Old 07-21-2008, 12:30 AM   #1501
Integra's Avatar
from playing with Multiple differnt motor's and Countless clutch set-ups...ive found that every motor brand fits a little differently and needs its own shimming....1 shim behind the collet to sit the flywheel center'd in the cutout.....or couple under the 5x13 to get the "air gap" as LOW ET liked to put it.......and i have even gone as far as to use the Ofna Style bushing and shave it down to the specs needed....what ever it takes.
Old 07-27-2008, 06:45 AM   #1502
air8's Avatar
I've been running the last couple of races without the Front swaybar. I like the feel of it. But there are moments the front will bite too hard and the truck wants to spin. Easily correctable though. Without the front swaybar I really like how the truck reacts and behaves.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 07-27-2008, 03:41 PM   #1503
Integra's Avatar
x2...i recently went down to the thin bar up front and noticed a slight difference in how the truck came off little roller's and step down's....i might try No bar next time.
Old 07-27-2008, 04:46 PM   #1504
LOW ET's Avatar
Trader Rating: 95 (100%+)
i got my clutch issues fixed and my truggy is back in action . it seems i got my top end running ok (smoke, 230*) but i think the bottom end needs a little work. should i see smoke when i hit the throttle before the truck moves? at the crack of the throttle it seems lazy until it clears out then it hauls the mail. sometimes at idle i can tap the throttle and the rpm doesn't change until it clears out, also after running it around the rpm seems to hang slightly until i blip the throttle and then it comes down to normal. any suggestions?
LOW ET is offline   Reply With Quote
Old 07-27-2008, 07:53 PM   #1505
air8's Avatar
Sounds like it's a bit fat (rich) on the bottom. Just remember that each day will be different than the last time you ran. You HAVE to set your carb needles each time you go out. It's not like these things are fuel injected and have a computer to adjust the fuel, air, and timing.
I come across many people that say something like this, "I don't know what's wrong, it was running great last weekend. I haven't changed any of the needles."
I'd suggest leaning the bottom a bit, and you might have to back out the high speed needle a little. But it's hard to say without being there and hearing your engine.
--"U Ain't Fast!!"
Chris Pearce
Old 07-27-2008, 07:56 PM   #1506
Integra's Avatar
I love it Air.
Old 07-27-2008, 08:00 PM   #1507
air8's Avatar
Originally Posted by Integra View Post
I love it Air.
LOL. How often do you hear it? I'm sure at least once every month or two. Just guessing though.
I'm not trying to put anyone down guys. So please don't take my suggestions like that. I'm simply saying your carb WILL need adjusted each time out. And if you get lost on your settings or you don't quite understand what's going on, just back the needles out and slowly work your way back in. Make small 1/8 turns adjustments, or use the clock face hours as an adjustment. 1 hour, or 2 hour adjustments.
--"U Ain't Fast!!"
Chris Pearce
Old 07-28-2008, 01:42 AM   #1508
LOW ET's Avatar
to make sure i'm turning the right needle to lean out the bottom, do i turn the one on the linkage side or on the opposite side of the carb. i'm using a os speed 21vz-b v spec engine.
Old 07-28-2008, 05:42 AM   #1509
air8's Avatar
http://www.osengines.com/engines/osmg2068.html
In this link the, picture shows the low speed needle closest to the camera. I would call this linkage side.
At the bottom, rear of the carb is the idle needle.
And then of course the brass guide sticking straight up is the high speed.
According to the picture in the link above, the carb would need to be facing the opposite way for 1/8 racing. Turned 180 degrees so the slide can be operated by the servo. This would put the idle needle at the front of the carb and very low. Access would become more difficult but shouldn't be an issue really.
--"U Ain't Fast!!"
Chris Pearce
Old 07-28-2008, 08:11 AM   #1510
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
a good starting point for the low speed needle (linkage side as you say) is flush with the body and parallel to the chassis. You may have to go +1/-1 hour for a better tune, but i have run 3-4 specs and they all had good bottom at this general location.
Fot the mid needle (opposite of the low speed and under the high speed) yo want to go flush with the body and set it to 2 o'clock.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 07-28-2008, 01:11 PM   #1511
LOW ET's Avatar
ok, so i was right on what needles to turn. i'll have to play with it and do some fine tuning.
Old 07-28-2008, 07:07 PM   #1512
halfempty's Avatar
Just got a .28 GRP mill with pipe any suggestions for a really good starter box ? I purchased the losi one and have had nothing but problems with it. Only had it two days and one of the motors died so I replaced it, now on the third day and the other one just died. Needless to say I'm not very impressed Just curious to know what starter boxes you guys are using?
halfempty is offline   Reply With Quote
Old 07-28-2008, 07:55 PM   #1513
Integra's Avatar
the losi...Modified a little.
PS that Pipe that comes with the promo pack somewhat tones down the power of that mill...try a 086 or MSR 1005 to really wake that thing up.
Old 07-28-2008, 08:01 PM   #1514
halfempty's Avatar
That looks pretty much what I was thinking of doing, I see you dealt with the too short wires that rub the wheel problem too ! ! What kind of motors did you put in there? Its a shame that all this work has to be done to it to make it good
Old 07-28-2008, 08:08 PM   #1515
Integra's Avatar
i hear ya....but like anything....stock really never cuts it. ....there Integy 55's....a whopping 18$ a peice.....couple Ft of Deans and a Ebay 4 cell for around 40$.....its been workin like a Charm the last month or so since i did the swap.
Losi 8ight-T Truggy Pro Roller, 10 truggy tire/wheel sets deskwarmer R/C Items: For Sale/Trade 60 10-03-2008 08:29 AM
Losi-8T Truggy or Mugen MBX5t truggy 8IGHT-TMAN Nitro Off-Road 1 01-24-2008 06:47 PM
Losi 8ight Truggy vs/or Losi Muggy????? rclab1 Monster Trucks 5 11-22-2007 03:56 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
mugen truggy/ losi truggy Ultraspeed84 Electric Off-Road 4 05-30-2007 06:58 PM
