Old 04-19-2007, 09:43 AM   #331
freefallmarine's Avatar
Originally Posted by tex1
CARL -
?????? Do you have my pinch tool for .21s???????
I can't remember where that thing went......
TEX
I don't have it.
freefallmarine is offline   Reply With Quote
Old 04-23-2007, 06:23 PM   #332
S Bowen's Avatar
Trader Rating: 57 (100%+)
Anybody having issue's with slow speed steering? My truck has a push at off power and I tried different tires and tried a smaller sway bar in front.
FACTORY TRACKS RACING, NANKIN HOBBIES, LUNSFORD, JCONCEPTS, KOLOR KONCEPTS
S Bowen is offline   Reply With Quote
Old 04-23-2007, 08:51 PM   #333
SlobbaTech's Avatar
Try going to #5-a rear camber link (you'll need to cut the turnbuckle like .060"-.100" shorter per side or it will bottom out in the ball cups leaving you with like +5* camber), go to the 3/3 rear plate, and then run 2 spacers in front of the rear hubs.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 04-23-2007, 10:34 PM   #334
TonysScrews's Avatar
Check the ride height. I don't run the Losi 8 but many of my friends do and the ride height is critical on that buggy. I would check it before every run as it'll change depending on any setup changes, the car getting weighted down with dirt, different height tires, etc.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 04-24-2007, 07:38 AM   #335
If you haven't tried it yet run Mike Truhe's setup on the 8T. Thats what I used on my sons T this weekend it was crazy fast!
Tekno RC, Alpha Plus Engines
AKA Products, Lutz RC, A-Main Hobbies
NitroPro Fuel, Hot Headz Engine Heaters
Raceform Bodies.....Reilly Paint (Just Plain Wicked)
gasser is offline   Reply With Quote
Old 04-25-2007, 10:23 AM   #336
air8's Avatar
Does the 8T's manual describe where to measure ride height? I will probably buy mine tomorrow. Why is this hobby so expensive. It's gotta be the thrill factor. HE HE. Is front ride height measured behind the front a arms, and then the rear ride height measured below the rear toe block? Thanx
air8 is offline   Reply With Quote
Old 04-25-2007, 08:52 PM   #337
Send a message via AIM to Brushless Corey
I have #1406
I just ran mine for the first time thos past Sunday. Didn't do too much with it though cause I'm breaking in the Picco P7R .21 I have in it. I'm also using a Dynamite 053 pipe on it. Just running it around the track the 8T seems to be well balenced. I can't wait to run some more tanks through this engine and start tuning it more and get some speed out of it.
Brushless Corey is offline   Reply With Quote
Old 04-26-2007, 10:28 AM   #338
Default droop
Center of top shock mount to center hole on lower shock screw.95mm front 110 mm rear
bnmbh is offline   Reply With Quote
Old 04-26-2007, 07:51 PM   #339
Factory Seal's Avatar
Trader Rating: 29 (100%+)
I have had better balance with the stock tire pattern.... Man those thing's hookup on anything! Wear kinda quick though.......I try not to Swell them,Get a few more runs out of them that way.
Have you had any more issues with your Truggy?
How many run's on your Shocks?And Diff's....What Servo are you runnin?
Sorry for al the questions..Butt slow speed push.could be alot of factor's..........
Is the truggy Free Rolling....When off....Will it roll across the kitchen floor.....
Gear mess will jack it up.......The rear brake Linkage is touchy....
Like i said could be several thing's.........Im sure you will figure it out soon,,,,mine will turn on a dime on or off Throttle.........most likely it is something simple........
My 02..........
My club.....msra-racing.com
Factory Seal is offline   Reply With Quote
Old 04-27-2007, 10:17 AM   #340
air8's Avatar
What is the average price of the 8T?
I thought my hobby shop would get me a better deal because I buy all that I can from him. I went to the store to practice with my buggy last night and maybe buy the T. But, he is asking like $650. It sounds a little too close to retail for me. Right now I drive the 8b and loving it. I want to get the truggy but not get ripped off. I have driven a few of the other guys' T's and they feel great. If it is close to what others are priced, then so be it. But just wanting others opinions.
Thanx
Old 04-27-2007, 10:47 AM   #341
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
The 2 shops in the town I live in(Vancouver WA) both have them for $569.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 04-27-2007, 11:51 AM   #342
air8's Avatar
If they were that price here I could get a JP-3 pipe also. Hmmm. Too bad I guess, I'll just wait. I want to support the LHS but not get screwed.
Old 05-06-2007, 05:39 PM   #343
Trader Rating: 28 (100%+)
What starter box are you guys running without hassle?I need to buy one that I don't need to chop up my chassis or mod the box too extensively.Thanks in advance!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-06-2007, 06:03 PM   #344
Hockey 85's Avatar
I use the Team Magic X-5 starter box works great. The only downside is that you can only get three pins for the wheel allignment, because the chassis covers the fourth. Also with any starter box you get take your time alligning it, take off your motor and look through the flywheel slot for the starter wheel and make sure that it is perfectly alligned.
Good luck
Team Associated - LRP - Reedy - Upgrade R/C - Byron's Fuel - Momentum R/C Racing Team
Hockey 85 is offline   Reply With Quote
Old 05-07-2007, 10:18 AM   #345
I took mine to the track yesterday for the 2nd time and the JR 650 throttle servo decided to take a crap on me. I didn't even get 1/4 of the way around the damn track.
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
