Old 11-28-2008, 09:02 PM   #1756
Integra's Avatar
Originally Posted by mcsquish View Post
Question for everyone using lipo receiver packs. Who's regulator are you using? I tried a Castle Link, but when I use the throttle and steering at the same time, one will die (I'm guessing because of lack of current). I tried moving the output voltage higher, but no help. I'm thinking of getting a losi one, but since the Castle Link is rated at 10A and the Losi is 5A, I'm not sure. So I was wondering if I'll have the same problem with the Losi regulator. I thought for a sec or two I'd run without one, but the servos were WAY too fast.........
running unregulated depends on Rx and servo's.....if you got both that can take 7.4+ then why not....turn down the speed on the radio if need be...I run the losi regulator with no issues.
Old 11-29-2008, 12:09 AM   #1757
hambone's Avatar
6.2 volt protek. It's been flawless all year and has led's to let you know if battery getting low.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 11-29-2008, 01:58 AM   #1758
Tin
I just got a 8ight-T RTR for a birthday gift. Question is what the difference between the Race Roller and the RTR truggy beside the RTR comes with the electronics and engine, etc? I wanted to upgrade my RTR to race specs. Oh and im using the Losi Lipo with the Losi regulator on a futaba 4pk with S9351 servos. No problem so far.
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Tin is offline   Reply With Quote
Old 11-29-2008, 05:13 AM   #1759
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Change the F/R Shock towers, Chassis, clean the grease out all three diffs and put diff oil in them, change the motor mounts and get a bump box, change the shock caps from plastic to alunimum.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 11-29-2008, 07:49 AM   #1760
air8's Avatar
Originally Posted by Integra View Post
whaa ?
Originally Posted by BOOST View Post
Yea....whaa??. Never ever heard of such a thing happening!
Those stone filters came apart a lot on me when the 8ight first came out. I had 3-4 of them seperate. So I came on here to ask and a guy recommended soldering the nipple and the filter together. Same thing when the T came out I broke one stone filter and soldered the two pieces together.
Anyways, your responses answer my question. LOL.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-29-2008, 08:01 AM   #1761
rjs_13203's Avatar
just bought a new hitec 7955tg servo and then got the team losi servo horn for it but it doesnt want to go on smoothly?? not sure if i should force it?
"You ain't seen nothin yet"
rjs_13203 is offline   Reply With Quote
Old 11-29-2008, 08:10 AM   #1762
CaLaBeR's Avatar
Is this the team losi aluminum horn or plastic? If its aluminum make sure the splines are lined up, it may take a bit of pressure to put on but not much make sure you got the right horn aswell.
CaLaBeR is offline   Reply With Quote
Old 11-29-2008, 08:12 AM   #1763
rjs_13203's Avatar
it would be the team alum one, also the one that came with it(alum) seems very tight. just scared, dont want to stripe it.
Old 11-29-2008, 12:43 PM   #1764
Integra's Avatar
My losi horn on my 5955 in truggy is overly tight.....i need to use Side cutter's to get the darn thing off....its tight but does fit.
Old 11-29-2008, 01:12 PM   #1765
rjs_13203's Avatar
cool just didn't want to damage a brand new servo
Old 11-29-2008, 03:50 PM   #1766
mcsquish's Avatar
When I put the AL on my Hitec servo I had to give it a little "persuasion" to get it on. Getting it back off is the real trick........
Thanks hambone
mcsquish is offline   Reply With Quote
Old 11-29-2008, 04:12 PM   #1767
Integra's Avatar
Thanks hambone
med To large Side cutter's....lay them across the rx box and lightly squeeze between the horn the top case....dont squeeze too hard or you will scare up the splines.
Old 12-01-2008, 09:54 AM   #1768
Tin
Does anyone know if these r good or bad chassis?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220318446972
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Old 12-01-2008, 11:04 AM   #1769
C.Capelo's Avatar
Trader Rating: 113 (100%+)
Stay away from the Dragon chassis. A fellow teammate had one on his Mugen MBX5T and it broke where the engine mount holes are! The stock chassis or the TFT chassis is the way to go. If you don't want to spend the money on the TFT chassis then stock Losi chassis can be had on ebay for around $50. Just my 2 cents
C.Capelo is offline   Reply With Quote
Old 12-01-2008, 11:07 AM   #1770
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 dragon racing chassis' are junk. stick with either the stocker or even better the TFT.
JAMMINKRAZY is offline   Reply With Quote
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
