Old 06-07-2007, 08:46 PM   #76
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Maybe a 6 for running in but the 7's are perfect for when its run in and racing
Try the 7 if they give you trouble ie flaming out all the time then try a 6
for run in id recommend the heat cycle method
http://www.johnnycoolguy.com/JCGR/ma..._break-in.html
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-09-2007, 06:57 PM   #77
Zen of Speed's Avatar
What kind of temps/settings are you guys running with your plus 5's?
After run in I have settled to about:
3 1/2 out HSN (This is about turn inward from flush.)
1 1/2 out LSN
Temp: 240
I can richen it up a 1/4 turn and she runs about 210 (I saw her at 270 after a qualifier and got that fixed quickly - I hope/guess no damage occurred!)
I think this is about right for racing... not many flame outs and have 1/2 gallon through and use the C7-S extra cold plugs from Novarossi. I would like to know if I am on the same page as everyone else with this motor.
Zen of Speed is offline   Reply With Quote
Old 06-09-2007, 08:52 PM   #78
tune by hour increments not quarters of turns
my 21-5K ran at 390 twice and got that fix quickly
and no damage was done that i can see with the naked eye
Robert.Hull is offline   Reply With Quote
Old 06-09-2007, 11:47 PM   #79
Low end sound way lean try 3 1/2 on the low and 3 out on the high temps shouldn't matter tune for performance the use the temps for reference after wards
1 1/2 out LSN
Temp: 240
Futaba
Mugen
Novarossi
Byron's
Old 06-10-2007, 03:04 PM   #80
RCRacing.com.au's Avatar
Post Temps
Nitro Junkie is right, tune for performance not just for temps.
They will run a little hotter until they break free for about the first 4-6 litres anyway.
Once you hit that mark they will run a little cooler, between 200-240 is fine.
It should start at say 200-220 at the start of the tank and finish at 220-240 give or take 10-15 degrees F.
If you keep leaning the top end in 1 hour increments until it really starts to scream then bring it back in and see what the bottom end sounds like.
After that turn the top back in 1 hour.
I'd say with the LSN at 1&1/2 turns out it will be way too lean and start to sound like a rotarty engine going bap bap bap bap or just idle really high.
Go to at least 3 turns out & start from there.
Your slide on the carby should only be open 1/2 to 1mm and it should purr nice and smoothly when idling.
You should also be able to get at least 10 seconds just sitting on idle after a big blast then open it to full throttle again and it should just about tear the tires off the rims and rev nice & clenaly.
1 1/2 out LSN
Temp: 240
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 06-11-2007, 05:39 PM   #81
houston's Avatar
Trader Rating: 91 (100%+)
Talking
HEY AUSSIE , DID YOU GET THOSE BEARINGS INSTALLED ? HOW WAS THE SIDEPLAY ON THE TKO BEARINGS YOU GOT ?
LATER , MONTY
houston is offline   Reply With Quote
Old 06-12-2007, 02:52 AM   #82
Talking TKO Bearings
LATER , MONTY
Nitro Junkie posted them today i believe so i will have them tomorrow.
They are the same bearings that EB Mods use when they do their mods so they can't be too bad.
One of the guys at our club said he ahs run the same set in 2 motors and they out lasted the motors.
I hope they are good cause i don't want to destroy my Novarossi for a set of bearings.
I'm sure they will be fine.
I have to do my first bearing change when i get them as i have never done it before.
Got any tips?
Steve P
-Stuff for sale-
Old 06-12-2007, 03:02 AM   #83
Yeah mate posted them today you should get them tomorrow
Got any tips?
Futaba
Mugen
Novarossi
Byron's
Old 06-12-2007, 03:03 AM   #84
Thanks Ashley i'm looking forward to getting them and getting the beast going again. It's been a ball tearer of a motor.
Steve P
-Stuff for sale-
Old 06-12-2007, 02:58 PM   #85
it looks suspect that nova give you a set with the new 367`s,i think they should have tko ceramics in them to start with and considering the rossi bearings are dearer as well,ive already replaced mine with another rossi set but wished id gone with tko,the rest of the motor is the baddest f%$#@n motor out there
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 08-06-2007, 07:06 PM   #86
22Racer's Avatar
Trader Rating: 67 (100%+)
Anyone have problems with the idle staying high for a few seconds? It bothers my son because the idle is high while in the air over jumps. I think it's the tune but I haven't been able to get it right. I have put a new tko front bearing in, sealed the carb and cover. We tried another carb and pipe, nothing really changed.
Rex
22Racer is offline   Reply With Quote
Old 08-06-2007, 07:19 PM   #87
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Rex....tell your son to slow down and not use full throttle, that will solve it. See you guys at Full Throttle.
wrightcs77 is offline   Reply With Quote
Old 08-07-2007, 07:09 PM   #88
Peter Martin's Avatar
22racer...try richening the low end and re-tune.
Peter Martin is offline   Reply With Quote
Old 08-07-2007, 07:47 PM   #89
22Racer's Avatar
before we tried the other carb I was 5 turns out on the low.
Rex
Old 08-07-2007, 08:35 PM   #90
Turbine_au's Avatar
You may actually be too rich on the low with too high an idle setting to compensate. So when you come off the throttle, the idle is too high and there is still plenty of fuel there as it's too rich, hence the high idle. Try leaning the low end and bringing the idle down.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
