Old 07-28-2008, 08:19 PM   #1516
halfempty's Avatar
Looks like I'll be hittin the hobby shop tomorrow followed by some wiring after work. Oh sigh Thanks for your help integra
halfempty is offline   Reply With Quote
Old 07-28-2008, 08:22 PM   #1517
Integra's Avatar
NO problem dude.....ANY time.
Old 07-31-2008, 01:30 PM   #1518
LOW ET's Avatar
Trader Rating: 95 (100%+)
anyone tried the light weight wheels yet? how's reliability?
LOW ET is offline   Reply With Quote
Old 07-31-2008, 02:10 PM   #1519
Integra's Avatar
good as far as im concerned....i got a couple race weekends on mine and there just fine.
Old 08-01-2008, 06:05 PM   #1520
LOW ET's Avatar
anyone make black wheels that will fit this truggy? what rim/tire combo are most of you guys running?
Old 08-01-2008, 07:18 PM   #1521
Integra's Avatar
i prefer GRP and Panther tires on the losi wheels.....if u want black...just Dye the white ones.
Old 08-01-2008, 07:30 PM   #1522
LOW ET's Avatar
years ago we used rit dye, it that still what people are dying wheels with?
Old 08-01-2008, 07:38 PM   #1523
air8's Avatar
Yep, Rit Dye. That's the stuff you want. And leave them in the dye for much longer than you think. Otherwise they come out dark purple.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-01-2008, 08:49 PM   #1524
Integra's Avatar
Yupper's....i leave mine in overnight when i used to dye rims.......Not any more tho.....black wheels at dusk= No fun
Old 08-03-2008, 06:46 PM   #1525
rcdaddy's Avatar
My Losi was raced for the first time today and I had a problem I need some help with. While jumping and the nose falls down it cuts out like it is running out of fuel then when it lands it takes a few seconds to clear out. When I check the in tank filter it was fully sumerged in fuel. I can turn the truck in all different positions while holding it and it does not do this until I hold it by the wing or even at a 45 degree angle with the nose down. It just acts like it is not getting enough pressure to move the fuel into the carb. I changed the fuel line and also tried moving the filter in different posistions in the tank. My freind has one and it does it also but a few others had them and theirs is fine. Sorry this post is so long but I need help. Thanks in advance.
I have posted this in the nitro forum also. I just need quick help. Thanks again.
Drive It Hard and it Will Be Fast
Nova Rossi, Jammin, Team Associated, OS Engines, Futaba, Airtronics, Go Engines, RB Mods, Fusion Motorsports
WCRC Raceway
Big Billy's RC World
Baity's RC
rcdaddy is offline   Reply With Quote
Old 08-05-2008, 03:07 PM   #1526
LOW ET's Avatar
how high from the ground can you drop your truggy without the chassis bottoming out?
Old 08-05-2008, 04:38 PM   #1527
Integra's Avatar
depends on what Wt shock oil but i would assume a couple feet or so...
Old 08-05-2008, 07:04 PM   #1528
air8's Avatar
Same here. Maybe two feet with 50wt or higher and the heavy springs.
Normally I drop mine from less than a foot, usually using 45-40wt front oil with 55piston, and 30-40wt with 56 piston.
Many times i have too much crap laying on the bench to do the drop. So I just lift the truck till tires are off the ground and then drop. Then push down several times quickly on the front and rear shock towers. Kind of like tapping the towers.
I try to stay with the same technique for a while. But sometimes I switch it around for no reason.
--"U Ain't Fast!!"
Chris Pearce
Old 08-05-2008, 08:44 PM   #1529
fishin4cars's Avatar
I had the same problem on mine, Not exactly which thing I did was what cured my problem but here are the two things I did so maybe you can at least look and check them out. 1) I took the upper needle valve out and put a small amount of thread sealer on the threads and retightened it back down, I think the spring for the throttle may have loosened it up just enought to allow a small amount of air in to the carb chamber. It was loose enough I could move it by hand. 2) I also replaced the oring that I had in my in-line fuel filter. It kept bogging down like it wasn't getting any fuel right after a good jump or roll. one of the two things seems to have fixed the problem as it hasn't reoccurred now in well over a month.
fishin4cars is offline   Reply With Quote
Old 08-05-2008, 10:28 PM   #1530
rcdaddy's Avatar
Thanks, I will try that. I have a new tank on the way and I am going to do one thing at a time to see which is the problem. I will check my needles first. Thanks again.
Has anyone else had this problem???
WCRC Raceway
Baity's RC
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
