Old 12-01-2008, 04:50 PM   #1771
Tin
What's the TFT?
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Tin is offline   Reply With Quote
Old 12-01-2008, 04:59 PM   #1772
air8's Avatar
Tuned Flex Technology.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-01-2008, 08:53 PM   #1773
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Tin View Post
What's the TFT?
Tuned Flex Technology. it has machined areas in the radiused edges of the chassis which makes it flex more.
here is a linkhttp://www.tiltedrc.com/product_info...oducts_id=4051
JAMMINKRAZY is offline   Reply With Quote
Old 12-01-2008, 11:02 PM   #1774
Tin
nice , thanks guys.
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Old 12-03-2008, 05:42 PM   #1775
Hey guys just picked up a new 8ight T Race Roller cheap and wondering what upgrades are recommended. I am a experienced racer but not with Losi's. I did pick up a HD diff for the rear I hear that might be a weak spot?? how is the stock Motor mount? what else is needed or is there anything that is a weak spot?
fordtastic is offline   Reply With Quote
Old 12-05-2008, 09:56 PM   #1776
air8's Avatar
Personally, I'd suggest an extended quick change engine mount to reduce some flex around the clutchbell/spur gear area. It seemed to help prolong clutchbell bearing life for me. If you crash enough the outer rod ends on the steering linkage will pop off easier and easier over time. Kyosho and Calandra Racing Concepts sell a "no-pop" kind of pivot ball. If you use these with a bit longer screw and a washer under the screw head, you won't have to worry about these ends popping off so easy.
Get the aluminum bearing inserts for the rear diff case. If you use a powerful engine look at getting the HD diff case for the center diff. Although the new 2.0 cases are said to be better than the HD cases.
Use heatshrink, or the "2.0 grease boots" for the Center F/R pinion couplers. Also GMK sells a set specifically for the 8ight and T. Basically just vacuum caps with a hole punched in the center.
Just develop a good maintenance routine to check things over every couple of race weekends and you should be good to go.
--"U Ain't Fast!!"
Chris Pearce
Old 12-06-2008, 06:14 AM   #1777
C.Capelo's Avatar
Trader Rating: 113 (100%+)
+1 for these necessary upgrades. The only thing I haven't had a problem with yet are the diff cases. But if I do, I will change out the stock cases to the HD cases.
One question...Do I have to change all 3 cases to HD cases? I have 2 Losi
8ights (one nitro, one brushless) and a 8ight-T so I'd be looking at buying 9 HD cases!!!
C.Capelo is offline   Reply With Quote
Old 12-06-2008, 11:47 AM   #1778
air8's Avatar
I wouldn't think you would HAVE to change. I think it comes down to how your vehicle is driven. A lot of chop, chop on the throttle probably causes more wear than rolling on the throttle. In nitro racing you always see most people working the throttle quickly through the corners. I think that's where the wear comes from.
Maybe just check your diffs over time. Order one or two of the HD cases. As you rebuild each diff check the cases for excessive wear. Then you could replace if necessary. That way it's easier on the pocket book and easier on time management. For my truggy to start showing wear in the center diff was around 7-8 gallons of fuel.
Of course, high powered engines/motors will cause more wear quickly. So that's my thoughts. Replace them as you go.
Also I would think the new 2.0 cases will fit also. They are supposed to be stronger and last longer. We'll probably start finding out in the next month or two from the people who've had their new 2.0 in use for a while.
--"U Ain't Fast!!"
Chris Pearce
Old 12-06-2008, 11:55 AM   #1779
C.Capelo's Avatar
Thanks for the info...I'll keep this in mind!
Old 12-06-2008, 03:50 PM   #1780
Chill_Will's Avatar
Trader Rating: 32 (100%+)
!!!!!!!!LOSI 8IGHT T PARTS FOR SALE!!!!!!!!!
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 12-14-2008, 05:53 PM   #1781
Hey new wit the Losi truggy whats the diffrance with the short and long ackerman. what does what?? why two sizes?
Old 12-14-2008, 06:18 PM   #1782
Integra's Avatar
the manual has descriptions of everything at the back fyi.
Old 12-22-2008, 04:32 PM   #1783
Miller_Time's Avatar
Trader Rating: 11 (92%+)
Can someone give a quick rundown of the differences on the RTR and race roller sets? I have someone offering to trade their RTR 8t to me but I was really looking for a race roller unless the differences are minimal.
From a quick glance over the listed specs it appears the differences are not as major on the Truggy as they are on the 8b roller and RTRs. Specs say same chassis but is that really correct?
Also is the Losi 427 a .27 engine? Is it decent at least or total trash? I'd like to get this racing so if there are major items in need of replacing I will hold out for a better offer on a roller.
Thanks!
www.HobbyStop.com
Miller_Time is offline   Reply With Quote
Old 12-22-2008, 04:36 PM   #1784
Tin
the differences are the shock towers, upper shock caps, chassis, engine mount ( because the 427 uses rotor start), and i think Servo saver upper arm, and allow chassis brace. I used the 427 and its a pretty good motor. Tuned right, it runs around 200 degrees and has good torque. I get about 11 minutes on a tank.
Tin
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Old 12-22-2008, 04:56 PM   #1785
Not really that big of differences just alot of minor things.
the 427 is a .26 and runs very well for a rtr motor.
the differences are
chassis
shock towers
shock top and bottom caps
shock shafts(just not ti coated)
hinge pins(again no ti)
king pins(yet again no ti coating)
diffs filled with grease(instead of silicone fluid)
Engine mounts(taller to fit the roto start)
Hex hubs(blue instead of grey lol)
Basically the only thing that makes a difference is the durability of the towers and shock caps and the flex characteristics of the chassis.
Neither the race roller or rtr have aluminum chassis braces and that is because they hurt handling and arent needed what so ever.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
