Old 09-25-2007, 12:24 AM   #91
Turbine_au's Avatar
How many shims for the turbo plug on 25% nitro? The parts sheet says 2 x 0.3mm and 1 x 0.1mm making a total of 0.7mm. Is this correct?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 09-25-2007, 05:24 AM   #92
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
yep thats right the factory setup i shimed mine down to .5 worth of shims total to up the compression i ran her on 25% and never had a problem with it but thats up here in Queensland me JP is setup the same way
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 09-25-2007, 06:36 AM   #93
Turbine_au's Avatar
I might just leave it at 0.7mm then. Easier on the engine and I'm not looking for every single little bit of power.
Old 09-25-2007, 06:54 AM   #94
GenReaper's Avatar
Send a message via MSN to GenReaper
But your gonna need the power to catch my newly ported Gotech Brad
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 09-25-2007, 10:58 AM   #95
Rosco's Avatar
Send a message via MSN to Rosco
Originally Posted by Turbine_au View Post
You may actually be too rich on the low with too high an idle setting to compensate. So when you come off the throttle, the idle is too high and there is still plenty of fuel there as it's too rich, hence the high idle. Try leaning the low end and bringing the idle down.
Yea I had the same problem this weekend too, it would idle really high for a few seconds when I start it then kick down and idle really nice. Also would keep a high idle when Im going over jumps too.
Thanks!
Allen Roth
GPMRA Executive Board Member
XRAY XB8TQ (Novarossi Plus 21-5 .21) - Team Associated RC10T4 (Team Brood 27t)
Grande Prairie Electric Winter Cup 2007 2nd place 1/10th
GPMRA 2007 Outdoor 1/8 Buggy Champion
Rosco is offline   Reply With Quote
Old 09-25-2007, 02:56 PM   #96
22Racer's Avatar
Trader Rating: 67 (100%+)
I added a .004 shim and went to a #7 plug and it idles down perfect now. I had not added a shim at all before and I am running 30%
Rex
22Racer is offline   Reply With Quote
Old 09-25-2007, 07:10 PM   #97
Turbine_au's Avatar
That's assuming it stays in one piece.
Old 09-26-2007, 12:59 AM   #98
Turbine_au's Avatar
Talking My Nova's happy again!
Just came back inside after having a post rebuild run.
I changed:
  • Standard to Turbo underhead
  • #7 to #5 plug
  • Standard to Boca Bearings
  • 0.7mm to 0.6mm shims
I was having problems with not holding a tune, the front bearing had a leak, it would constantly flameout and was running way too hot. Now, it holds a tune, has a nice plume of smoke and still runs great and runs a lot cooler than before. Still fiddling with the tune but I'm so much happier now.
Can you tell I'm excited?!
Old 09-26-2007, 01:10 AM   #99
GenReaper's Avatar
Good stuff Brad, im glad for ya, now we can get some racing next meeting
Make sure everything is good including your tyres :]
Yeah i havnt run my GO tech yet since i ported it and put new Con Rod, Bearings and Orings in the carbi, so who knows it could go pop.
Cya at the Working bee this weekend mate.
Trex 600E
HPI Baja 5B SS
Old 09-26-2007, 05:10 PM   #100
22Racer's Avatar
Isn't a #5 plug quite a bit hotter?
Rex
Old 09-26-2007, 07:27 PM   #101
Turbine_au's Avatar
Yep. Makes a difference though. Everyone I know running a plus 21 has switched to hotter plugs and they run a lot better.
Old 09-27-2007, 03:03 AM   #102
RCRacing.com.au's Avatar
Talking Hotter Plug
Yeah everyone I know is running either a #5 or a P3 OS plug in their plus21.
They are a newer version of the p5 which had the same problem of flaming out.
The hotter plug seems to be better to keep a nice tune and keep them running without flaming out.
I'm running a #5 also and it works well.
I just changed my rear bearing and bought a TKO from a guy on here which is pretty loose for a new bearing.
It has twice the play of a Novarossi bearing so i just bought a novarossi one onstead.
How do the Boca Steel ones go?
Anyone else tried any other good bearings with luck?
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 09-27-2007, 09:07 AM   #103
Turbine_au's Avatar
I've only put one tank through the new bearings but they seem quite nice. The front bearing doesnt leak and it only has the one outside seal. My original front bearing leaked quite a bit.
I'll let you know what the're like when i've got a couple of litres through them. These are the ones I got:
http://www.amainhobbies.com/product_...oducts_id/2321
http://www.amainhobbies.com/product_...oducts_id/7094
Old 09-29-2007, 03:35 PM   #104
im thinking of getting one of these for my st-1 truggy for next season. seems like nothing but good reviews for this motor. i have one question. i'm going to be running byron's 30% fuel, will i need to shim the motor or will it be okay? also, where do i get the shims?
Redfox03 is offline   Reply With Quote
Old 10-22-2007, 11:04 AM   #105
I've got in my arsenal a JP1, JP2 and the pipe that came with my Hyper 8.5 Pro.
What is the BEST pipe for the 21-5? I picked one up from a friend and would like to know the best, well-rounded pipe out there. And answers don't NEED to be from what I have...I won't mind buying a new pipe if it is better than what I have
toejam is offline   Reply With Quote
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
