Old 05-23-2007, 08:11 PM   #421
air8's Avatar
Did you have to modify the starting wheel? And what did you make the plate out of, regular plate steel? that's what i'm looking for for another month's worth of racing.
air8 is offline   Reply With Quote
Old 05-23-2007, 08:56 PM   #422
scabsk8s's Avatar
i only had to shim the wheel up a little ,about 2 washers & it was perfect....
the plate is made out of .060 aluminum & i used some non-slip tool box mat for the top ,,to tell you the truth ,i think its much more solid then the TKO plates..
scabsk8s is offline   Reply With Quote
Old 05-23-2007, 09:14 PM   #423
The magic X5 is perfect for the 8ight in every way. I havent seen a better fitting box and its more than powerful enough for stubborn break ins. No drilling or modifying and the wheel is tiny and fits perfect! For the person who mentioned the mugen box check out rccompound.com they have a awesome deal on them right now. But look at the magic its like it was made for it
turtletrax is offline   Reply With Quote
Old 05-23-2007, 09:23 PM   #424
air8's Avatar
Originally Posted by Hugh
I need to make a cut on the other side in the back to form another placement peg. The one's been working fine,so far.
Hugh--does your modified peg go in front of the arm or behind it?
Old 05-23-2007, 09:24 PM   #425
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
+1 for the Team Magic X5 starter box.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-25-2007, 04:24 PM   #426
ZERTA RACING's Avatar
Trader Rating: 36 (100%+)
Hey has anyone seen the RTR version of the 8t whats the diffrence between the two
- Thomas
ZERTA RACING is offline   Reply With Quote
Old 05-25-2007, 06:58 PM   #427
Hugh's Avatar
Trader Rating: 14 (100%+)
Neither. Snugs up against the chassis.
Hugh is offline   Reply With Quote
Old 05-25-2007, 08:33 PM   #428
Default Rear hinge pins
keep bending the stock ones and the new improved silver ones just snap,
so I made my own. Will try out tomorrow.
McMaster Carr p/ns
3009A242 ,8813A32
will try .136 m2 first and if they bent will go with .140-9/64 m42 which are super hard.
sbales is offline   Reply With Quote
Old 05-26-2007, 07:56 AM   #429
so what are the most commen problems with the 8t
Old 05-26-2007, 07:58 AM   #430
My only problem has been rear hinge pins bending.
Old 05-26-2007, 08:37 AM   #431
22Racer's Avatar
Trader Rating: 67 (100%+)
Anyone looking for a starter box modded for the 8t. I have a Ofna stainless box for $25.00 the motor fryed but most Hobbyshops have the replacements. (775 size)
E-mail 22welch@cannon.net
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 05-26-2007, 09:31 PM   #432
I am a noob to this site but I am pretty ser there is a buy and sell form =)
Old 05-26-2007, 10:27 PM   #433
air8's Avatar
- Thomas
If its's like the 8 RTR, Shock tower, hinge pin plates, chassis, clutch shoes, drive hexes and wheel nuts, shock shafts, shock springs, shock pistons, steering hinge pins, engine mounts, and "Losi" bubble nameplate. There might be more too. On my buggy this was the difference. Add it up. It's big.
Old 05-27-2007, 09:28 AM   #434
Talking
These pins worked out great, 1 gallon of racing yesterday
and not even a hint of bending perfect.
3009A242 used with 1/8 alun shaft collars also from McMasters
must be cut with dremal cutoff wheel, cut alittle,cool with h2o
cut little more, same with notch on ends, try not to get pins hot.
I also made alum hub spacer .151 thick "one piece"
Good Luck. Reamers are $ , drill bits work.
Losi Truggy-pins.jpg   Losi Truggy-pins-installed.jpg   Losi Truggy-pins-cut.jpg
Old 05-28-2007, 04:13 PM   #435
whats the cheapest place to buy one of these bad boys online?
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
