numbers or links for the appropriate servo horn and clutch setup?
Old 06-11-2007, 04:18 PM   #465
If you intend on running Losi clutch parts, try four of the blue aluminum shoes with four silver springs. Works awesome!
www.liverc.com
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
