Old 06-04-2007, 05:20 AM   #61
RCRacing.com.au's Avatar
Default TKO Bearings
Originally Posted by Nitro$junkie View Post
Id get the TKO ceramics for $50AU delivered
Sounds like a plan stan.
I'll fix you up during the week and email you.
Cheers
RCRacing.com.au is offline   Reply With Quote
Old 06-04-2007, 05:33 AM   #62
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
I will be at Meakin on Saturday night i can bring them if you like make things a bit easier
Cheers
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-04-2007, 09:49 PM   #63
Talking
That sounds good mate.
I won't be there until after 6pm though as my wife works until then and i will be looking after our 2 daughters.
You should be able to find me ok as some of the guys know me, being the vice pres and all that.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
Old 06-05-2007, 09:50 PM   #64
freefallmarine's Avatar
Anyone try the front bearing seals from tko? I have a leaky bearing in my p5 and saw just the seal for sale.I wonder if it would work.
freefallmarine is offline   Reply With Quote
Old 06-06-2007, 01:34 AM   #65
Default bearing seals
Mate if your seal is gone then there is a chance you may have got a tiny bit of dust into your motor or at least the front bearing.
I would suggest you just replace the front bearing.
Once a motor is dusted it is usually F^@#&*!
I've just had the same problem with my Plus 21-5T so i stripped it down to check it out.
Luckily the piston and liner are still perfect but the bearing has too much play in it for me.
I will be getting some TKO Bearings this weekend to fix mine.
They are excellent value for money bearings for ceramics.
Steve P
-Stuff for sale-
Old 06-06-2007, 08:25 AM   #66
Thank's Steve. The problem i have is the washer dug into the front bearing when i tighened the collet and flywheel. It just dug in and now has a slight leak. it suck's cause i have like 1/2 gallon on this motor.
Old 06-06-2007, 09:14 AM   #67
Turbine_au's Avatar
As part of the deal on my engine, I got some Nova #7 (non-turbo version) plugs thrown in. Are these going to be too cold for run in? Are they a bit too cold for normal running as well?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-06-2007, 09:30 AM   #68
hey guys i have a quick question i just switch to novarossi and i was wondering am i correct you have to replace the con rod after break in
and isnt the plus 21-5K and 367 plus2 using the same conrod (R7)
Robert.Hull is offline   Reply With Quote
Old 06-06-2007, 02:55 PM   #69
just doubbled check actually they are the same rod
Futaba
Mugen
Novarossi
Byron's
Old 06-06-2007, 08:19 PM   #70
Anybody using the O'donnell cooling head for there motor? I was told not to use the button that comes with it. Any paticular reson?
Old 06-06-2007, 08:35 PM   #71
houston's Avatar
Trader Rating: 91 (100%+)
Talking
theres nothing wrong with the odo buttons , you just have to use only one of the aluminum head shims . that is the proper head shimming (novarossi long strokes). i usually use the stock buttons though . no particular reason .
houston is offline   Reply With Quote
Old 06-06-2007, 09:39 PM   #72
Thank's H.
Old 06-07-2007, 03:44 AM   #73
would like to know if anyone has tried the new ninja fls 2053 pipe on the novarossi plus21-7bt,it looks a very good pipe (excellant joining system on the manafold)and i like the perfomance of my novarossi 2015 but i damaged it at the last race meet and am looking for something better and stronger
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 06-07-2007, 08:41 PM   #74
Turbine_au's Avatar
Anyone got an answer to my glowplug question?
Old 06-07-2007, 08:44 PM   #75
those plugs are spot on
Futaba
Mugen
Novarossi
Byron's
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
