Old 09-07-2008, 08:20 PM   #1591
air8's Avatar
http://www.losi.com/Products/Support...rodId=LOSA0802
Here ya go. Click on Instruction manual Part 4. Then scroll down to 3 pages from the bottom. This is the stock RR setup. They don't have a direct link to it. Also in this section of the manual is all the tuning info you need.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-07-2008, 10:06 PM   #1592
HuntersDad's Avatar
Trader Rating: 38 (95%+)
who is the Losi team manager these days?
HuntersDad is offline   Reply With Quote
Old 09-09-2008, 03:22 PM   #1593
rjs_13203's Avatar
will a lst2 throttle spring work on an 8-t
"You ain't seen nothin yet"
rjs_13203 is offline   Reply With Quote
Old 09-09-2008, 03:25 PM   #1594
Integra's Avatar
throttle spring.....meaning what exactly....throttle return spring ? a linkage spring ?
Old 09-09-2008, 03:26 PM   #1595
rjs_13203's Avatar
isnt there only 1 spring on the throttle side??
Old 09-09-2008, 03:32 PM   #1596
Integra's Avatar
typically yes.....But some guys run return springs....which i dont advise....so i was just checking......but it'll depend on how u have the throttle set-up....u can always add a stopper on the back side to tighten up the spring if its not long enough.
Old 09-09-2008, 03:51 PM   #1597
rjs_13203's Avatar
i just got it used and the guy i got it sent me a throttle spring from a lst2 and said it would fit, i just wanted to make sure. sorry its my 1st exp with anything nitro, have always been an electric guy
Old 09-10-2008, 06:56 PM   #1598
air8's Avatar
What I've found works great is the little tiny rubber bands in the women's section of hair products at the stores. They are so small and when you put one or two around your carb, it works better than most throttle return springs. They stay out of the way, don't wear out, and they come in packs of like two hundred. Plus they're easy on the pocket book.
--"U Ain't Fast!!"
Chris Pearce
Old 09-10-2008, 07:33 PM   #1599
rjs_13203's Avatar
can someone plz show me a picture of there throttle linkage, i want to make sure that i have it right
Old 09-11-2008, 08:23 PM   #1600
rjs_13203's Avatar
new question just put in my airtronics 94358 servo for steering and it is whinning a whole lot, doesnt want to return to tires straight or eben turn them half the time?? just bought it from a guy at the track, is it shot or just not strong enough
Old 09-12-2008, 06:34 AM   #1601
air8's Avatar
Sorry RJ I don't have an engine in my T right now.
For the steering what have you checked so far? Remove servo horn to see if the steering works smooth by hand. If there is tight spots or resistance, start taking the steering apart one section at a time. There isn't a known problem in this area so it might be dirty. The one thing that has bit newer drivers is the servo saver adjusting nut on the bottom of the right hand steering post. If the nut backs off it will rub on the chassis and lock up your steering.
At my last race I found my end link to be very dirty and the plastic rod ends were super tight. It was bad enough the steering was something I'd never experienced before. So I lightly squeezed the rod ends to free them up. This is done in electric racing also to free up the ball cups a bit when new. After a few times of doing this with the T, the steering got back to 100%. So maybe check these two things and see if that helps.
--"U Ain't Fast!!"
Chris Pearce
Old 09-12-2008, 06:41 AM   #1602
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
as long as you follow the instructions and do the tray and do the addendums, you will be dialed!
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 09-12-2008, 07:29 AM   #1603
rjs_13203's Avatar
could the servo be doing that cuz the reciever pack was dying
Old 09-13-2008, 12:23 PM   #1604
rjs_13203's Avatar
got a question just picked up a used 8-t put in my servos and when i tested the brakes when i let off it seems to pull the carb open but then when i press the gas and let off it goes back to a neutral position am i doing something wrong???
Old 09-13-2008, 01:35 PM   #1605
air8's Avatar
rjs--Make sure you aren't holding your radio too close to the vehicle when checking over stuff. Even with Spektrum systems you can get little glitches when the radio is too close.
Sounds like you need some small adjustments on the linkages. Check the servo horn is not rubbing on your servo. If so use a small #4 washer to raise the horn up. Use a throttle return rubber band or spring that can pull the carb closed if you shut your radio off. This alone will help with servo centering when letting off the brakes. The linkage length from servo horn to the carb might need shortened/lengthened.
Then move on to checking your servo gears inside of the top half of the case. Many servos use one plastic gear, even when they are labeled as all metal gears. And this protects the electronics in most cases, for those really nasty sudden stops from WOT. So this plastic gear might have some damaged or worn teeth. They are very, very tiny teeth too, so look closely.
Maybe these suggestions will help.
--"U Ain't Fast!!"
Chris Pearce
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
